Question about Sony Playstation 3 (PS3) Console
Change my display setting
I changed the display setting on my ps3 to hdmi, I don't have a hdmi cord and when i turn on my system there screen is just blank, HOw can i reset my display setting
    President:
  • 1,139 Answers
Do the following steps to solve your PS3 problem :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Posted on Sep 11, 2010
SOURCE:
How do i get my hdmi to work for my ps3 system
Note: How to reset video output settings
If you are attempting to change to an HDMI cable from a different video cable or if the video output settings do not match those required for the display in use, the screen may stay black. If the screen stays black for more than 30 seconds, you may need to reset the video output settings of the PS3.
To reset video output settings:
  1. Turn the PS3 system off by holding the Power button on the front of the console till you see the power light turn red.
  2. Then hold the power button on the front of the console for at least five seconds until you hear a second beep to turn the system on again. The video output settings will automatically be reset to the standard resolution.
[TOP]
HDMI Cable Installation
Interactive Video Tutorial
Click below for an interactive video walkthrough on connecting your PS3 to your television or display device (including HDMI).
alt="Click to play tutorial">
[TOP]
Minimum Requirements
  • PlayStation®3 computer entertainment system
  • SIXAXISTM wireless controller (and USB cable)
  • AC power cord
  • HDMI cable1 (sold separately)
  • TV or display monitor with HDMI port and capable of displaying picture in HD resolution
  • Updated system software installed on your PS3
    Visit PS3 System Software Update to download and install the most recent version.
  • TV "Input" or "Video" channel for the HDMI port
    You need to know the TV "Input" or "Video" channel for the HDMI port on your TV. For instance, if your TV has multiple "Input" or "Video" channels, (i.e., "Input 1", "Input 2", "Input 3", etc.), you will need to toggle through each "Input" channel on your TV until you find the correct channel that displays the HDMI picture. This is important to remember, especially if you do not see the HDMI picture after you connect the cable and configure the PS3 settings. Please refer to the TV instruction manual for more information.
[TOP]
Instructions
  1. Before you begin installation:
    • Turn OFF the PS3TM system using the [MAIN POWER] switch (in the back)
    • Unplug the AC power cord from the electrical outlet
    • Turn OFF and unplug the TV
  2. Connect one end of the HDMI cable into the [HDMI OUT] port on the back of the PS3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
    alt="line drawing of HDMI connection">
  3. Plug in the AC power cord by connecting one end of the AC power cord into the [AC IN] port on the back of the PS3 system and the other end into an electrical outlet.
    alt="line drawing of AC power cord">
  4. Press the [MAIN POWER] switch on the rear of the system. A red light should appear on the front of the system indicating power is available.
  5. Turn on the PS3 by pressing the touch-sensitive [On/Off button] on the system front. The red light will turn green, indicating the PS3 is now turned on.
    Note: The blue light will also appear on the front of the system if you have a disc inserted.
  6. Plug in the TV and turn the power on. The PS3 should detect the HDMI display device automatically. When prompted, "Do you want to output video and audio using HDMI?", select YES and press the alt="X button icon">button. (You may need to press the PS button on the center of the SIXAXISTMcontroller to enable the controller first).
  7. The next screen will ask, "Do you want to automatically switch to the optimal setting?" Select YES and press the alt="X button icon">button.
  8. On the next screen, the PS3 will display the maximum resolution capable on the display (i.e., 1080p). The screen will display, "Do you accept the setting?" You will have 30 seconds to confirm your answer.2 Select YES and press the alt="X button icon">button to save your settings. You have now completed the HDMI installation.
[TOP]
Feb 15, 2015 | Video Game Consoles & Games
My coby lcd tv won't work for my ps3 what wires would I need to make it work
You will need an HDMI cable. Please follow the below instructions.
Instructions
  2. Connect one end of the HDMI cable into the [HDMI OUT] port on the back of the PS3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor. ps3_8_hdmiconnecttv.gif
  3. Plug in the AC power cord by connecting one end of the AC power cord into the [AC IN] port on the back of the PS3 system and the other end into an electrical outlet. ps3_11_connectacpower.gif
  6. Plug in the TV and turn the power on. The PS3 should detect the HDMI display device automatically. When prompted, "Do you want to output video and audio using HDMI?", select YES and press the icn_btnx_color.gifbutton. (You may need to press the PS button on the center of the SIXAXISTM controller to enable the controller first).
