Question about Cole HERSEE PUSH-PULL SWITCH -- OFF-ON
Rewiring my boat and I have a Cole Hersee push-pull 3 way switch. Which terminal is positive, which is negative. and which terminals do i attach my power source too?
  • 8,404 Answers
I'm going out on a limb here and try to answer your question. I don't know what a Cole Hersee push pull switch is or what you are trying to do. However, I am familiar with automotove and marine wiring.
I would normally expect this switch to turn something on and off. The something in case probably expects a common ground which we can call negative. In a car, the common is the body. In a boat, you probably have to provide the common ground (plastic boat). When you turn the the switch on, you are providing power to it. So, you have a hot wire that goes to the switch we will call "line" and a switch leg we will call "load" The hot (line)comes from the power supply and the switch leg (load) goes to the something or two somethings. The negative is not involved in this switch.
You say this is a three way switch. This can mean several things. In this application, I believe you have a "something #1" and a "something #2" in which case you have one line and two load wires. For a better example, posiion #1 on your switch is OFF - while position #2 turns on the light in the cabin and position #3 turns on the light in the engine room. Or, it could be you have a Forward and a Reverse (either this (position) or that (position)). In that case, the power would most definitely go to the center tap. A different way to explain is is in Forward position, the head lights come on while in reverse, the backup lights come on. I know, I know, no head or tail lights. I'm just trying to esplain my thought a little better.
So, I have said all of that to say this. Using your volt/ohm meter, find out which terminal becomes live in position #2 and #3. I would try the first terminal as the HOT.
You can test this by applying power (12 volts) to the first terminal and then measure voltage in the other two positions to prove the theory.
If I missed the mark, please post a comment to this question and I will address your concerns.
I want to help you and learn at the same time.
Thanks for posting at FixYa.com
please vote
thanks
a
Posted on Dec 13, 2009
Show proper battery hookup for 24 volt trolling motor, 2' 12 volt batteries
to get b24 volts from 2 x 12 volt batteries
connect the negative (- ) terminal of one battery to the ground point on the motor
next connect the positive terminal (+ ) of that same battery to the negative terminal of the next battery
connect the positive terminal of the last battery to the power terminal of the motor
so it will be negative to ground , positive to negative , positive to motor or motor control
(-) to ground (+ ) to (-) , (+) to motor
That is called a series connection and increases the voltage available
Mar 23, 2017 | Boating
Tip
How to Wire On-Board Marine Battery Chargers
Battery chargers are wired into a boat's electrical system. Wiring the charger to a battery switch permits the charging of the individual batteries or battery banks. The switch can be configured to charge both batteries or battery banks at once. Mounting the charger in the vessel keeps the charger where it will do the most good--connected to the batteries. This is useful if you are stuck with low batteries and need a recharge. Power from a generator, shore power or even AC power from another vessel can be used to get you going again
Instructions Things You'll Need:
Battery charger
Battery switch
Battery cable (sized)
Cable cutters
Razor knife
Battery terminal lugs
Lug crimper
Terminal kit
Terminal crimper
Hammer
Step 1
Mount the battery switch with the mounting kit provided by the manufacturer. The switch should be accessible but close to the battery or battery banks.
Step 2
Mount the battery charger in a location that will be accessible but protected from the elements. Mount the charger close to the battery switch to reduce the size of the charger leads.
Step 3
Connect the battery cables to the battery switch. Mount the battery cables onto their corresponding terminal studs on the battery switch.
Step 4
Lay out the battery positive cable from the charger to the switch and cut it to length with the cable cutters. Strip 3/4 inch of insulation from the cable ends with a razor knife. Splice the cable to the hot wire from the charger with a **** connector and the terminal crimper. Crimp a terminal lug onto the battery end of the cable with the lug crimper and a hammer. Connect the terminal lug at the battery switch positive output terminal.
Step 5
Lay out a battery cable from the charger to the battery negative terminal block. Cut the cable to length and strip 3/4 inch of insulation from the ends with a razor knife. Connect the battery negative cable to the charger negative power lead with a ****-splice and the terminal crimpers. Crimp a terminal lug onto the terminal block end of the cable with the lug crimper and a hammer. Connect the terminal lug at the battery negative terminal block post.
Tips & Warnings
Set the switch to "1," "2" or "both" to charge battery bank 1, bank 2 or both batteries at once.
on Jan 07, 2010 | Mercedes-Benz C230 Cars & Trucks
How to connect fishfinder to 2014 carolina skiff jvx 18 cc
get a volt meter I would suspect that the breaker would have positive only on it, Run a wire directly from the negative terminal of the boat's battery to the negative on the volt meter and then test the toggle switch with the positive lead of the volt meter to find out what is being switched when the accessories are keyed to on. If you don't want to use a volt meter you can use a probe like this one http://www.banggood.com/Waterproof-Voltage-Digital-Electric-Sensor-Detector-AC-Or-AD-12V-250V-p-918269.html?currency=AUD&utm_source=google&utm_medium=shopping&utm_content=miko_ruby&utm_campaign=Industrial-au&gclid=CNTr_uG7hL4CFY2CvQodfIcAQA. or use a 12V light globe soldered to a black negative wire and then solder a red wire to the other globe terminal and put the black wire on the boat negative terminal. Finding negative will be your challenge. The metal frame under the dash may be hooked to negative or the metal case of the key switch may be connected to negative. you may wish to run a negative wire through the boat connected straight to the negative on the boat battery if you can't find a good source of negative.
see http://www8.garmin.com/learningcenter/on-the-water/echo/ installation video for help with your project. Use a pin pressed into the wires that come off the key switch to find the switched accessory wire via a voltage test. You may need to shave the insulation back and solder a positive wire to it and then tape it up with insulation tape where the join has been made. (I used to install car phones years ago ) Hope this is some help and gets you on the right path
Apr 26, 2014 | Garmin Echo 550C 5" Color VGA Fishfinder...
