Question about Miele Cat & Dog 326i Bagged Canister Vacuum
Failed telescoping tube lock. Will not release
  • Miele Master
  • 8,404 Answers
It is stuck because it is full of gritty dirt. Like the guy said, don't force it, get a bigger hammer.
Serioiusly, you can use a hammer to tap along the handle to loosen the gritty dirt and probably get the parts to release.
thanks for posting at FixYa.com
Posted on Dec 13, 2009
  • A Miller Dec 13, 2009
    Solution didn't work for you?
    I'm sorry. I tried to give you a simple workable solution, something I have used with success in the past.
    Thanks for your question
    a
How to put the telescoping wand back and use DC25 vacuum again as regular?
Carefully put metal tube back into the hose so that the hose is on the outside of the tube Make sure that it is the correct way around when fully returned i.e. that the handle part is the right way.
Aug 16, 2014 | Dyson DC25 Bagless Upright Vacuum
How to return telescopic reach pole to original position
Hi there, it's Jack at Dyson.
Once you've reattached the wand to the machine, you need to press the release catch again to collapse the wand back down inside the hose. The release catch is the same one you used to remove the wand initially, located just above the on/off switch.
I hope this helps, but if you'd like any further advice you're welcome to get in touch directly. You can reach our experts by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 12, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
How do you change bag
Hi! Below are step-by-step instructions on how to change the bag on your vacuum. This vacuum takes a Dirt Devil Type D replacement bag. I have included a link to the instruction manual, as well as a link where you may go to purchase replacement bags for your vacuum.
1. To Remove: squeeze front panel release lever and pull towards you.
2. Grasp cardboard collar of paper bag with both hands and pull past raised locking tabs on the dirt tube. Dispose of old paper bag.
3. Important: Extend bag away from hole before installing. Press in opening to clear paper away from hole.
4. To Install: Push cardboard collar past raised locking tabs on the dirt tube with both hands. Be sure paper bag is fully extended and tucked in at the top and bottom.
5. Replace front panel by putting the two bottom tabs in the slots on the vacuum. Push front panel so release lever attaches.
http://bit.ly/1DEkilx
Type 3 Pack
Hope this helps!
Jun 01, 2014 | Dirt Devil Vacuums
Telescopic extension tube has lost clips
This can easily be repaired by ordering the ***.kit locking devise, not kidding on the name; part # 03876673.
Jan 12, 2012 | Miele S7210 Bagged Upright Vacuum
I NEED A TELESCOPIC HOSE FOR MY PHILIPS EXPRESSION HOOVER, WHERE CAN I GET THIS MY HOSE PIPE IS BROKEN AND I HAVE TRIED TO GET A NEW ONE AT VARIOUS SHOPS HERE IN IRELAND AND I CANT.
Hi - greetings from Scotland! Im not sure if you mean telescopic hose = do you mean telescopic metal tubes? If so they are readily available on ebay.co.uk I buy from many sellers on there but Hoovermania are one of the best.
What you need to do before order is to measure one of the smaller cleaning tools at the opening with a ruler where you'd usually put the hose. If you haven't got one to hand measure the end part of the plastic handle where the hose is where you'd usually attach the pipes. Generally if it measures 3.5 cm this works out to be a 32mm fitting tube which is readily available on Ebay and from different sellers. If however it is more then it has a 35mm fitting.
If its bigger than that, then you'd need 35mm tubes of which some are still available on EBay. In any case, you can look at different manufactures because when it comes to telescopic metal tubes the 32mm fittings will fit any vacuum cleaner that can accomodate these sizes. Therefore shop around; Hoovermania have a few on offer and you can phone / email them if you are not sure.
Mar 27, 2009 | Philips Vacuums
Electrolux oxygen plus 2100w telescopic tube is stuck. I wanted to extend it but the handle will not release and is stuck. Can you offer any suggestions?
I have a electrolux 2000 and my tube has a small tab that you push before it would let me release it. I had trouble getting it off as well. What I did was push the tab, Plasing one foot on the vaccume head holding it down while pulling up and twisting. I'm not sure if yours is attached the same way but this method worked for me. Good luck!
Aug 18, 2008 | Electrolux Vacuums
Telescopic duster
Just pull straight up. They're a bit stubborn at first, but there's no real lock or anything in there, so trying to get it to release by twisting or pushing on anything won't help. (I know this because I spent quite some time not wanting to break a customer's duster, so I wasn't willing to just yank, and was coming up with all kinds of crazy theories on how to release it. But yeah, just yank.)
-R
Jun 22, 2008 | Eureka 2971AV EZ Kleen Bagless Upright...
Telescopic handle
sometimes the locking mechanism for the wand wears out, make sure u have it all the way in and look where it locks and see if it looks worn
Jan 21, 2008 | Fantom Vacums FM760 Twister 500DX Bagless...
Miele Cat & Dog 326i Bagged Canister Vacuum Logo
665 people viewed this question
Top Miele Vacuums Experts
Colin Stickland
Colin Stickland
Gerry Harvey
Gerry Harvey
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
