Question about Canon EOS-5D Digital Camera
I would like to photograph people and animals in snow
I would like to photograph people and animals in the snow boyj on dim and cloudy days as well as breight blue bird days. Olease tell me what mode and settings I would have best luck with. usin a Canon EOS 5D
  • 667 Answers
Using the camera in program mode with auto bracketing turned on should give you reasonable results. Winter light is “cooler” in nature and the bright reflections from snow and ice tend to make the final image too “bright."
Bracketing exposures help when photographing outdoors in the snow.
You can use flash as well. Remember to keep a spare battery for the camera, and keep it warm if you plan on being in the cold very long.
Posted on Dec 13, 2009
Low beams go off when high beams are on
what car, what year,? what model (wrangler?) im clueless
bulbs get weak with age
the glass in bulb (looks like silver paint)
this is normal for extreme usage.
replace the bulbs if dim. both.
if the car has covers in front of bulbs (not my 02 wrangler)
but newer cars have this crappy plastic in front,
it can be cloudy, there is a nice kit that fixes it (labor) at walfart. ask.
dim lites?
1 dim bulbs
2 cloudy lenses.
3: bad wire, bad grounds and bad connectors to lamps.
4: wiring hacked by kids wanting HID bs.
5: wrong bulbs, kids again.
6: corroded fuses, (12v at lamp do you have)?
7: bad combo switch or its ground is bad.
if you have 12volts across the dim lamp, you can skip 3 to 7 fails.
see your FSM for how they work. and wiring.
does your car have DRL? daylight running light option or in CANADA?
that be more heart ache.
and my jeep the highs and lows are never on at the same time.
the combo switch selects one or the other.
what it does in flash mode, not sure. need car year. and name.
Dec 16, 2013 | Jeep Cars & Trucks
Code for snow lepored on animal jam
the codes are usually purchased on a code card and are usually 'one time use', meaning that if someone used it once, it probably won't work a second time. I've heard that they snow leopard is only available though the Snow Leopard Card. You can check out this site if you wish: http://myanimaljamblog.blogspot.com/2012/11/stop-and-read-snow-leopard-urgent-news.html
Apr 10, 2013 | Gateway Computers & Internet
Snow leapord code for 2013
these peoplez on fixya will not tell it to u because u have to buy the card ur self
Feb 11, 2013 | Computers & Internet
I'm using GIMP to try to create falling snow. The 1st snow image has snow covering the image, the 2nd has the snow moved down 12.5 pixels, the 3rd has the snow moved down another 12.5 pixels, etc. until I...
How are you playing it? are you trying to create an animated gif?
If so, do the following:-
Create a file, with each of your snow images as layers, then
File-> Save As.
Name the image, then go to "Select File Type."
Make it a .gif image, and then click save.
GIMP gives you the option of flattening it or creating an animated gif. Click the button that says "Save as Animation", and then click export.
Then you get to alter a few more variables in the next dialog box (- you can set the frame rate (a higher number makes the animation go faster) )
Then once saved, load it up in an internet browser, and it should work.
Once you've saved you're gif image, open it up in your image viewer. If your normal image viewer doesn't show the animation, try opening it in Firefox or Internet Explorer. You can do this by right clicking on the file, and selecting "Open With." Then choose your internet browser, and you're all set!
Dec 31, 2010 | GIMP
When taking pics my camera pic are a white blur how do i fix it?
Back up from what you are photographing, and turn your flash off or onto auto. You do this by lightly tapping the little Lightening bolt in the lower right corner of the LCD screen and repeat as necessary until the yellow lightning bolt on the left side of the screen either has a red circle on it w/ a light through it (off) or a capitol A beside it (auto). I prefer auto, because I take most of my photos outdoors and it's hard to tell if a flash is necessary under a tree when its really sunny, or on a really cloudy day @ the beach...(sunny day in the shade-flash. Cloudy &rainy beach? No flash, not ever!) There is a problem w/ the cameras flash system though, you can set it on auto thinking that you can just click away & let the camera handle the flash like you can on most cameras, but the Vivitar almost always has to have the flash reset after every single photo, but then every once in a while it stays on the same setting all day long!
Jul 11, 2010 | Vivitar ViviCam T328 Digital Camera
My headlights are really dim at night. But everyone says there fine. what should i do?
The headlights on my Tahoe are dim too. It's also a 1999. I replaced my bulbs with Silverstar's but it was still dim. I used Mequiar's Headlight kit to polish off the yellowing and oxidized headlight's and it really made them look good but they are still not bright. They look bright but the light hitting the road is still weak. It's because the inside of my headlights are a little bit cloudy still. The heat damage from the bulb made the insides cloudy and the light is still weak on the road at night. That's all I can do unless I replace the headlight assemblies. Much money and not super simple to do. I have very bright bulbs just cloudy housings that still don't allow the beam to fully shine through. I don't know if that is your issue but I hope this helps.
Jan 27, 2010 | 1999 Jeep Grand Cherokee
The car won't start in the morning
Let's test the battery. Turn on yout headlights ant try to crank engine.
If the headlights dim, the battery is dead. If the headlightd go out you have a bag connection.
Now if the battery is dead we need to start it to ck the charging ststem.
If the indicarion is a bad connection then the battery cables beed removing clean and tight reinstsllation( special attento both ends of boyj cables.
To ck altrnator engine must be running and uou need a 10 dollar multimer from a parts stor and then get back to me K?
May 27, 2009 | 2002 Mercedes-Benz S-Class
INSTRUMENT PANEL LIGHTING
this problem seemed to go away when I jiggled the key switch or turned it off and on
Dec 20, 2008 | 2006 Buick LaCrosse
Rear Projection TV
high humidity could be a cause i have a similar problem with a sony rear projection. on some warm rainy days /try cleaning lenses with a photographic anti fog cloth.but be very carefull not to scratch or leave dust on lens.
May 08, 2007 | Mitsubishi WS48511 48" Rear Projection...
Canon EOS-5D Digital Camera Logo
127 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
P.J. Ryan
P.J. Ryan
Level 1 Expert
Are you a Canon Camera Expert? Answer questions, earn points and help others