I have a 1996 Acura 3.5 R.L. just put a new fuel pump in and it won't start. It turns over, but will not stay started.
Check your main fuel relay.
Fuel Supply System
PGM-FI Main Relay
Description
This PGM-FI main relay is located behind the dashboard
lower cover. The PGM-FI main relay actually contains
two individual relays. One relay is energized whenever
the ignition is on. It supplies battery voltage to the PCM,
power to the fuel injectors, and power for the second
relay. The second relay is energized for 2 seconds when
the ignition is switched on, and when the engine is running.
It supplies power to the fuel pump.
PGM-FI
MAIN RELAY
FUEL
PUMP
RELAY
Relay Testing
NOTE: If the engine starts and continues to run, the PGMFI
main relay is OK.
1. Remove the PGM-FI main relay.
2. Attach the battery positive terminal to the No. 3*
terminal and the battery negative terminal to the
No. 2* terminal of the PGM-FI main relay. Then
check for continuity between the No. 5* terminal and
No. 2 terminal of the PGM-FI main relay.
• If there is continuity, go on to step 3.
• If there is no continuity, replace the relay and
retest.
*: 8P CONNECTOR
To FUEL PUMP
3. Attach the battery positive terminal to the No. 4 terminal
and the battery negative terminal to the No.
7* terminal of the PGM-FI main relay. Then check
that there is continuity between the No. 3 terminal
and No. 1 terminal of the PGM-FI main relay.
• If there is continuity, go on to step 4.
retest.
4. Attach the battery positive terminal to the No. 1 terminal
and battery negative terminal to the No. 2*
terminal of the PGM-FI main relay. Then check that
there is continuity between the No. 5* terminal and
• If there is continuity, the relay is OK;
If the fuel pump still does not work, go to Harness
Testing on the next page.
retest.
To PCM CONNECTOR
TERMINAL A4
To ST. SWITCH
To GROUND
To IGN. 1 To BAT
To PCM
CONNECTOR TERMINALS
A13 and B1
FUEL PUMP
RESISTOR
FUEL PUMP
Sep 18, 2013 | 1996 Acura TL Series
Neutral switch location on 1994 VT600
Instructions
    • 1 Pull the left and right covers out of the rubber grommets on both sides of the motorcycle's frame. Pull the rubber strap off the tool kit holder on the left side of the motorcycle and remove the tool kit.
    • 2 Locate the fuse box on the right side of the motorcycle, just above the battery. Remove the pair of bolts that secure the fuse box to the battery box with a 10 mm socket. Pull the fuse box away from the battery box.
    • 3 Reach into the left side of the frame to access the battery's negative terminal. Unscrew the negative wire lead bolt from the battery's negative terminal with a 10 mm wrench. Pull the negative wiring lead away from the battery.
    • 4 Reach into the right side of the frame and remove the positive wiring lead bolt from the battery's positive terminal with a 10 mm wrench. Pull the positive wiring lead away from the battery.
    • 5 Pull the battery out of the battery box from the right side of the motorcycle. Slide a new YTX9-BS battery into the battery box, positioning the battery's positive terminal to the right of the motorcycle. Reconnect the wiring leads to the battery's terminals, connecting the negative lead first followed by the positive lead. Tighten the lead bolts with a 10 mm wrench.
    • 6 Reattach the fuse box to the battery and tighten both bolts with a 10 mm socket. Place the right side cover over the frame. Push the cover's tabs into the frame's rubber grommets.
    • 7 Place the tool kit into the tool kit holder on the left side of the motorcycle. Pull the rubber strap over the tool kit and hook the end of the strap onto the holder's catch tab. Place the left side side cover over the frame. Push the cover's tabs into the frame's rubber grommets.
Jan 16, 2013 | 1994 Honda VT 600 C Shadow
Simple horn diagram for 19ft. ski boat
One lead is power when button is pushed the other ground.
Jul 26, 2012 | Boating
How to
Please follow the following instructions 1)Use a wiring harness equipped with an adapter plug for faster connection and installation.Disconnect the car battery while installing electronic equipment.
2) Make a note of the wire colors and connect the power supply wires to the DEH-45DH as follows:
Orange wire to the constant 12Volt
Yellow wire to the switched 12Volt
Black: ground wire
3) Connect these wires to control display functions on the DEH-45DH:
Attach the gray wire to the wire marked control panel illumination.
The brown wire connects to the dimmer.
4) Make the front speakers connections following this color scheme:
Left front positive (+) tan wire
Left front negative(-) Gray
The light green wire connects to the positive (+) terminal of the right front speaker.
Connect the dark green wire to the negative (-) terminal of the right front speaker.
5) Make these rear speaker connections:
Brown wire to the left rear positive (+) terminal
Yellow wire to the left rear negative (-) terminal
The dark blue wire attaches to the right rear positive (+) terminal
The light blue wire connects to the right rear negative (-) terminal
Hope this helps
Thanks
Smith.
Sep 09, 2009 | Car Audio & Video
Wiring two circuit pull switch boat lights
3 terminals.. 1 power input & 2 x outputs
Main positive goes to 1 terminal = power in to switch.
The anchor goes to another terminal = power out from switch to anchor
3rd terminal is another output for lights/anchor.
Mar 28, 2009 | Cole HERSEE PUSH-PULL SWITCH -- OFF-ON
Cole HERSEE PUSH-PULL SWITCH -- OFF-ON Logo
169 people viewed this question
Top Cole Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Cole Electrical Supply Expert? Answer questions, earn points and help others
