Question about BSA Optics DH2060X60 20-60X60MM Spotting Scope
My BSA Deer Hunter 20-60X60 Spotting Scope has had parts come loose inside. I cannot determine anymore about the problem because I cannot determine how to disassemble it. I bought it new and fastened it on the flip-up side door of my bullseye shooting box to use during outdoor shooting matches, but have not had an occasion to use it since then because all of my shooting has been indoors with target return systems. Recently though, I wanted to shoot outdoors, and discovered that the scope could not be used because of the problem inside. The part that is loose inside has left some kind of marks on the inside of the front lens, probably as a result of opening and closing the flip-up door it was fastened to. I never heard anything happening inside the scope with the protective covers on front and back. Anything you can tell me would be very much appreciated.
5 Suggested Answers
informatica
  • 1114 Answers
SOURCE: SWIFT MARK II, MODEL 841 SPOTTING SCOPE BASE
Hi, I would contact Swift directly on this number: For ordering parts or warranty repair information, please contact Swift Customer Service at 800-523-4544. You can get other contact information and dealer locations on their website: http://www.swift-optics.com/support/faq/dealer The 'scope is mounted on a standard camera tripod thread so you can always check your local camera dealer. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 13, 2007
SOURCE: BSA rifle scope
its a metric 1.5 for the cam adjustments
Posted on Jan 15, 2008
JokerCat
  • 6 Answers
SOURCE: Need instructions for my BSA Red Dot RD 30/22 Scope
I contacted BSA and they e-mailed me the instructions!
Posted on Mar 20, 2009
SOURCE: back scope came undone-do i
Well I have never seen or had a successfully repaired one, (A scope) so i guess that says it all. replacement really and truly is the answer unfortunately.
It seems once these incredibly finely manufactured units goes out of whack, as it were, they can never be fixed properly, as I was told, "Well you can't put toothpaste back in the tune" it's best to get a new one so I did,and am happy... if you do, I have no doubt you will be too.
Posted on Jul 03, 2011
Back scope came undone-do i have to have gasses replaced or buy a new spotting scope
Jul 03, 2011 | BSA Optics
My scope is pulling down and to to the left
You might look for signs of impact damage (dropped) the rings could be bent
Jan 17, 2010 | BSA 3-9x40 Deer Hunter Riflescope
My elevation and windage adjustments aren't moving my scope. I shot 4 times and my group is 1 inch. Problem is I adjusted my scope between all 4 shots. I'm consistently shooting 7 inches high and 3 inches...
This can only be due to a "broken" scope. To be sure, you can put your gun in a vice (cushion it) and put the crosshairs on a fixed point. Without moving the gun, crank the adjustment knobs a good 10-15 clicks in one direction each, and see if the crosshairs move from where you had them pointed.
If they do not, the scope must be replaced. If they do move, perhaps you should try adjusting the scope quite a bit more between shots.
The best way to sight it in requires a helper. Fire one shot with the crosshairs on the bullseye. Then, without reloading, put the crosshairs back on the bullseye, and have a friend adjust the knobs until the crosshairs move to the ACTUAL point of impact of that shot. It is essential NOT to move the gun while doing this.
This method allows me to sight any gun in with only 2 shots (and a few for confirmation, of course). Best of luck!
Nov 23, 2009 | BSA 3-9x40 Deer Hunter Riflescope
Bsa superten problems firing
Give BSA a call at: 01494 676740 If you're not in GB, it's an overseas call.
I know it's a dumb question (maybe), but are you sure the bolt is fully advanced and locked and the safety's off?
Mar 26, 2009 | BSA Air Gun Scopes
Mar 19, 2009 | BSA Air Gun Scopes
Need more adjustment......
it sounds like the gun shop did not mount it right if rings tighten on bases from both sides it needs to be evenly tighend on both sides as for up and down some times you need to add small shim to front ring or back ring this must be done some times not much but there is times just use a index card to shim it cut to fit the ring if ya would need more help contact me back hope this helped ya
Jan 11, 2009 | BSA 3-9x40 Deer Hunter Riflescope
Nitrogen gas refilling in a rifle scope.
At a factory, the scopes are emptied in a vacuum chamber and nitrogen gas is used when the chamber is allowed to repressurize to the surrounding environment.
One possible solution is to re-assemble the scope in a clear plastic bag filled with nitrogen gas (working through the bag to re-assemble). Large plastic gloves can be taped into the sides of the bag.
Nov 13, 2007 | BSA Big Cat 3.5-10X 42mm (3.5-10x42 mm)
BSA rifle scope
Nov 11, 2007 | BSA Big Cat 3.5-10X 42mm (3.5-10x42 mm)
BSA Optics DH2060X60 20-60X60MM Spotting Scope Logo
66 people viewed this question
Top BSA Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a BSA Optic Expert? Answer questions, earn points and help others
