Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
Magic focus error Hitachi 51F500A
On my Hitachi 51'' TV the green is separated from the other colors and when we run magic focus it stops on green and then puts up a code 4. When we try to manually adjust the colors using magic focus it won't let us select the green to pull it down
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
Ok, you have more than 1 post for this set--this model uses two of the STK-392-110 OR 392-150 Convergence chips.
If magic focus will not adjust the picture both chips need to be replaced--about 13 dollars in parts if purchased on Ebay.
Green is not offered to be adjusted since it determines the geometry of the picture--red and blue are adjusted to it.
Let me know how much skill you have and I can tell you how to fix the set--it requires two things--getting at the chips and being able to unsolder and replace them--there may or may not also be some resistors around them that are now bad and need to be replaced.
most shops get 300 or more for this repair--total parts cost if you are able to do it yourself is under 30 dollars.
If this helped you rate this solution as I do this here for free.
SD TECH
Posted on Dec 12, 2009
My Dad is having the same problem with the same tv and has the skills to solder and unsolder the chips. Can you let me know what part of the tv they're located in or if you have a scematic?
Posted on Jul 14, 2010
SOURCE:
I have a hitachi 51f500a projection tv. my problem is with the red color overlapping. when i go magic focus it stops at the red
The convergence has failed you can get the convergence repair kit for that model at the following link . The kit contains the parts and the CD with instructions Its the last one listed on that page. http://tvrepairworld.com/convergence_repair_kits/hitachi_convergence_kits
Apr 08, 2013 | Televison & Video
Magic Focus will run for the red blue and when it gets to the green will go half the way up then will stop. a green number 4 shows at the right side of the screen and the picture comes back still out of...
Press the Magic Focus button,will not solved ur tv convergence problems.Ur tv 100% have an convergence problems,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 03, 2010 | Hitachi 51F500 51" Rear Projection...
ATTN SD Tech :Hitachi 51f500a cant make out resistor value
Do not guess on Hitachi resistors...every model is different. Go back to the company you bought the parts from and ask them. If you did not buy instructions goto tvrepairkits.com - they will help you out.
Feb 18, 2010 | Televison & Video
The color on the tv is messed up the green and red i tried auto and manual magic focus but cannot move the green line on manual magic focus please help
Most likely this set has bad convergence ic's and some open resistors. This is a common problem for projection tv's. Check:
resistors RK42, RK46,
RK50, RK54, RK58, RK62
Output STKs IK04, IK05.
I hope this helps. Thanks for using fixya.
Jan 13, 2010 | Hitachi 51F500 51" Rear Projection...
Magic focus error Hitachi 52
The model number you have selected here does not have magic focus--if you really want a answer post the correct model number.
SD TECH
Dec 12, 2009 | Hitachi 52LDX99B 52" Rear Projection...
ERROR CODE 5 on Hitachi 51 inch
You have a bad convergence circuit, very common problem. A good repairman will run you around $400 to do the repair.
Let me know if you have more question.
Tim Nolan
Experttv@comcast.net
Oct 12, 2008 | Hitachi 51F59 51" HDTV Projection...
Blue and Green Bar
run magic focus, If you get a error 4 during the magic focus, that is often an issue with the convergence
Feb 01, 2008 | Hitachi 51F500 51" Rear Projection...
Loss of color picture
I have a blue-ish yellow ghost tint which just appeared on my 51" 51SWX20B made July 2002. Did the magic focus got a number 5 at the end. Did you get a number when you did the magic focus?
Dec 01, 2007 | Hitachi 51SWX20B 51" Rear Projection...
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
453 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
