Question about Maytag MMV4205 Microwave Oven
How many micro wave ovens will a 20 amp circuit support?
A six-bedroom house is being converted to a boarding house. Tenants will probably want to have micro wave ovens in their rooms but multiple bedrooms are on one circuit leading to a possible overload.
  • Maytag Master
  • 8,404 Answers
Please stick with me to the end ... some examples are for example only. There is no 1000 watt circuit per'ci.
This will not be possible overload, this is an accident waiting to jump on you, my friend
Install dedicated circuits for these ovens, my friend. It will cost you a little but will be better than having dissatisfied guests or talking to the zoning board or boarding house authority or (gasp) the fire inspector after the fire.
If you don't do this, when the breakers start flipping off, tenants will run extension cords to outlets that have power. A whole different and worse, problem!
Rule of thumb, lighting circuits should be designed to operate at 80%, for example, if you have 800 watts of lights on a 1000 watt circuit, you are at the max.
So, there is a possibility that your circuit for lights is already near max. Adding ovens is trouble. Don't forget the iPOds and cell phone chargers as well as lap top chargers, walkman chargers (older students), little TV's, DVD players, clock radio's, electric shavers, curling irons, steamers, popcorn makers, lava lamps and occasional electric heaters that will be snuck into the room.
What is a 1000 watt circuit ... good question. Ohms law comes into play here.
Volts X Amps = Watts
120 volts X 8.333 amps = 500 watts (a smoothie blender) 300 watts (slow cooker) 200 watts (hand mixer) = 1000 watts.
A 15 amp circuit will protect #14 wire and can carry about 1800 watts (a toaster (1500 watts), for example).
A 20 amp circuit will protect #12 wire and can carry about 2400 watts (i am using a big paint brush here. these numbers are pretty close but not exact and I am not a licensed electrician.)
When I wire, I aim lots lower, preferring to OVER build than to under build.
10 amp circuits are rare in modern homes. In general practice, if the need was to be protected at 10 amps, the wire used in the circuit would be #14 and it would be protected by the breaker at 10 amps. In this case, it is the device plugged into this 10 amp circuit that needs protection rather than the #14 wire (which would be technically oversized)
Another consideration for you is where is the water? If you have an outlet that is 5 feet from a water source (bath - kitchen - etc) it must be protected by a GFIC
A 30 amp circut will protect #10 wire --- but this is not a normal household circuit.
Maybe the best option is for you to have your electrician install a sub panel in the vicinity of use and run several 20 amp circuits from that location to the various rooms.
The answer to your question "How many (1150 watt)micro wave ovens will a 20 (amp circuit handle)" is TWO with nothing else on the line. The National Code requires dedicated circuits for micro wave ovens, BTW. A commercial application may have a different (more stringent) standard in your town.
Thanks for the opportunity to answer your question and thanks for your interest in FixYa.com
Please vote - positive comments appreciated by volunteer question catchers.
thanks
a
Posted on Dec 13, 2009
  • 581 Answers
Each microwave will tell you (probably on the back near the serial number the amount of amps each will use. If not divide the number of watts by 115(volts) or 230(volts) depending on which voltage the appliance uses. The answer will be the number of amps used by the device.If volt * amp = watts perhaps you can take the wattage of a microwave and divide by your voltage at home (120 in North America) to get amps.
Lg micro wave turns on but doesn't heat
A word of caution.......if you are familiar with microwave ovens, you know how to discharge the big capacitor in the seconday-circuit, and what can happen if you don`t! BE CAREFULL!
If your microwave oven runs normally, but won`t heat, suspect a primary-circuit fuse. Always replace with a fuse of the same voltage and amp rating. Also, check all electrical connections. Again, be sure to discharge the big capacitor so as to avoid dangerous shock.
Another common problem and simple check is the power diode. Simply check for continuity. If you get continuity in both directions with a volt-ohm meter, replace the power-diode.
If you have the proper meter, check the secondary-circuit capacitor. The capacitor can be a little pricey if it is bad.
If that doesn`t do it, the problem is likely the primary-secondary transformer. Unfortunately, the cost of the replacement part is probably more expensive than buying a new microwave oven.
Mar 03, 2015 | LG Microwave Ovens
Blowing breaker
In general house hold circuit breaker of the house is 15 Amps or 20 Amps.
Either you have defected (weak) circuit breaker and wiring or bad Microwave oven.
The 99.99 % house hold Microwave ovens pull less than 15 Amps. They may have internal ceramic 15A fuse or 15 Amp internal circuit breaker.
To isolate your problem:
1. Plug your Microwave oven to different areas (different electrical circuit) if the different circuit breaker still trips... your Microwave oven has a short - Most of them has a small ceramic fuse 15 amps fuse.-also check some inter lock switches at door .
2. If the Microwave oven works Ok then you may have:
2a. You may overload the existing electrical circuit, try to unplug some other appliances
2b. You may have bad electrical outlet receptacle (Replace it with the same type , - may need helps from licensed electrician)
2c. Weak or defect house hold circuit breaker. (Replace it with the same type , brand - may need helps from licensed electrician)
Jan 24, 2014 | Goldstar Microwave Ovens
Where are the fuses in my microwave oven,?
