Question about Refrigerators
Hi,I have a GE 42" Monogram refrigerator,model # ZISW42DYB,serial #LS037072. The problem that I have is the freezer is leaking water even if I turn the ice maker off.In a day or two the ice tray fills with water & freezes & stops despensing ice.Could it be a defective fill valve? Thanks,Paul
    President:
  • 1,218 Answers
Good day Paul.
Sounds like your diagnosis is right on. In extremely rare cases the ice maker itself could be at fault. But once again is extremely rare.
Posted on Dec 13, 2009
Serial #
What problem are you having? All you need is the model number.
Jul 05, 2013 | GE Monogram ZICS360NRRH C... Bottom...
My monogram refrigerator leaks water from the upper left side/top of the freezer.It is a model ZIS- 42
you have a blocked/frozen evap drain tube leading to the pan, located directly above the freezer section. in all honesty donot believ this to be a repair homeowner should attemp i would contact an authorized ge servicer.As a maytg/ whirpool servicer myself , i know in our built in refigs we have new heated drain tube/evaporator pans that we installe possible that GE has as well
Mar 14, 2008 | Refrigerators
I am thinking about buying a used ge monogram range. Model number ZDP48L4GH3SS. I am trying to find the stats for it, but I am having no luck. Would especially like to know how old it is, what it weighs,...
All in the links below.
GE Appliances Model and Serial Number Locator
www.geappliances.com/ge/find-model-serial-number/
Find Your Model & Serial Numbers. Select your product type. Refrigerators & Freezers. Compact and Wine & Beverage Refrigerators · Bottom-Freezer Refrigerators · Chest Freezers · Icemakers · Side-by-Side Refrigerators · Top-Freezer Refrigerators · Upright Freezers. Cooking Products. Advantium Ovens · Cooktops ... Missing: zdp48l4gh3ss
How to Determine the Age or Manufacture Date of a GE Appliance
products.geappliances.com/appliance/gea-support-search-content?contentId=16195 How to Determine the Age or Manufacture Date of a GE Appliance. The manufacturing month and year is coded into the serial number (not the model number) of the appliance. Our serial numbers begin with two ... for further assistance. For information on old RCA appliances, see RCA Appliance Age or Manufacture Date. Missing: zdp48l4gh3ss
Discontinued Models - GE Appliances
www.geappliances.ca/en/products/discontinued-models Discontinued Models · Explore our GE Collections. Our Company. About us. Our Story · Appliance Donation Center · Press Room. Websites. GE Appliances Worldwide · Business to Business · Corporate Website · Careers · Monogram Design Centre ... Missing: zdp48l4gh3ss
Parts for GE ZDP48L4GH3SS Range - AppliancePartsPros.com
www.appliancepartspros.com > GE > Range Original, high quality parts for GE ZDP48L4GH3SS Range in stock and ready to ship today. 365 days to return any part.
Parts including Gas burners
http://www.appliancepartspros.com/parts-for-ge-zdp48l4gh3ss.html
These are posts about that Range
https://cse.google.com/cse?cx=partner-pub-9933858514302629:4836214790&q=ZDP48L4GH3SS&oq=ZDP48L4GH3SS&gs_l=partner-generic.3...146736.146736.0.147883.1.1.0.0.0.0.115.115.0j1.1.0.gsnos%2Cn%3D13...0.42j1764j2..1ac.1.25.partner-generic..1.0.0.BUEnm5lSMk4#gsc.tab=0&gsc.q=ZDP48L4GH3SS&gsc.page=1
Weight and Specs will be the same at 538 lbs.
ZDP48N6DWSS GE Monogram 48 Professional Range with 6 Burners and Griddle...
Jan 24, 2018 | GE Monogram ZDP48L4GHSS Dual Fuel...
Approx 1996 model- Have been having water leaking into freezer- water line is shut off. Now the entire freezer compartment on top is a large block of ice and dripping down. Is it possible to shut the...
No, the fridge side gets it cold from the freezer. You can turn the freezer off and use a hairdryer to thaw it out and the fridge side won't loose much cold during that time.
Your water inlet valve may need replaced to fix the leak unless the leak is a hole in the water line.
Feb 05, 2011 | GE Monogram ZISS420NRSS 42" Built-In...
GE Monogram bottom freezer leaking water from left side onto the freezer floor and onto hardwood floor of the kitchen . Already tried totally defrosting freezer and that did not solve problem. Help!!
ck the drain in the back of freezer . it may be pluged and when it goes into defrost cycle you get about a cup of water on the floor . if there ice on bottom of freezer then the drain is iced over . some models require a drain heater to prevent this . mm hope this helps ..
Oct 14, 2010 | GE Monogram ZICS360NR Bottom Freezer...
Water leaking from top of freezer into icemaker and right side of freezer. Coils, etc. are clean.
Is the water condensing and winding up in the ice maker or is there an actual leak in the ice maker water feed line?
Jul 29, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Need to find model # for ge monogram 42" side-by-side (1992?)
on the 42" Monograms the Model & serial nomenclature are usually located behind the top panel in the center section to the right of the compressor panel. Hope this helps....Bill
May 18, 2009 | GE Monogram Side by Side Refrigerator
GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
Jul 17, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
Water leak
I am having the same problem. I do have a light layer of ice at the bootm of the freezer.
Apr 01, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
Water dispenser in fridge door
Email me for the bulletin on water line freezing. Try turning on the dispenser light for 24 hours this should defrost the line.
amasuperbike@comcast.net
Jan 15, 2008 | Refrigerators
Refrigerators Logo
182 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
