Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
I wish to print postcards on two sides. I have already done this but now the printer will not print the cards on both sides. I have set everything on two sided to AUTO. I can still print item on paper, on both sides but not the post cards I get from the post office 3.5x5.5. Can enyone help me? I know this printer can do it, it did it last wk but not now. Thanks Bob
    President:
  • 1,566 Answers
There are a couple of steps for you to do. And there is also a note:
"The printer driver does not support manual duplexing. Two-sided printing requires an HP Automatic Two-sided Printing Accessory to be installed on the device."
To print automatically on both sides of a page (Windows)
1. Load the appropriate media.
2. Make sure the duplexer is properly installed.
3. With a document open, click Print on the File menu, and then select a printing shortcut.
4. Change any other settings, and then click OK.
5. Print your document.
To print automatically on both sides of a page (Mac OS X)
3. Verify that you are using the correct printer and page size in the Page Setup.
4. On the File menu, click Print.
5. Select Copies and Pages from the drop-down list.
6. Select Two-sided printing tab, and then check to print on both sides of the page.
7. Select Layout and then select the binding orientation by clicking the appropriate icon.
8. Change any other settings, and then click Print.
To install the duplexer:
1. Push the buttons on the rear access panel and remove the panel from the device.
2. Slide the duplexer into the device until the unit locks into place. Do not press the buttons on either side of the duplexer when installing the unit; use them only for removing the unit from the device.
Posted on Dec 13, 2009
SOURCE:
How to print on postcard size paper?
Most domestic printers have a variable paper tray in which you can adjust the size manually, simply put the paper to the correct corner and print.
Oct 18, 2012 | Canon Pixma Mg5220 Wireless All-in-one...
What's the best paper to use in printing postcards?
I've been printing postcards for like five years now. And based on my experience, the best way to go about that is to print postcards using sturdy cardboard stocks coated on both sides for a high-gloss surface. This medium is best for shipping and for advertising purposes.
Mar 26, 2012 | Office Equipment & Supplies
Magicolor 2530 DL Laser Printer: reset image drum 2530...
I had this same problem however I was using the Magecolor 7450. I was trying to print a C5 postcard and the right hand side of the document was getting cutoff (aprox 2 in). Changing my Paper-Type settings on the printer from "Postcard" to "Any" magically fixed the problem.
I hate this printer.....
May 18, 2010 | Konica Minolta Magicolor 2530 DL Laser...
Ink from my deskjet 5650 smears off my glossy postcards.
Hello there jbaerpynes.
You must use HP branded glossy paper in this particular printer as recommended by the manufacturer. Because HP ink is much finer than most other inkjet printers, the ink sometimes does not set in properly on generic papers, especially glossy ones, and can smear right off.
Try new paper and get back to me. If you have any other questions, please don't hesitate to comment on my post. If I helped you, please give me a positive rating.
Thanks.
-Phil Traversa
Aug 19, 2009 | HP LaserJet 1300 Printer
Postcard printing
You should find the proper setting under the "Layout" tab of the printer properties. Check the box "Cpombination" and from there you can select "2-IN-1". Make sure you use the bypass tray and select the appropriate thick paper for the weight. Lining up side 1 with side 2 is not guaranteed with paper above 210 g/m2 (thick 3) Hope this helps.
Aug 29, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Ink is wiping off my postcards I printed
Is it just with your envelopes? or all your pages that you print?
Usually, when a Laser printer "Smears" it means that the FUSER is bad.
If you do a websearch for "LJ1300 fuser" You should be able to find them for sale. or, check your local Office Supply Store.
Sometimes envelopes are TOO THICK for the fuser to handle at the speed that the printer sends them through, and the toner doesn't have enough time to bond to the envelope. There may be an envelope setting with your printers software, or, you might want to look at the back of the printer.
The door will open. Looking for blue or green or orange or yellow tabs with arrows on them, or paddlock icons. Maybe even an envelope icon. Sometimes you have relieve the fuser tension for envelopes.
If you still have your HP Documentation, check that.
HP has pretty good support on their site.
Q1334A Is the TRUE Model Number of your printer,
Its on the back of your printer.
I hope this helps you.
Jun 05, 2008 | HP LaserJet 1300 Printer
Printing Postcards
actually as you now the fusser unit have a stable temperatures 85c
in your case the problem is the media that you used tray to change the postcard media or tray the post card media in another printer
Mar 13, 2008 | HP LaserJet 9050n Printer
Postcards causing printer jam
I think the card is too heavy or too thick for the machine as when it prints it has to turn the paper. If the card is too rigid it is unable to bend causing a paper jam. Suggestion is to try a less grade of card.
Thanks J
Dec 15, 2007 | HP DeskJet 5650 InkJet Printer
Printing postcards
Hi, You can print postcards in either the manual tray (1) or Tray 2 . But if you have a tray three installed you cannot print postcards,envelopes, etc... I recommend printing them from the manual tray and what you can do is either in your printer setting on your pc adjust which trays you want to use for printingpostcards. Or you can use the printers menu and go to paper handling and manual select which paper sizes you wish to use in each tray.
Dec 04, 2007 | HP LaserJet CM1015 All-In-One Printer
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
Clive
Clive
Thomas F. Schneider
