Question about Linksys Wireless-G WRT54G Router
I can connect through my modem but not modem and router. I have reset the router multiple times and tried everything else i can think of, but still nothing... any help?
Perhaps your modem has a router built in. What brand of router do you have?
Posted on Dec 12, 2009
No internet
I had exactly the same problem with my EnGenius ENS202EXT. I was trying to set up an Access Point, hard wired to a FAST1704N V1.0 Router/Modem from Windstream communications.
I spent 2 days trying/altering as many different combination settings as possible, on the Engenius. It turned out in the end that I had alter an unnecessary setting in the Fast1704 modem/router. After I reset the modem to factory settings everything worked beautifully. I have great coverage and higher speeds than I ever had before.
Note: in addition to the fact that internet would not pass through to the Access Point I was trying to set up, neither would the FAST1704N V1. show up on the internal network. I could not find or communicate to the FAST1704N V1. through my own network until I reset my modem/router. After resetting the modem and getting internet through the AP, I went back an readjusted the critical settings in the modem. Everything working great.
Oct 10, 2013 | EnGenius ENH202 Wireless Outdoor 800mW...
Wireless security
I think you should upgrade the firmware on your router.
After upgrading the firmware reset the router and reconfigure it manually.
I will also suggest you to create a new wireless network and use security modem WPA.
Try to connect to the new wireless network and see if that works.
See linksys router setup
Watch : How to reset Linksys router.
Jan 25, 2012 | Linksys Wireless-G Broadband Router
When I first started using this modem, it worked great and easily worked well with my Belkin router. One day when I came home, the modem was only flashing the "power" light was flashing and I had...
Flashing power light on Router is sign of hardware failure As mentioned, you have already reset the router
You can try to hard reset the router one more time
Follow this procedure
1. Press the reset button with some paper clip 2. Wait for 10 Secs 3. Turn of Power to the router (While Reset button is still pressed) 4. Wait for 10 secs 5. Power on router 6. Wait for 10 secs and then release the Reset button
While doing this make sure reset button is pressed continuously start from Step 1 - 6
Check if Power light still blinks
If No - you can setup router like before and it will work If yes - Buy a new router or get it replaced if under warranty
Jun 29, 2011 | Arris SURFboard SB5101 Cable Modem
Tried to upgrade firmware. It accepted everything, I can connect locally through wireless. But the "Internet" status is constantly set on "Disconnected". I have reset the router,...
did you put the modem in bridge mode?
try plugging computer into to the modem to see if the internet is working
then add router to see if it has internet at the router. try pinging the router and the modem
Jul 04, 2017 | SMC Barricade g SMCWBR14T-G Wireless...
Modem will connect to router but not to computer
This is mostly because it has not adapted to the changes when using another device aside from the router, especially a router. What I have done with internet modems is when you are removing a router, or if you are installing a router is allow that modem to be shut down for about 10 - 20 minutes before you use other devices it does not recognize right away.
May 05, 2010 | Toshiba PCX2600 (c40054) Modem
Not connecting to internet
You will need to reset your modem or have your internet service reset. When you have a PC connected directly to the modem the modem locks on to the NIC MAC address and will not assigin a pubilc IP address to the Linksys router until the modem is reset. I hope this helps.
Apr 13, 2010 | Linksys Wireless-G Broadband Router
Belkin F5D7230-4 not working anymore?
Well i think u r right, u must contact to Belkin support team (http://www.belkin.com/support/) or to from where u buy this. If router is in warranty period then u will get replacement.
Mar 21, 2009 | Belkin (F5D7230-4) Router (587009)
Browser and email continuously won't load
I would have to say this is a problem with Comcast, call them and ask for a line test, tell them that you are having this problem on multiple computers, and you have even tried connecting directly to the modem. If they can run a test on the line, hopefully that will shed some light on the issue.
Often times with Cable/Phone companies, the right hand doesn't know what the left is doing, be instant that they check, at the very least they can check connection to your modem from their end.
Mar 12, 2009 | HP Pavilion A255CB PC Desktop
Connection Issue ~ D-Link DI 514
Connect to your router, then on the computer click start/run, type CMD at the >, type ipconfig /release, then ipconfig /renew this will reset all ip address from your computer through your router to your modem. this should fix the problem. BPCS
Dec 30, 2007 | D-Link DI 514 Wireless Router (DI-514)
Linksys Wireless-G WRT54G Router Logo
62 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
