Question about Arris SURFboard SBG900 802.11g/b (motosbg900) Wireless Access Point
Wireless router slow connection - Arris SURFboard SBG900 802.11g/b (motosbg900) Wireless Access Point
  • 115 Answers
To ensure that you are getting the most out of your product you should read the official manual. I would keep it away magnets and thick metal. Every wall that your wireless router must go through weakens the signal. Keep your wireless router in an open atmosphere and away from the ground, preferably.
If your signal is still weak you can take the intenna off and place it back on, but in a much tighter and closer fashion. Try unplugging your router, waiting a few moments and then plugging it back in.
Your router should then have a much stronger and much faster signal. If you still are having problems, feel free leave a comment.
Thanks,
Brandonmxb
Posted on Dec 15, 2009
Slow internet speed when connected to router
So, If you have internet connection speed problem with your wireless try with the following steps,
1.)Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from www.ScanMySpeed.Com before and after following these steps.
Jan 26, 2013 | Linksys WRT54G2 Wireless Router
Slow wireless connection
I think you can try to upgrade the firmware on the router.
Connect one compute to the router and download the firmware of the router.
Open the setup page and upgrade the firmware.
See How to upgrade firmware on the router
After upgrading the firmware reset the router and reconfigure it manually.
See if that helps you.
Watch video: How to reset linksys router
Feb 12, 2012 | Linksys WRT300N Wireless Router
Very slow connection speed
Basically the Wireless Internet always slow compared to wired ,also You can use the instructions in user manual,or get that from Online and then connect to Laptop,check any signal problem in wireless router ,better call the ISP to connect it,they will assist you,You can check the speed of the internet at here Scanmyspeed.com it will show Good Speed.
Jan 16, 2012 | Computers & Internet
My internet connection is slow. wireless home network setup connected to adsl.
is it as slow as when you connect it from the router(not the modem) to your pc with a wire instead of wireless? if so its bc adsl is slow in nature and you may need a filter adapter going into your MODEM first
Mar 25, 2011 | Linksys Wireless-G WRT54GL Router
Very slow connection speed, drops connection &...
which ever router or device u r using for the wireless connection , plz upgrade the drivers for that or u can even visit the website for that product an u will find the details there as well ....
May 20, 2010 | Linksys WRT160N Wireless Router
The wireless network is very slow compared to when I connect to one of the RJ45 ports in the back of the router. Every wireless connection I try crawls in speed. I have Wireless -G USB adapter in one...
Makesure your computer is not too far away from your wireless router andyou have a good signal. By placing your mouse pointer over the wirelessconnection icon, located in the bottom right corner of your taskbar, you cancheck to see if your signal strength is good. Anything less than a good signalcan cause intermittent connections.
SOLUTION:You will need to relocate your wireless router closer to your computer.
Dec 16, 2009 | Linksys WRT160N Wireless Router
My router gives two wireless connections
go to the router page in that you got the wireless option in that just reconfigure it the device then you get the one wireless connection
May 13, 2009 | Arris SURFboard SBG900 Wireless Router...
I turned off everything overnight, turned it back on in the morning, "WALLA" like magic everything worked. Thanks
Nov 26, 2008 | Dell TrueMobile 2300 Wireless Broadband...
Linksys to homeportal
In order for you to make the linksys wireless router and the homeportal 1100 to work together they should be connected via CAT5/ethernet cable, you cannot connect them wirelessly...
Oct 26, 2008 | 2wire HomePortal 1100 Router...
Slow connection
Your slow connection could be affected by poor location wireless router (therefore poor signal strength), electrical interference, or even someone else with a wireless router transmitting on the same channel as your wireless router.
Try relocating your router away from solid walls, and/or move your computer or router to another location.
If your connection speed varies, could be electrical interference with appliance/s in your house, turn off all appliances, test your internet speed connecting then turn on one appliance at a time to determine which appliance is at fault (could have a faulty capacitor in the appliance)
Jul 24, 2008 | NetGear MR814 Wireless Router
Arris SURFboard SBG900 802.11g/b (motosbg900) Wireless Access Point Logo
274 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
