Question about SanDisk Memory Media
Locked memory card
How do I unlock my SanDisk memory card? The slider button is there but even when I slide it away from "lock", my camera still shows it as memory card error, card locked.
  • 2 more comments
  • andyj1991 Mar 12, 2008
    i flip the lock button up but it is still locked. i need help plz
  • Anonymous May 31, 2008
    removed card
  • Anonymous Jul 22, 2008
    it dont have an lock and unlock mark on it
  • ankitsingh07 Jan 25, 2009
    k
    Please describe the specifics of your problem below. We'll add
    your post as a comment to josjos's locked memory card problem, and notif
    your post as a comment to josjos's locked memory card problem, and notify you when a new solution is offered.
    your post as a comment to josjos's locked memory card problem, and notify you when a new solution is offered. y you when a new solution is offered.
  • 94 Answers
Hi
the unlocking is due to digital camera and not due to card. card do not have any locking feature. checkup on camera password
or alternately ask replacement fm company as this as 5 yrs warranty
Posted on Apr 03, 2008
I have the same problem... it says card locked but its the camera doing so with no optiob for a sd card
Posted on Jul 03, 2008
  • shottz Jul 03, 2008
    nope mine is in my pc right now... and when I do put iit back in my cam i still receive the msg
  • 3 Answers
You can ty to unlock it then put it in a computer that has a card reader and format it using a computer that should confuse that camera to accept it again
Posted on Jan 26, 2008
Memory card locked
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Feb 08, 2013 | Samsung S860 Digital Camera
I have sony cyber shot it said your memory card locked when we click on shot button
SD and Micro SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Aug 28, 2012 | Sony Cybershot DSCW350 Digital Camera
Card locked error on samsung es80
Turn off the camera and remove the memory card.Most cards have a lock slider at the side.You have to slide that button downwards/upwards to unlock it.Slide the memory card back into the camera.
Turn on the camera.
Hope this helps.Thanks!
Please rate this answer.
Oct 28, 2011 | Samsung Cameras
My readout says "card locked"
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 13, 2011 | Polaroid Cameras
4GB Sandisk is write protected; I don't know what I pushed to do that, but now I need to unlock it so I can use my camera. Please help
On the side of the SDHC memory card is a sliding lock I have a diagram to show where this is and which direction to push the slider. Here is the diagram.
Also to make the SDHC work compatible with your camera you need to format the memory card. Each time you download the picture files the memory card needs to be formatted, never format in the computer and expect the card to work in the camera.
Dec 27, 2010 | SanDisk 4 GB Standard SDHC Card with Rezo...
SanDisk 1GB Card is locked
There is a little slider on the right hand side of your memory card. If the slider is towards the bottom of the card the card is locked. When the slider is towards the top of the card your card is unlocked. So all you need to do is to slide the little slider towards the top of your memory card.
Regards, obliqueridge
Nov 12, 2010 | Kingston 1GB Secure Digital Memory Card
I need to unlock a Sandisk SD card, I've just
If you've already tried the slide switch, see this link for additional things that you can try.
Mar 18, 2010 | SanDisk 2GB microSD Memory Card
Memory card is locked. Where is the lock?
This is usually caused by the SD card, and is nothing to do with the camera. On the SD card there is a small slider - which allows you to lock the card (to prevent accidental erasure).
If you put in on the table with contacts upwards, corner cut top left, then the slider is on the right hand edge, about 1/3 the way down. If it is slid to the top position (nearest the contacts) the card is unlocked. If it is slid down (away from the contacts) the card is locked.
If it is a damaged / "cheap" card, sometimes the slider falls out, in which case the card is locked. You can still read from it, but not write to it until fixed or replaced.
First check is to turn the camera off, remove the card, move the slider to locked, then back to unlocked. Replace in the camera and turn on.
Mar 02, 2010 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Locked memory card
I guess it is a simple switch problem..
try to switching it between lock and unlock many times until it become ok again..
If it will still not unlock itself, try to format it, for some errors to erased and starts a new one.
Jan 20, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Electronics - Others Logo
311 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
