Question about Panasonic CQ-C1303U CD Player
My Panasonic Cd player works and im getting power to my amp but no output though my subs..
Everything is connected rca's power wire speaker wire remote and im getting full power but im not getting any output on the subs it was working for about a week then just stoped i checked all the fuses and still nothing...someone told me i could have blown the lower channel in the cd player???
Mine's doing the same thing and i don't know whats causing it either other than its a factory defect
Posted on Apr 21, 2008
How can i test my rca output jacks with a test light? pioneer deh p3100ub. hooked up spkr, nothing. tried one rca plug to white(lt) and then red(rt). Unit has 4 rca jacks, 2 for subwfr and 2 for front...
:) the rca jacks have to be connected to an amplifier,, their signal is too lay to even light a bulb.. you have to connect it to a car amplifier and then from the amplifier to the speakers..
Just so you'd know,, once your deck plays and you hear music on your speakers through your normal speaker wires,, RCA jacks work..
Ok you have 4 jacks,, 2 subs and 2 front.. These should connect to a preamp,, which takes 4 inputs and allows you to equalize or adjust how the music should sound,, now from the pre-amp,, it runs to an amplifier,, thats powers the subs and another that powers the speakers.. Some amps have 4 inputs so you can use one amp for your subs mids and heights..
for example a basic music system is
1 cd player
1 pre amp
1 amplifier (4 inputs, 4 channel out)
you bridge 1+2 and connect this to 1 12" double coil sub woofer
the next 2 connect to 2 mid speakers example "rockford or ev 5 / 8 " and 2 tweeters for heights..
Thats a kicking tricked out basic car audio system,,,
Hope that helps you understand how it works..
Mar 12, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
Doesn't eject CD! and im unsure how to wire up the two RCA outputs that are lable SUB. and the other lable CENTER! do i really fire up my two 12'' subs, just off one RCA jack? and if so do i run two 6''...
I think you will find that those outputs, SUB, CENTER, must go into an Amp that in turn you plug into, unless they are the ones with inbuilt amps. This depends on the output from your unit though. As to whether it would drive them or not.
Feb 07, 2010 | Kenwood KDC-319 CD Player
Connect stereo amplifier to powered sub
You can y out from the main out to the sub.This output is post volume control. set level on sub to desired balance of lows feq to highs
Nov 20, 2009 | Yamaha YST-SW015 Subwoofer
Power Acoustik PWM-16 Equalizer Help
You should be able to use your RCA output (Line Out) from your Pioneer to the input of your PWM-16. Then take the PMW output to an amplifier and then to your speakers. Your EQ only uses RCA's so an amplifier after
it would really bring the sound to life. The amp need not be huge as you have an output for subs also. You could try a line converter to change the RCA lines to speaker wire connections. Not sure if the output would be enough to power a speaker but it's worth a try.
Sep 28, 2009 | Power Acoustik PWM-16 Car Audio Amplifier
DEH-P360 Won't output to rear channels/Sub
Make sure that the FIE (front image enhancement) is off. If it is on, the rear outputs are muted.
Oct 01, 2008 | Pioneer DEH-P3600 CD Player
Sony cdex-m630 connections with an amp
You can use either set of RCA outputs for the amplifier that you want to. Only difference in either of them is front, rear and sub outputs. If you are only powering a sub amp, then use the sub outputs, otherwise, the other two will work fine. You can still use the outputs from the radio itself to power four other speakers while using the RCA outputs.
Jun 26, 2008 | Sony CDX-M630 CD Player
Jensen Amp and Sub
If you followed the instructions correctly, then the amp must be defective. This is sort of simple.
My generic suggestions:
You have the power, the ground, the outputs to the speakers, and then the input.
Make sure that none of the speaker wires are somehow being grounded. Make sure that nothing is shorted that feeds the speakers.
Jerry G.
Apr 27, 2008 | Jensen A300HLX Car Audio Amplifier
Connecting a passive subwoofer!
I believe the sub output that uses a RCA plug is not amplified and wouldn't work in your case.
Nov 14, 2017 | Onkyo TX-SR502 Receiver
Multipal amps
make sure your speakers are connected correctly if subs and are inside the box then check connections also at times the rca at the back of the head unit can disconnect. if power light is on then error is either speakers not connected correctly, rca faulty or not connected or speaker output on amp is blown
Jan 03, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Subwoofer Output Not Working...
The first thing to try is disconnecting ONE of the two subs. See if you get more bass with a single sub than with both. If you do, re-connect the second subwoofer, but reverse the (+) and (-) wires.
Jun 19, 2007 | Panasonic MXE CQ-C7401U CD Player
Panasonic CQ-C1303U CD Player Logo
134 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
