Question about Mitsubishi WS-55511 55" Rear Projection Television
Relay Connector on Mitsubishi TV
What is the ''relay connector'' on a mitsubishi rear projection TV? There is a CAUTION note that it should be removed before removing the screen.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
IF IT IS A WS-55511 what you are reading is with the speaker grill removed--there will be one or two sets of wires coming from the front keyboard--before you remove the entire screen assembly you need to follow them to the right and unplug both plugs.
The screen assembly will have about 5 screws at the bottom edge--with both plugs free and the screws removed you pull up and lift the screen about 4 inches and pull it off--if you have questions ask before you attempt to remove the screen unit--tell me also why you want to remove it.
If this has helped you rate this solution as I do this here for free.
SD TECH
Posted on Dec 12, 2009
Whwre is the fuel pump relay for 95 mitsubishi diamonte wagon located?
You need to be certain the fault is due to the Fuel Pump Relay. Your vehicle's PCM will have stored the appropriate fault codes which are causing your problem. If you haven't already, have your codes read to confirm your fault.
The Fuel Pump Relay is actually hidden underneath the plastic 'centre' console (where the gear lever and ashtray are).
These are photos of locations, with the centre console/ashtray removed:
MPI CONTROL RELAY AND FUEL PUMP
RELAY CONTINUITY CHECK
UNDO THE RELAY CONNECTOR
1) Without Battery Voltage: check continuity between connector terminals 2 & 4
2) With Battery Voltage: connect 12v battery power to connector terminals 2 (-) & 4 (+) . Then, check continuity between connector terminals 1 & 3. Refer to diagram below:
If the relay connector does not measure the correct continuity, then replace the relay.
Cheers,
"If this solution has helped you resolve your problem, please be kind enough to leave a testimonial"
Jun 04, 2011 | 1995 Mitsubishi Diamante
Mitsubishi vs-60803 turns relay on board then goes
replace the power relay the contacts are burned and, will not latch.
Jul 22, 2010 | Mitsubishi VS-60803 60" Rear Projection...
Tv mitsubishi ws55311
Remove front lower speaker grill,then remove access panel =
unplug white connector ( goes to front controls )......Does the set
work now with remote ?...= bad tactil switch on front panel......T.
Apr 23, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi vs-50603 removing screen for cleaning
Don,
You were in the right place going at it from the front. After removing the grill the bottom edge of the screen has a series of screws holding the lower edging down. Remove the screws and gently but firmly work the sides of the screen frame up to unlatch the top. When you have the screen/frame in your hand just be careful not to go to far with it - wires attaching the panel controls are still attached and don't have a lot of extra length.
Clean the cans, mirror and reverse area of the lenticular screen and re-assemble.
Bill
Mar 11, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Ps3 hdmi to dvi on mitsubishi wd52327
What brand DVI connector and how many pins are on the connector. try a different cable
Dec 25, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Tv wont power up
Good Day, y'all;
Try these:
CHECK CONNECTOR "DR" FOR PROPER CONNECTION, BETWEEN THE DEFL MINI PCB AND THE MAIN PCB. 2. CHECK C5A09 AND C5A50 BOTH 33 UFD 50 V OFF OF IC5A01 ON PCB-DEFL MINI. 3. CHECK FOR LEAKY IC5A03 PART # 270P704010 ON PCB-DEFL MINI 4. SUSPECT THE HIGH VOLTAGE BLOCK PART # 920P016010.
NO POWER. RELAY CLICKS 1. CHECK Q501 (261P071010), Q502 (260P561020) AND Q503 (260P788010). IF ANY OF THESE TRANSISTORS ARE SHORTED OR LEAKY REPLACE IT INSURE THE FOLLOWING CIRCUIT CHANGE HAS BEEN DONE. REMOVE J58 FROM THE PCB-MAIN. USING AN INSULATED JUMPER WIRE, SOLDER A 22 OHM 1/4W RESISTOR BETWEEN PIN 4 OF THE RELAY K9A30 AND THE J58 HOLE NEXT TO PIN 1 OF CONNECTOR DQ. DRESS AND INSULATE THE JUMPER AND RESISTOR TO PROTECT AGAINST SHORT CIRCUITS. INSTALL A .01 UF 50V CERAMIC CAPACITOR BETWEEN THE COLLECTOR OF Q510 AND THE GROUND LEAD OF R502. NO POWER. NO RELAY CLICK 1. CHECK FOR 5 VDC AT PIN 9 OF IC700 (AC-OFF) IF MISSING CHECK PC901 PART # 268P058020, ON THE POWER PCB. Good Luck, big IRISH. back.gif back.gif
Dec 16, 2007 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi TV rear projection (Model ?)
No worries = generic note applies to more than one model....
Note:Use no cleaner on screen / lens caps = dry soft cloth....T.
Nov 08, 2007 | Mitsubishi WS-55809 55" Rear Projection...
50707 does not turn on, goes off immediately code 24, relay clicks
1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
Aug 27, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
162 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
