Question about Hanns.G Corporation JW-199DPB 19" LCD Monitor
Osd is locked on hanns g
Dont know which button is the menue button on bottom of montor.
jerry
My HP 1730 monitor is showing "OSD Lock Out" message. How can I remove this msg?
The following site has step by step instructions on steps you can try: http://www.ehow.com/how_5008634_fix-lockout-display-computer-monitor.html
I'll paste them below: All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on screen display (OSD) lock out that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lock out setting, there are several different ways you can remove the lock out, depending on the make and model of your particular computer monitor.
1 Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
2 Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
3 Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
4 Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
5 Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out.
Mar 01, 2011 | HP 1730 LCD Monitor
The sceen say`s osd lock out and also the menu screen for the monitor is stuck on . The menu,+,- and auto set buttons wont respond
OSD Lock-out — The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message “OSD Lock-out” appears for 10 seconds.
If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Mar 20, 2010 | HP RY117AA w2408 24" Widescreen LCD
OSD IS LOCKED AND WILL NOT UNLOCK! MODEL IS .....HANNSG HU196D
hey, to unlock osd press and hold the volume down "<" the volume up ">" and "menu" all at once then the osd will unlock
May 27, 2009 | Hanns.G Corporation HU196D (Black, Silver)...
Hcl lcd monitor osd locked
my moniter was automatic restarted, and osd lock not open,where is is osd open option?
Dec 19, 2008 | Acer AL1916W 19" LCD Monitor
My computer screen has a blue box that pops up and say "Controls locked". I am assuming that the buttons on the bottom right hand corner of my moniter is what it is talking about because when I hit the...
This is from the user manual for the monitor. You can download a copy from hp here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=324216&os=228&lang=en&
Click on the "monitor user's guide" link to download.
There are four adjustable options on the OSD settings screen: Lock OSD settings, Timeout, H Position, and V Position.
To change OSD settings:
1 Open the OSD setting screen under the Advanced menu. See
“Using the On Screen Display” on page 25.
2 Press the Browse buttons to select the option you want to adjust.
3 Press the Select button to check the option.
To change OSD lock setting:
1 Press the Browse button to select yes (lock) or no (unlock). The
setting is automatically saved when you change the value.
2 Choose Exit sub-menu and press the Select button to return to
the OSD Main Menu or press the Menu button to exit OSD.
NOTE: Once OSD is locked, all OSD functions including the
shortcut buttons are disabled. If OSD is locked, pressing
any button on the monitor directly opens the Lock OSD
settings window so that you can unlock OSD.
Dec 02, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
OSD Lock Problem
I have a hanns g 22" widepanel , I had the same problem with lockout. I had my monitor disc and looked on it, or in a manual if you still have it. Here is the combination I had to press and it worked. I pressed the arrow buttons and the menu button all together a few times and it unlocked. Try that!
Function Key Lock:
Press the <「Volume -」, >「Volume +」and the 「Menu」buttons simultaneously to
enable the Function Key Lock. When the Function Key Lock is enabled, only the Power
button is active. Press the <「Volume -」, >「Volume +」and the 「Menu」buttons
simultaneously again to unlock the function keys.
Aug 03, 2008 | Hannspree HW191D LCD Monitor
Monitor
Here is a link to the Monitor manual
http://america.hannsg.net/filectrl/JW199D_UM_EN.pdf
Most OSD's lock/unlock by pressing the menu button and holding it for 15 seconds
Jun 08, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
OSD Lock
I am not sure if this applies to this model.
Hold down the menu key for more than 10 seconds, and see if this unlocks it.
Jerry G.
May 18, 2008 | LG Flatron L1951S 19" LCD Flat Panel...
Osd main controls locked
that depends on the brand and model of monitor ,
it normally takes 2 buttons pushed at same time to unlock it.
if you have side buttons its normally them.
May 12, 2008 | Gateway FPD2275W LCD Monitor
Osd locked
I had precisely the same problem... I depressed the Menu Button for about twelve seconds or more and the menu actually finally popped up; and does so now every time I depress Menu! Hope this works for you.
Big Jim
Dec 30, 2007 | HP vs15 15"LCD Flat Panel Monitor
Hanns.G Corporation JW-199DPB 19" LCD Monitor Logo
135 people viewed this question
Top Hanns.G Corporation Computers & Internet Experts
nm8r
Level 1 Expert
Are you a Hanns.G Corporation Computer and Internet Expert? Answer questions, earn points and help others