  7. The next screen will ask, "Do you want to automatically switch to the optimal setting?" Select YES and press the icn_btnx_color.gifbutton.
  8. On the next screen, the PS3 will display the maximum resolution capable on the display (i.e., 1080p). The screen will display, "Do you accept the setting?" You will have 30 seconds to confirm your answer.2 Select YES and press the icn_btnx_color.gifbutton to save your settings. You have now completed the HDMI installation.
Dec 01, 2014 | Televison & Video
I am trying to connect a playstation 3 to my tv using a hdmi cable but it says "no support". i can hear it but there is no picture.
Try connecting it using HDMI and the standard composite video. Then when you press the power button on the PS3, Press and hold it, it will beep once for turning on, then beep again, once you get the second beep, release the button. Switch your TV to the composite mode and go to your display settings. Then change your display settings to the HDMI cord and the screen will most likely go black. Then switch your TV to the HDMI mode and finish the settings change. Then, change the audio settings to audio as-well. Hopefully this helps. Nathan Taylor.
Jul 17, 2011 | Maxent MX-50X3 50 in. HD-Ready Plasma...
I m trying to change my ps3 from a screen to another. i connect it with hdmi but in the smaller screen doesn't play.the display settings are in hdmi mode in 1080i 1080p and lower.. The monitos that the...
This is a rare problem ............ i faced similar kind of problem
i solved my problem with the help this repair guide you can also try this out i hope this will help you a lot .......
all the best
Click Here
Jul 14, 2010 | Sony Playstation 3 (PS3) Console
When i turn on my ps3 the screen loads but the xmb does not what can i do to fix this.
Are you using an HDMI cable? Or did you use that before but are now using a regular cable?
-Hold the power button until you hear the beeps; the video settings will have reset themselves.
-Plug in the regular cables (yellow, white, red)
-If you can see the image, then stop right here
-If you want to use an HDMI cable, then follow the above steps, but...
-Go to Settings-->Display Settings-->and change it to HDMI or whatever cord you are using
-Restart the PS3, using the cable you set it to use.
Apr 20, 2010 | Sony Playstation 3 (PS3) Console
My screen wont work i tried a hdmi cable but wouldnt work what do i do?
If you can get a display with the default setup (original cords) follow this procedure:
a) Plug in BOTH the HDMI cord and the other display cords to your TV.
b) On your TV, using the disignated video input (not HDMI) you should have the main screen
c) Go to settings, and then display settings. Set up your display to read HDMI. Your screen will go dark.
d) Quickly change your TV input from video to HDMI and it should still be displayed. Save the changes.
e) Shut off the system, unplug the original cords leaving in just your HDMI cord and your designated audio cord (preferably fiber-optic).
f) Turn it back on and you should be good to go.
Dec 01, 2009 | Sony Playstation 3 (PS3) Console
Hdmi doesn't work
Make sure everything is pluged in correctly and the Playstation 3 is on stand-by. The using the power button on the console hold it for about 5 seconds till you hear two beeps. And this will reset the display settings.
Don't hold it to long or it will go on stand-by.
Also try reversing the ends of the HDMI
Nov 06, 2009 | Sony Playstation 3 (PS3) Console
Unable to display HD device (PS3) on HDMI screen
Press the INPUT button on the remote or TV control panel until you find HDMI.
When you turn on the PS3 keep your finger on the power pad until an HDMI message apears on the screen.
This should FixYa.
Let me know and please rate this solution.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Feb 10, 2009 | Olevia LT42HVi 42 in. LCD Television
My ps3 will work on the rca hookups but not on the hdmi hookups
When you hooked up the HDMI did you go into display settings and change all the PS3 settings to HDMI instead of AVI? I thought my HDMI wasnt working, just a blank screen but I could hear the sound, then it hit me..... change the video and display settings to HDMI and poof, there was the pic. lol
Feb 03, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3
try using the composite cables as well.....with your tv set to the composite input go back into the settings and select the HDMI output switch your tv's input back to your HDMI input and remove the composite cables....it should work fine...
Jan 11, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
juanmireles1
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
