Question about Traxxas Toys
My summit will turn on the gears shift, the difs
My summit will turn on the gears change the difs lock and it turns. but wont drive. i didnt know if it was my controller because the last motor i had smoked and threw sparks when it stoped working this one never did so i wasnt sure if it was the motor. also where you turn the truck on the lights red. it was green before. should i just get another motor and see if thats it. is there a better motor out there that will just bolt on. cuz this is the 2nd one that burnt up on me so far?
thanks
andy
  • 88 Answers
The electronic speed control is probably bad. If you had a motor smoke and spark there was a major problem. I would also check the wiring from the ESC to the motor to make sure it was not damaged.
Posted on Dec 16, 2009
Want shift into. Hi gean
i take it is a automatic check gearbox transmission fluid or the torque converter may be at fault
Jan 24, 2016 | Cars & Trucks
Transmission is intermittenly slipping
change trans fluid & filter ! important you do this ! very low fluid level ! if it doesn't improve, torque convertor and maybe pump is shot !!!!!!!!!!!!!!need rebuild, for the price of a rebuilt trans,, JEG'S.COM , OR SUMMIT RACING.COM will give you a new one !check it out !
Mar 08, 2013 | 1998 Chevrolet Blazer
I have a 2005 tahoe 2wd it has 96000 mile on it i started it up yesturday and put it in drive it act like it didnt wont to go like it was in second instead of 1st i wnt down the road and it didnt wont to...
Has the transmission fluid and filter been changed in it in the last 50,000 miles.Sounds like you have some shift solenoids sticking.Change fluid and filter
Apr 20, 2011 | 2005 Chevrolet Tahoe
Rear on a2004 astro van awd v-6 locks up when making turn's left or right.but does'nt do it when gowing forward or reverse.
Rear end is a lockup dif. This couples both wheels.It has clutches that allow inner and outer weels to turn at different speeds when going around corner, thus eliminating most tire scrub. If noise is coming from dif. change dif oil and redress clutches.Driving in a straight line with a lockup dif. would not normally be noticed,because both rear wheels are travelling at the same speed.
Sep 09, 2010 | 2004 Chevrolet Astro
Hello, so I'm trying to better understand failing cv joints and how it can affect front differential on a front drive SUV. I read an article that when cv joints go bad it can affect the front differential...
First I think you read it wrong ,that Front WD suv have locking dif..they don't , it locks at the transfer case at the tranny and only on All Wheel Drive SUVs. And then it only transfer more power from back wheels to front wheel. The dif are open dif. means the power goes to the wheels with least resistance or limited slip dif. that transfers power to slower turning wheel. Yes max. load is at full lock and high speeds and yes it does damage over time (wear out), less at lower speeds. The symptoms of a failing cv is knocking while turning.
Jan 20, 2010 | 2007 Nissan Murano SE
1995 crown vic gear problems/gear shift wont lock
most likely the shift tube bushings are bad- you may have also lost a few screws in the shift tube or they could just be loose. you have to pull the steernig column down to inspect/repair it.
May 30, 2009 | 1995 Ford Crown Victoria
Will not shift
neutral safety switch in console jammed, not releasing handle to change gears.
Apr 29, 2009 | 2005 Infiniti G35
Toys Logo
180 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
John mullen
gbob59
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
