Question about Nikon D200 Digital Camera with 18-200mm Lens
Trouble auto focusing
My D200 will not auto focus. I have gone thru the entire menu and still nothing. I have the Nikon 18-200 lens. Everything appears to be set correctly. It just quit.
  • tomassmalley Apr 21, 2008
    my camera is 2 years old and the auto focus has become temperamental with a variety of lenses i have a v2.0 firmware in the camera and I do have a sigma lens amongst my collection.- don't know what to do luckily I have a Nikon service center close by so will get them to have a prod and poke. Otherwise the d200 has proved a great camera. I hope this isn't a fault designed to force an untimely upgrade
  • Anonymous May 04, 2008
    My D200 with Nikon 18-200mm lens recently quit autofocusing correctly. In M/A mode, (VR on or off, regardless) it now "seeks" back and forth through whole zoom range, while configured in settings I know worked fine for the last 1-2 years. The Autofocus cannot seem to settle on an "in-focus" settting. Should I suspect the VR engine or the zoom motor, or WHAT?? I've carefully reviewed the settings to assure it wasn't a simple configuration problem (though I recognize there are lots of combinations of settings,and some of these collectively cause unexpected or odd symptoms). I have to check to see if its still in warrenty.
If it's any consolation, I have the same setup and the same problem. I'm now at the point where I'm probably going to have to return the lens as faulty, but there are a few things it could be on yours which you might want to check.
Have you got the D200 set to auto-focus? The selector (on the front of the camera, on the lower left) should be in the S position (as opposed to C or M).
Have you got the lens set to auto-focus? It should be in the M/A position, rather than M.
Have you tried cleaning the contacts? Pop the lens off and give the contacts a clean with the appropriate equipment. Dust on the contacts could be causing a problem.
Failing that, have you tried turning the camera on and off a few times?
I've obviously tried all the above on mine, and now suspect I've got a faulty lens that needs fixing ... which really sucks! Good luck with it, let me know if you get it working.
Dan
Posted on Jan 23, 2008
Auto focus problems using 18-200mm lens on D200
Your lens might need to be recalibrated. Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
Sep 28, 2009 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Nikon 18-200 mm vr lens not auto focusing on my nikon d200
lets start with the basics, try hard reseting it and try again, if that doesnt work then
try upgrading your firmware (if possible on your camera) and if that doesnt work then it may be the lens, but dont forget to spend a few hours trying to find a option for it in the meny
Jun 13, 2009 | Nikon D200 Digital Camera with 18-200mm...
Trouble shooting in auto focus
Maje sure you lens it not set to manual focus and that the lens is mounted correctly. Also - FWIW - shoot with a fast shutter speed (1/250 or better) to avoid blur.
Apr 24, 2009 | Nikon D200 Digital Camera With 18-135MM
Very soft focus on D200
Hi Amanda, welcome to FixYa.
Try this to fix your focusing issue. It's a custom AF setting.
Press the Menu and select the pencil icon. Then you'll see Custom Setting Menu on the LCD display. Click down to Autofocus and then click to the right.
There are 3 choices here: FPS Rate, FPS Rate + AF, and Focus.
Set it to Focus.
FPS Rate is the default setting, the camera will take 5 frames per second whether it's in focus or not.
FPS Rate+ AF forces it to slow down hoping to get more frames in focus.
Focus sets the camera to fire only when in perfect focus. It slows you down some, but it will save you from deleting all the blurry ones.
Try this and let me know if it works for you with a comment.
Ken Rockwell has alot of tips and tricks (including the one I just gave you) in a pdf telling all about your camera. You can read it here. http://www.kenrockwell.com/nikon/d200/users-guide/d200-users-guide.pdf
Enjoy your camera and feel free to rate my solution.
Rob
Mar 02, 2009 | Nikon D200 Digital Camera with 18-200mm...
Nikon D200 refuses to auto focus with any lens it just doesn't do anything.
Does the camera body has a M/AFswitch? it would be located in front on the left side if that accidently gets changed to M your lens will not AF any more until you change it?? I know it sounds so simple but who knows!! Barry Brown
www.coralreefphotos.com
Oct 27, 2008 | Nikon D200 Digital Camera with 18-200mm...
Nikon D200 Auto Focus
It seems to be a problem with the internal working of the camera its self. I have requested a replacement fro my seller. Thank You Samuel
Apr 06, 2008 | Nikon Cameras
Prime lens
make sure the aperture ring on the lens is set to the minimum aperture number, (usually a orange colored number), i.e. f22,f32
Jan 23, 2008 | Nikon D200 Body Only Digital Camera
Nikon D200
My first question would be what lens are you using - some lenses have auto stability features - please post lens make, type, model number and when you purchased it.
Dec 22, 2007 | Nikon D200 Digital Camera with 18-200mm...
D200
Do you mean that you turned off auto focus on the shutter button? The manual will tell you where to find the appropriate custom setting. It's Menu > custom setting menu > a Autofocus > a6 AF activation.
Hope this helps.
Oct 16, 2007 | Nikon D200 Digital Camera with 18-200mm...
Nikon D200 Digital Camera with 18-200mm Lens Logo
69 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
