Question about Alpine CDA-9883 CD Player
I installed my cd player with the car battery connected and now it wont work how do i know if its still good the car is a 97 honda civic with a factory car alarm
  • spxlazy Dec 15, 2009
    well i connected the radios negative to ground and connected all the +12 volt wires to another +12 volt wire in the car and.......yes i got power,so it was the +12 constant wire that wasnt giving me power so im going to connect it to another wire that provides constant power
Check the fuse it may have blown. replace it if it is
Posted on Dec 14, 2009
97 honda civic battery is fine but wont start unless jumped when turning key there is no sound. dash lights up and the headlights work but just wont start.
how do you know the battery is good? may not have enough power under load like starting - you have it load tested.
make sure your battery connections are clean and tight
Oct 21, 2017 | Honda Cars & Trucks
97 honda cvic dx cranks but wont start and no lights or radio work
Wires,coils,fuel filter,check fuses,relays,battery connection.
Jun 14, 2013 | Cars & Trucks
How does the cd player work in honda civic 2003 model
The Civic CD player may not be able to read that type of disc
Jan 28, 2013 | 2003 Honda Civic
Hi, I have a steal stopper alarm which came with my honda civic 97, I changed the battery and now the alarm wont work. How do I reset the alarm. When I re-connected the battery the alarm chirps but does...
there might be a hidden switch under your ood or dash that you need to push to before doing any electrical work like on mine. If you dont push that switch it could short circuit your system. I would find that switch and try to reset it by pushing it in and then back out.
Dec 09, 2010 | 1997 Honda Civic
My new cd player wont turn off in my 1999 Honda Civic
The problem is you have the two wires hooked together. It's back feeding. One has to be hooked to key power. and one to all time power.
Jul 10, 2010 | 1999 Honda Civic
97 honda civic Speedometer bouncing lights dimming fuse ok
hey ! guyz i dnt knw for sum reason my dash board lights are not working, i have checkd the fuse and the bulbs buh they are perfect can ny1 tell me whatz wrong wiv ma 1998 honda civic dashboard lights.
Mar 14, 2010 | Honda Civic Cars & Trucks
My 96 honda civic has a idle problem. I gotta charge my battery daily...we got a new alternator and its a brand new cell battery but the idle goes low and every light within the car including the dash, cd...
Check the battery cable connections at both ends for loose or corroded connections. I would also insure that the drive belt and connections to the alternator or good and tight. You also want to check relevant fuses.
If all this checks out then there could be a "sneak" circuit draining the battery somewhere. You could verify this by connecting an ammeter between the battery positive terminal and the battery with the key off, it should read zero or very very close to it. If you are seeing more than a few tenths of an amp current flow (preferably less) then I would start tracking through the wiring beginning with any new electronics that have been installed or repaired lately.
Feb 18, 2010 | 1996 Honda Civic
Civic 97 sohc vtec wont start
The need for the trans to be in park or neutral is a safety feature on all automatics called a detente. This prevents the vehicle from starting in gear and taking of out of control. As for the starting problem, if the battery is good and you even tried to jump it with another car the best place to start is at the battery terminals for corrosion.Remove the cables and with some sand paper, not to rough, clean the both the terminal and cable end to a shin before replacing.
If it still won't start than check all the connections on the starter motor. Do the same thing to all the connections that you did to the battery. After replacing the terminals on the battery and starter coat them with a terminal spray to protect them.
May 05, 2009 | 1997 Honda Civic
93 civic wont start
My mind goes to battery, starter, or kill switch.
If you can play the radio and the lights are working, but you get nothing when you try to start it (not even a clicking sound), it's not likely the starter, either.
You may have a kill switch engaged. Some Honda cars have a kill switch that disables the engine from starting. (Anti-theft device installed). Check your user Guide to see if there is info there.
Often, there is a button you need to push or some other trigger to release the lockout.
Here is what I would try:
1. Conact the seller, if you can, to inquire.
2. Call AAA. They may know the various options, and did help me when I had trouble.
3. Call a Honda dealer to inquire about options for disabling it.
Good luck.
Jun 09, 2008 | 1993 Honda Civic 4 Door
Alpine CDA-9883 CD Player Logo
126 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
