Question about Janome Memory Craft 10000
Knots! hi there, i had a repair question about my janome rx18s. the top stitch comes out fine, but the stitching on the bottom of the fabric is coming up entirely knotted. i've tried changing the way the bobbin was loaded, using different types of threads and rethreading the bobbin. not sure what else to try! thanks for any help you can offer.
  • 96 Answers
Try changing the needle sometimes over use causes burrs on the end of a needle and always remember to use proper needles to appropriate fabrics. Change needles frequently to avoid unnecessary wear on the feed dog teeth
Posted on Dec 13, 2009
Having issues with my Janome 6500P with stitches since I had service
Sounds like a threading issue.
Be sure to install a brand new needle (every 8-16 hours!).
Remove the top thread completely from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning. You may need to tweak the top tension until the two threads meet in the middle of the fabric.
This should take care of your problem. If not, you may have the technician look at it again.
Remember, thread problems under the fabric are usually top thread issues. Thread problems appearing on top of the fabric are usually a bobbin thread issue (or top thread tension being too loose).
May 04, 2018 | Janome Sewing Machines
How do u end the stiching
You shorten the stitch length and either reverse a few (5 or 6) stitches or stitch forward a few stitches. Some people will stitch in place but that frequently causes a knot on the underside of the fabric. You can also tie the thread tails together (especially when sewing fine fabric like chiffon, silk, etc.) and clip the tails close to the knot.
Nov 10, 2016 | Sewing Machines
Why is the fabric not feeding forward when stitching
on the front of the machine there is a lever/knob that sets the stitch size
if it is in the middle position ,the teeth will just go up and down and not back and forward
check that setting
it is used to seal of the threads when starting to sew and when finishing
start the sew for about 1/2" then reverse the feed then go forward again to complete the sewing
at the end of the sew do the same thing again before cutting the threads
this locks the threads as a knot so that the seam will not come undone
Sep 27, 2015 | Sewing Machines
Why does my thread knot on the back when stitching in place?
Several things to try:
Pull thread tails (both bobbin thread and upper thread) straight back and when you lower the presser foot, make sure they are held down straight back. This may or may not be enough to solve the problem, but it is simple to try, and often works. You might want to hold the thread tails while you start sewing.
Use a starter--folded piece of fabric scrap about an inch long--and begin sewing oink middle of starter. Push the fabric you want to see right up to the starter and keep sewing from the starter right onto your project without lifting the presser foot or cutting the thread. When you finish sewing, cut the little piece of thread between the starter and your project.
Before lowering presser foot, use wheel to lower your needle once and then pull up bobbin thread to top surface of your project. Then hold both bobbin and upper thread tails, lower your presser foot, and begin sewing. Release the thread tails after a few stitches.
Hope this helps. Those nasty "thread nests" are a real pain.
Jul 13, 2014 | Janome Sewing Machines
Why do the stitches on the underside of the fabric look like one straight line, not individual stitches as on the top of the fabric?
This is an indication that either the bottom tension is too tight or the top is too loose. try tightening the top tension 1 number at a time till it looks good.
Jun 29, 2014 | Janome Sewing Machines
I am trying to do a rolled hem using a singer ultralock 14sh654. Do I disengage the knife? The stitches are uneven and some are quite loose no matter how much I adjust the tension. I am positive I...
no, you need the blade in place and cutting to give an even cut fabric edge. Set up for a three thread using the right hand needle, take out the left hand needle. move blade over to the right so it is cutting wide. Most overlockers there is also a thread finger you need to change on the foot, or a little lever you flick to move this finger forward into the stitching area. Check this on your manual as each make is a bit different.
If you can source it, put wooly nylon thread into the upper looper (knot it onto existing thread and just chain it through, the knot should go through the looper eye fine). Now turn the tension on top looper down so it is looser and tighten up tension on bottom looper, so needle 5, top looper 2 and bottom looper about 7.
Now test serge, the fabric cut edge should be wider than the overlocking seam so the fabric rolls under inside the stitching. Adjust the two looper threads so that this is happening, you want the bottom looper thread to nest right up against the needle stitch and the top looper thread to wrap all the way around too.
Once you've got this happening, turn the stitch length down to 0.5, to close the stitching right up. On some fabrics you'll need to adjust the differential feed too if the fabric is "waving" a bit.
Uneven stitches or sometimes loose when serging could indicate that one of the tension devices is faulting, so if this machine is not new and its doing this, it could need a service. Can you get a regular smooth three or 4 thread seam out if it???
It is always good to just recheck the threading path, make sure the thread aerial is up and that a thread hasn't got caught back on the thread stand somewhere if you're getting something wonky happening, threads stream off overlocker cones through the machine so anything wrong in the thread path will throw off the stitching.
Jun 25, 2011 | Singer 14SH654
Stitches are on the reverse of the fabric
hi! there,
set dial tension to #3 and stitch tension to #12 try on straight
sewing,check bobbins winder if thread was wind on clockwise rotation before sewing.if ok try to sew and observed the change.
have a nice day regards,dont forget to rate me
thank's
Apr 09, 2009 | Singer 7444 Mechanical Sewing Machine
JANOME RX18S
If it was sewing correctly BEFORE the needle break...why did the needle break in the first place?...and what fixes did you make?
If it sewed properly...what changed?
Cut your upper thread close to the spool...make sure the presser foot is raised and pull the cut off thread section through/out of the machine from the needle area (sewing direction...do not pull the thread backwards!)
Clean out the bobbin area...remove any traces of lint or pieces of thread...look for any broken off needle pieces... brush the bobbin area out....then add a drop of sewing machine oil (but only if your manual says to oil that area).
Remove the needle plate to expose the feed dogs...brush/clean out that area too and add a drop of sewing machine oil...then secure the needle plate back on.
Replace the needle...do it again...yup...some needles arrive bad from the factory. Make sure the needle is inserted and positioned properly. Then thread the machine WITH the presser foot in raised position. (The thread needs to get seated into the upper tensions.)
..with the.presser foot down...thread the new needle.
Oh...and use the correct needle for the thread. (a universal 80/12 is standard).
Thread can cause issues too. Try a different bobbin, or maybe a different spool of thread to see if that makes a difference.
Mar 25, 2017 | Janome Memory Craft 9500 Computerized...
Sewing Machines Logo
250 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
