Question about Nikon D70s Digital Camera
My Nikon D 70 wont take pictures. When I try to
My Nikon D 70 wont take pictures. When I try to take the picture the ISO CHA just flashes. I've tried changing the memory card and it's completely charged ...
  • 667 Answers
I have one doing similar, try formatting one of your memory cards in the camera
Posted on Dec 13, 2009
SOURCE:
Grainy pictures
If you are taking pictures in low-lighting conditions without flash, then the pictures will appear grainy. Set the ISO to a lower number (try ISO-100 to start with) and use the flash to compensate for low-light conditions.
This should improve the grainy appearance of your photos.
Dec 29, 2010 | Nikon D100 Digital Camera
My D90 sometimes has an err message and also a CHA in the the ISO mode. Also there is a green LED on the back of the camera that stays on. The only way to get all this cleared is a battery pull. When this...
CHA indicates a problem with the SD card. ERR indicates a camera malfunction. Try reformatting the card which may clear the problem or try a different card. The card may be creating the ERR message. On page 259 of the D-90 users manual, Nikon says this error can be cleared by releasing the shutter but the shutter will not release unless you turn the camera off and back on. Rarely, I have to remove the battery and reinstall it before the shutter will release. The camera will not function at all until the battery is reinstalled.
If you cannot resolve this problem using the above suggestions, I'd recommend that you contact Nikon technical support at www.nikon.com and see if they can help.
Sep 12, 2010 | Nikon D90 Digital Camera with 18-105mm...
Nikon D50 Digital Camera. I cannot take a picture, the letters CHA are flashing on the screen.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't do it, try a different card.
Aug 27, 2010 | Nikon D50 Digital SLR Digital Camera with...
I have a D50 and it now will not allow me to take
THERE IS A "LOCK" LEVER ON YOUR MEMORY CARD----->UNLOCK IT (when it's locked, you cannot read or write information to it, but the lever is often bumped accidently
May 12, 2010 | Nikon D100 Digital Camera
I'm trying to take pictures without the flash but
You can shoot at faster shutter speeds if you raise the ISO setting. Also, turning up the lights will help.
Jan 12, 2010 | Nikon D40x Digital Camera
Nikon D40 is taking Dark Pictures. Flash is
kindly see the aparture and speed of xpouser and the iso also if the iso is 100 change the iso to 400 or 800 or u can select he programme option for the best xpousers
Nov 01, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Can't take pictures in low light/no flash with my Nikon D40X
First of all you need a tripod to cut down on the movement . Next use the mode dail and select a nigt setting .
You can even use a shutter speed in Aperature Prioity .Ypu might want to use exposure comp .
This should work for you.
Apr 07, 2009 | Nikon D40x Digital Camera
Dark wiew
is it set to auto? if not i suggest you check the aperture and shutter speed setting :)
Sep 22, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Lens wont allow me to take picture
That may be the "insert memory card" error.
May 13, 2008 | Nikon AF 70-300mm f/4-5.6 G Nikkor Lens
Nikon D70s Digital Camera Logo
159 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
