Question about LG Washing Machines
Last night the WM2077C washer showed a LE error.It did finish washing the load aftwer stopping and restarting. Today the breaker tripped supplying the power, reset the breaker and the machine does nothing, like it has no power. Outlet has 120v available. thoughts?
  • 1 more comment
  • hdrock206 Dec 12, 2009
    tbird,
    I'll pop the back cover off and check your recommendations. Unit does not even light up when the power button is pressed. Wondering if there is a reset of some type?
    thx
    rockettman
  • hdrock206 Dec 13, 2009
    Thank for the pointers, popped the back cover and the lid off. checked all the connectors. power is available at the source. no power or lights at the controls.
    time for a service tech?
    I see the relay on the main incoming power board. the same board that has the chokes on it. going to give this project a rest for the night.
    mucho thx
  • LG Master
  • 3,051 Answers
Hello there:
this LE means this
LE Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective.
Posted on Dec 12, 2009
Testimonial: "Tech tips were very helpful. Ran out of time on my end. Would highly recommend tbirdfan1 to anyone. more later...."
  • 2 more comments
  • Michael Thomas
    Michael Thomas Dec 12, 2009
    You may be able to also unplug the unit for 45 minutes and leave it alone then plug it back in and see if this error wil reset it'self ok somtimes this has helped me in the past but no powere is worring me
  • Michael Thomas
    Michael Thomas Dec 13, 2009
    hello again also here are some more things to check
    there is a relay for the start switch that will fail and when it does
    it will shut down the entire control panel What the repair men do to
    test this is to bypass the relay and using a small jumper wire with
    aligator clips on each end of the wire and 9 out of 10 time the machine
    will come back to life. Then they replace the relay by rewiring in a
    new one about a 25 dollar part and they charge youabout 100 dollars for
    the service call so what yo might want to do is to trouble shoot the
    start switch relay circuit ok? and save your self alot of money in the long run by repairing this your self.
    Also check the door switch to see if it is any good ok
  • Michael Thomas
    Use the free web link below to troubleshoot your problem.you might be able to narrow it down to to two faults. Stator Assy or Main PWB Assy. Good luck
    just copy and past the below into google
    http://136.166.4.200/contents/Laundry/WM...
  • Michael Thomas
    ok no problem please do me a favor and give these soulution a rating for me it helps me so i can continue to help you
My name is raza. i have west point washing machine model no 1225tl , Fix error LE is coming. please tell me about this urgent.
An LE error code on the washer's display indicates that the motor is locked, possibly due to a heavy wash load.
Large and heavy sized loads will put a strain on the motor, causing the LE code to occur. Performing a reset on the washer will normally resolve this error.
To reset the washing machine:
  1. Press POWER to turn the washer off
  2. Unplug the washer from the power outlet. If the outlet cannot be reached, turn the circuit breaker to the unit off.
  3. With the power disabled to the washer, press and hold the START/PAUSE button for 5 seconds.
  4. Plug the washer back in, or turn the circuit breaker back on.
The washer should now be reset and the LE code cleared. If washing a heavy or large load, reduce the load size and attempt to restart the cycle.
Note: For your safety and to preserve your warranty, if the issue persists, LG recommends that all repairs are performed by an Authorized Service Center.
Jan 06, 2017 | Washing Machines
I have an LG wm2277hs washer, started to flash LE code now it will not power up
Le error is a motor error code. The motor error could be caused by several things including : motor, bearings , rps sensor and wiring and in some cases all. continued use with this error could have taken out your mother board.
I’m happy to assist further over the phone at https://www.6ya.com/expert/donald_a8261495ff0777e2
Dec 13, 2015 | LG Washing Machines
Frigidaire affinity washing machine E30 error message
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Nov 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
We finished a load of laundry and noticed it was still pretty damp after the wash had been completed. Upon attemping to do another load the washer will no longer work at all...Bit of a problem here any...
Are there any error codes at all displayed on the screen? Basic troubleshooting for this unit will be first to check to make sure the circut breaker is not tripped in the main breaker box, make sure if you have any GFI power outlets in the home that they are not tripped (they are normally near sinks or in bathrooms and have the "test" and "reset" buttons on them. They can sometimes be wired into a nearby washer outlet.) Make sure to not use any extension cords on the washer, and last of all unplug the washer for a few mintues and plug it back in to see if that will reset it. Sometimes unplugging it can reset any errors. Please repost if this does not fix the problem or if you find any error codes.
Mar 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Model LGWM2277H purchased 2005 - Since 3/19/10 LE Code Continues
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jul 18, 2010 | LG WM2277H Front Load Washer
LG Tromm WM2277H washer won't start after tripping breaker
no fuses only control boards.with power off pull the top off and check wires at your power supply board(not the one with buttons). Look for burn or damaged wires. no luck with that, will probably need power board(usually the board that goes out). Call LG and speak to cust service....sometimes will cover the board.
Jun 11, 2009 | LG WM2277H Front Load Washer
Washer
Product Laundry Washer
Symptom Error Codes
Sub Symptom LE error code
Question Locked motor error code.
Answer
LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | LG WM2277HSW XL Front Load Stackable...
LG WM2277HW washer LE error
I was also having the LE error problem. I tried removing the unpumped water , tried re-running the load etc....... then I decided to try something else.... just like we have to restart our computers, I thought about resetting the washer so to speak......not sure if it is fixed, I am going to try running another load, but, I UNPLUGGED THE WASHER, LET IT SIT FOR ABOUT 10 SECONDS, THEN PLUGGED BACK IN.... AND THE WASHER WENT THROUGH A CYCLE AND FINISHED.
Jun 15, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
172 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
