Question about JustCom jc-102cp 2-port KVM Switch
What are the keys I use to switch between the 2 computers?
    New Friend:
JC-102PC 2 port KVM Switch with AUDIO Commands
Switch to PC 1 Scroll Lock + Scroll Lock 1
Switch to PC 2 Scroll Lock + Scroll Lock 2
Previous Active Port Scroll Lock + Scroll Lock Up Arrow
Next Active Port Scroll Lock + Scroll Lock Down Arrow
Switch Audio to PC 1 Scroll Lock + Scroll Lock F1
Switch Audio to PC 2 Scroll Lock + Scroll Lock F2
Auto Scan Mode Scroll Lock + Scroll Lock 0
Change ALL to PC 1 Scroll Lock + Scroll Lock A 1
Change ALL to PC 2 Scroll Lock + Scroll Lock A 2
Posted on Apr 15, 2014
  • 98 Answers
Press the Scroll key twice
Posted on Dec 20, 2009
Reset computer yamaha mt-01
As far as I know, all encryption is carried in the master key. You got 2 keys + one RED key. Remove key from the bike, switch on USING THE RED KEY, let it go through the check routine, start the bike and switch off.
Remove red key, insert normal key and restart the bike using the normal key.
Option 2 would be to FIRST remove the master fuse situated above the battery (or disconect battery) and then repeat above procedure.
Hope this help
Aug 09, 2014 | 2006 Yamaha MT-01
Hi, I can't remember what buttons to push on my keyboard to switch from one computer to the other with my belkin 2 port kvm switck? can you help me, Ive just set up the system in another office. Thanks...
Short answer:
There are two ways to switch from one machine to the other with the keyboard
1. Press Scroll Lock key twice, then the Up or Down arrow key.
2. Press Scroll Lock key twice, then enter 01 or 02.
Long answer (from the manual posted at www.belkin.com):
You can select which computer to operate by either the front-panel push button
located on the top of the Switch or through hot key commands. Note that it will
take 1-2 seconds for the video to display after switching. This is due to the
refresh of the video signal. A re-synchronization of the mouse and keyboard
signal also takes place. This is normal operation and ensures that proper
synchronization is established.
You can conveniently change ports on the Switch through a keyboard command
sequence using the "SCROLL LOCK" key and up and down arrow keys. To send
commands to the Switch, press the "SCROLL LOCK" key twice within two seconds.
You will hear a beep for confirmation. Then you can press the up or down arrow
keys to switch between ports.
You can switch directly to any port by entering the Switch port number you wish
to use. For example, if you press "SCROLL LOCK", "SCROLL LOCK", "2", the
computer on port 2 will be selected.
AutoScan Mode
In AutoScan mode, the Switch remains on one port for eight seconds before
switching to the next. This time interval cannot be changed.
To enable AutoScan mode, press "SCROLL LOCK", "SCROLL LOCK", "S".
Note: There is no mouse or keyboard control in this mode by design, in order to
prevent errors. If it were enabled, the user could move the mouse or use the
keyboard while the KVM Switch is switching to the next port. This could interrupt
communication between the computer and Switch that might cause erratic mouse
movement, or result in errant display of characters when using the keyboard.
To disable AutoScan mode, press the space bar.
Feb 05, 2011 | Computers & Internet
How do I switch between computers using old Belkin 2-port KVM?
if i remember right, hitting the scroll lock key twice, and then pressing 1 or 2, depending on which box is your xp box.
hope this helps
Feb 16, 2010 | Belkin F1DK102P 2-port KVM Switch
Hi how can i switch computers using Belkin
Try tapping the scroll lock key twice and then the up or down arrows, or tapping the scroll lock key twice and then the "s" key to auto scan.
Dec 05, 2009 | Belkin F1DK102P 2-port KVM Switch
All Keys do not work on keyboard with KVM switch
GCS632U is designed to work with standard USB keyboard an mouse only. You have to make sure that you are not using any type of adapter such as PS/2 to USB adapter. To further isolate the problem, please follow the steps below:
1. Connect the USB keybord directly to th computer to make sure that the keyboard is working properly.
2. Make sure that the keyboard is connected to the keyboard port on your KVM switch. You may take a look under neath this GCS632U (near the USB ports) and you will see an icon where to connect the keyboar and mouse.
3. If you're still gettings the same problem, Try power cycling this kvm switch by disconnecting if from the computers and disconnect also the keyboard and mouse from the KVM switch and leave them disconnected for a minute or two.
4. Reconnect everything after two minutes and then reboot the two computers.
5. If same problem exist, try using different USB keyboard.
NOTE: This KVM swith does not work correctly with wireless, gaming and smart keyboards because it's designed to work with standrd USB keyboard only.
Mar 23, 2009 | IOGear GCS632U 2-port KVM Switch
WHAT KEYS
The toggle key on your keyboard for changing from one computer to the other is the Scroll Key. You press the Scroll key twice. It will switch from computer # 1 to computer # 2.
Nov 02, 2008 | StarTech.com SV211MICRO (0065030795418)...
KVM hotkey
Hold down the Scroll Lock key for several seconds. The switch should beep briefly and blink. Hit either the "1" or "2" key on your keyboard to switch to the corresponding computer connection.
Jun 23, 2008 | LinxCel PS-121D 2 Port PS2 KVM Switch
KVM 2 PORT SWITCH
Yes try uninstaling the kvm switch reboot pc's install the kvm again and try another key and see if that works
Jan 29, 2008 | JustCom jc-102cp 2-port KVM Switch
JustCom jc-102cp 2-port KVM Switch Logo
591 people viewed this question
Top JustCom Computers & Internet Experts
David Payne
David Payne
Are you a JustCom Computer and Internet Expert? Answer questions, earn points and help others
