Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
My WUrlitzer 1015 omtCD selects CD, places it in the CDM4 player then the player moves to the left a little so the gripper arm isn't holding the CD any more, but mine isn't moving far enough left so the gripper arm rubs the CD which makes it skip then reject, I've seen other 1015's in operation and thier player moves to the left more than mine, can I adjust this?
    Problem Solver:
  • 16 Answers
There are 2 to 4 screws that adjust the arm tighten or loosen the to fix this issue
Posted on Dec 12, 2009
Can't play discs
i can send you the manual to fix it
Sep 18, 2012 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Problem
A flashing 8 indicates that the gripper arm is not returning to the idle position. It could in fact be returning, but a switch is not operating properly. Feel free to email me for further troubleshooting help. tech@wurlitzer-ohio.com.
Mar 23, 2010 | Wurlitzer Jukebox 1015 One More Time...
I have a 1993 wurlitzer New York, New York jukebox. it has the same inters as a 1015 one more time. the problem i am having is with the cd gripper arm. it will take a cd from the cd carousal and place it...
I would suspect you have a lubrication (or more specifically lack of lubrication) problem. When the gripper arm is over the carrier, pick it up a couple of inches (as it moves to pickup a CD) and drop it. It should snap right back down. If it doesn't, it will not properly pickup and return CDs. You may be able to lubricate it to get it working again. For further information, you may email me, tech@wurlitzer-ohio.com.
Mar 15, 2010 | Wurlitzer Jukebox 1015 One More Time...
Flashing 8 on display
A flashing 8 on the display indicates that the Selection and Credit Computer hasn't detected the gripper arm has returned to it's normal rest position over the CD carrier (where the CDs are stored). It can be caused by several factors:
1. Gripper motor switch has been turned off
2. K7 microswitch or actuator is defective
3. Blown fuse in amplifier
4. Defective gripper motor
5. Open latch solenoid coil
6. Defective Selection and Credit Computer
I am the authorized Wurlitzer Jukebox repair center for the US and would be happy to help you over the phone. I can supply parts and repair defective amplifiers and computers, etc. Please email me tech@wurlitzer-ohio.com.
Jan 18, 2010 | Wurlitzer Jukebox 1015 One More Time...
WURLITZER OMT CD 100 D picking problem
Hello J.P.,
You need to get the manual for this jukebox.
You have to however confirm what the manufacturer and the model number of this is. The One More Time was made by the following manufacturers:-
Wurlizer, Rowe Ami, Rock Ola, Antique Apperatus and Sound Leisure.
Look for a serial plate on the back of the jukebox in order to get any information.
You can get manuals in the USA from www.victoryglass.com
Regards
Alan Hood
ami-man
UK
Nov 17, 2009 | Wurlitzer Jukebox 1015 One More Time...
Hello, I have a problem with WURLITZER 1015 OMT CD 100D. The arm go to pick up the CD, but returns in the same time as it lock the cd in the gripper.Result is the CD is supported on two points instead of 3...
The carousel is locked in position by the latch at the front (about 6 oclock). If the gripper isn't exactly in line with the cd then you need to adjust the latch a bit.
Nov 16, 2009 | Wurlitzer Jukebox 1015 One More Time...
OMT Gripper Issue
There's a spring wound round the shaft of the rod that drives the gripper gears. Oil very lightly. The gearbox rotates when it puts the arm back but the arm is held against the driving part by this spring so if it is sticking the arm will not turn over properly even if the drive shaft is doing what it is supposed to.
Dave.
Oct 23, 2008 | Wurlitzer Jukebox 1015 One More Time...
Record Changer Arm
When the carousel reaches the correct count, the computer sends a signal to the gripper motor to start it. You could have a bad motor or a bad computer. But!....if the little switch at the front of the machine is in the off position (Gripper motor On/Off) that will give exactly the same effect. It's easy to knock Off when you are loading CDs.
Oct 02, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 3600 series
The microswitch at the base of the gripper arm is what enables the scan motor when the gripper is over the carousel. You will probably find that the small lever on the base of the tone arm is not clicking the microswitch properly.
Dave .
May 20, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 1015 OMT 100CD
I asked a Wurlitzer engineer about this problem and he simply said, "Bend it a bit."
Sounds horrible but there is no genuine adjustment. But before doing that, try moving the carousel lock latch (at the 5 oclock position). This is what locks the carousel and determines its position when the correct CD number is reached. If you could ****** or advance it a little it might work.
Dave
Apr 05, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
177 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
John Robertson
John Robertson
Level 1 Expert
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
