Question about Oster Kitchen Appliances - Others
The paddle will not stay in the machine and the water leaks out
  • 433 Answers
The sealed bearing at the bottom of your bread pan has failed. There is no fix for it. You will need to hunt around for a new bread pan. Check ebay. (My pan failed also, and the pans on eBay were about $30.00. I bought a brand new Sunbeam at Walmart for just under $50.00. Oster and Sunbeam are the same). Good Luck...Hank
Posted on Dec 14, 2009
Testimonial: "Thanks"
Maytag clothes washer Model LAT6910AAW. leaks at the last cycle when the rinse water is drained. it may be the drain pump, except it doesn't leak when the wash water is drained (2nd cycle)
If your machine has a tray that you put softener in, softener is the last thing added at rinse time. If it is plugged or has a leaking supply hose, this would cause water paddles and appear to be related to the drain cycle.
Feb 17, 2017 | Maytag Washing Machines
Dose the paddles that mix the bread stay attached while I bake the bread?
Best Bread Machine Reviews has a lot of articles about bread machines, all of the models on there have paddles that do indeed stay attached, but they can come off for cleaning.
Aug 03, 2014 | Kitchen Appliances - Others
Drum paddles replace
Assuming the paddles are attached with nuts/bolts I would suggest using Locktite. If that is not an option, lock washers. If the paddles do not attach using nuts/bolts, invest in some high end epoxy.
Dec 16, 2013 | Washing Machines
How do I get the kneeding blade out of the bread machine?
soak the paddle in soapy water overnight with enough water to keep the paddle submerged. The next day wiggle it back and forth while holding the litte ears underneathe the pan. Move it up and down too. If it still doesn't break free go to you tube and type "how to remove a stuck bread machine paddle" have your husband do that move, but don' use more than one jug of water because the TBR15 pan is thin and can bend. Be sure your husband uses hot pads to hold the pan edges so he doesn't hurt his fingers. If that method doesn't work you will have to live with a stuck paddle or order a new pan assembly and paddle and then always remember to remove to soak your paddle after baking and remove it from
the stem, clean, and store. Daryl,,, from breadmachineshelp.com
Feb 26, 2013 | Toastmaster TBR15 Bread Maker
Hello, lost water in the house, now when came back on, water dispensor has a slow drip... the dispensor handle seems to be working fine... it dispenses water when pressed.. doesn't seem to stay...
If you take the bottom grill off the front of the appliance -1x Philips screw either side- under the freezer door you will see where the water pipe goes through the hinge. follow that pipe back towards the underneath of the machine and you should come across a push-fit connector.
The pipe leading through the freezer door from the connector, and blow down it, re-fit, press dispenser paddle to allow to flow. This stops the drip in 9/10 instances.
If not you may need to have someone check the water valve for slight blockage.
Jan 27, 2011 | Whirlpool Refrigerators
B2300 Bread Machine: Good morning - Both paddles in the machine come of...
I am experiencing the same thing. I've spoken with a rep at 1-800-231-9786 and they said that if my machine was still under warranty they would replace the paddles and the pan. I purchased mine in 2007 and therefore my cost to replace the above would be $68.00 Cdn. That's getting close to purchasing a new machine. Does anyone have any ideas... wrap the rotating shafts with plumber's tape or anything else that might ensure the paddles will stay in place?
Linda
May 16, 2010 | Black & Decker B2300 Bread Machine
Would there be any problem if I removed the paddle after all dough mixing has been completed?(before baking stage)
Hi, No problem at all. People do this to prevent the paddle from staying in the bread. If bread machine does not have a pause, take the pan out of the machine to remove the paddle to be safe, and do this before final rise and baking cycles. Hank
Mar 19, 2010 | Sunbeam 5891 Bread Maker
Water leaking from Door and Draw from Hotpoint Aquarius Extra
Had the same problem. I unplugged the machine from the mains. pulled it out from the unit and removed the lid. checked the black rubber hose which leads from the drawer to the drum. it was full of water. i carefully squeezed the pipe and tried to clean it out with warm water to see if it was clogged. still leaking. i then Removed the green paddle on the inside and turned the drum to line up with the black rubber hose that leads from the drawer. I very carefully used a wire coat hanger to put through the gap in the drum left by the paddle. Moved left and right, oh look.... A sock! I manipulated it out of the gap, checked the hose. Water had gone. Put everything back together. No leak. All done in under an hour :-)
Mar 02, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washihg paddle won't stay in
there are usuallyplastic tags that need to be fully engaged for it to stay put. if you can pull it out again then it won't stay in during a wash.
Jan 28, 2009 | Washing Machines
Water Dispenser for Frigidaire
try mashing the wire end connector gently with a pair of pliers to tightn the connectorer and let me know if it stayes on
Jan 15, 2008 | Frigidaire FRS26R4A Side by Side...
Kitchen Appliances - Others Logo
149 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
