Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Bissell 1699 does not press against the carpet. The brush rotates but does not clean my berber carpet since it only lightly touches it. There must be a tension belt or spring I am missing. Help
  • 701 Answers
Well here is a link to the manual. Hope it helps!
Bissell ProHeat Manual
Posted on Dec 13, 2009
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
It won't move forward. it turns on but drags when going forward will go backward smoothly.
On the front of Carpet claner is the clear part that pulls the water back up. It may have come apart. this will cause it to catch, unplug the cleaner, remove all the cleaners and water container, then , lift up and look at this part, If it has a large gap it has come apart.
Mar 24, 2010 | Bissell 1699 ProHeat Clear View Upright...
I have a bissell proheat turbo2x the brushes wont rotate checked for blockages none to be found can anyone help
The belts are probably broken, stretched or worn. I would try replacing the belts if you haven't in a while. You can get the belts you need here:
Bissell 1699 Replacement Belts
Nov 09, 2009 | Bissell 1699 ProHeat Clear View Upright...
My bissell 1699-n is dragging or catching on the carpet
Hi
Please check this user manual which will explain you about the complete information on your vacumm cleaner.
Bissell 1699
Please do accept the solution and revert for any further assistance.
Thanks
Rylee
Mar 25, 2009 | Bissell 1699 ProHeat Clear View Upright...
Power Pro Bissell cleaner
Try going a diferent direction. Burber carpet is extreamly hard to clean because the nap it causes vacuums to bounce and shampooers to catch. just try using a differnt angle to shampoo the carpet from.
Oct 13, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1699 ProHeat Clear View uses very little soap.
The valve at the bottom of the soap tank may have gone bad, Also try running a mix of water and vinegar(not on carpet) to see if it will clean the system out. The system may just need cleaning out.
Jun 06, 2008 | Bissell 1699 ProHeat Clear View Upright...
Need help putting back together
With out seeing it, it will be hard to figure out what isn't right. Must be a different model then 1699. which model is it?
Nov 08, 2007 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
130 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