Inside behind the display panel on a small circuit board.
Jan 01, 2013 | Magic Chef MCO160UB Microwave Oven
Microwave sometimes heats up food and sometimes it does not.
usually when you kill the power and then when you put power back on the machine works it's the computer board that's bad.all you're doing is resetting the board just like your house computer,if something happens to it you shut it down and reboot it,that's what you're doing with the micro wave just rebooting the board.here's the funny thing about micro waves sometimes the part you're gonna change is almost the same price as a new micro wave so i would first check how much the board is,i went on sears and they have the board for 115.00 repair clinic for 235 part number WPW10216347 they don't make this model anymore but you can get a stainless micro for around 290 to 300 dollars and if you buy the same brand all you should have to do is remove the bolts up above that hold it in place and remove the micro wave and the same brand should mount the same way so you won't have to drill new holes or replace the back metal panel.if i were you i would replace the unit instead of the board repair clinic shows most of the parts for this model out of stock so it might be a while before you can get any parts for this model but this is up to you.good luck with your micro wave.one more thing when you were in there did you see alot of grease,this is usually the cause of no heat,the grease from cooking on the stove top gets into the micro wave and on the mag tube and damages it,if there was grease in there i would just replace the unit
Dec 15, 2017 | Whirlpool WMH2175XVS Stainless Steel 1000...
Try2910227 serial ywmh2205xvb-0 model arcing on the back corner were the rack sits.Is there a way to repair this seen is the unit was purchaced in June of 2011.
Yes, take the rack out and recycle it. I do not know why these micro-wave company put racks in the micro wave ovens. You get some insulation on the inside the micro flaking off next the rack.
The mega-tron tube is a very high energy transmitter. The energy will come out of the top inside the micro wave oven in a wave guide. Micro wave energy that generation by the tube is high frequency into Gega Hertz. You have a metal tray in side the micro wave acts like a big capacitor it stores energy in form of heat the next you know it look like Marconi is putting on a lighting display.
Leave the wire tie on a loft of bread and put in you micro wave oven to defrost. The next thing you might see is a load bread burning, instant toast. ----The use of micro wave were invented by the British before WWII. The mega tron tube generation very high frequency radio wave and these wave struck an object 100 miles away some of this beam energy would balance back to a receiver-----You have Radar.... I wish you and your family well being and be careful of micro wave ovens it can burn from inside out. GB you...stewbison
Aug 22, 2011 | Microwave Ovens
Micro wave will not heat has a picture of a little micro wave on the screen
Either the power board to supply the magnatron or the magnatron is defective.
Check or have someonr check the output of power supply. If ther is a hi reading, then change magnatron
Aug 05, 2010 | General Electric Microwave Oven
Oven appears to function normally but doesn't cook at all.
With micro waves, this could be a number of things. They are hard to diagnose using this forum but I'll try. There are three things you can check. One being the thermal fuse. On some models, when it goes bad it put some things out. with others it puts every thing out.
if it's good, check the mag tube (Magnatron). Most of the time, it will be burned on the end if it's bad. tube. The last thing would be the fuse. It is made of ceramic and is a 20amp. It looks like a old round car fuse but it's not. It's made just for micro waves. Honestly, if the thermal fuse and the round 20 amp fuse is not the problem, you may be able to replace the micro wave cheaper than replacing the parts.
Thermal fuse $28.99.
Round 20amp fuse $1.53
Transformer $100.00.
Mag tube $87.00
Capacitor $45.00
Go to www.appliancepartspro.com and enter your model number. This will pull up every part in the micro wave and their prices. Then you will ba able to decide if you want to replace the parts. With yours being one that's built-in over the stove. These cost more and are worth putting more into. If I can help any more comment back and I'll do what I can.
Please rate solution
Sep 07, 2009 | Maytag MMV5186A Microwave Oven
Microwave comes on but doesn't heat ge.jvm1540
In the case of microwave ovens, the commonly used radio wave frequency is roughly 2,500 megahertz (2.5 gigahertz). Radio waves in this frequency range have an interesting property: they are absorbed by water, fats and sugars. When they are absorbed they are converted directly into atomic motion -- heat
So, NO Micro waves NO heat......... Need to check for Microwave emitter device installed inside.
Sep 11, 2008 | Microwave Ovens
I have a sharp micro wave oven. Occasionally, when some foods are cooked or heated, you can see small bursts of blue flame. What I should do ? I only use microwave safe containers.
You probably have a burnt wave guide cover. Look inside the microwave either on the side or on the top, it's a square piece of mica board, and you should see a burnt spot on it. You should be able to replace it fairly easy with the model number I can check on a replacement for you.
Jul 09, 2008 | Sharp R-220HW Microwave Oven
Maytag MMV4205 Microwave Oven Logo
385 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
