Question about Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum
I have charged batter for over 24 hrs and still doesn't hold charge, can u replace the batteries? or do u have to get a new battery pack
  • 8,404 Answers
You need a new battery pack. Visit www.hoover.com or fixYa.com advertiser. Other places you may check is www.batteries.com or www.repairclinic.com
thanks for posting at FixYa.com
Posted on Dec 13, 2009
How long does it take to charge the cordless vac?
The basic rule of charging is "charge for 3 hours for every hour of use".
You won't hurt anything if you charge it overnight, but don't leave it charging for more then 24 hours.
If you wear the battery out eventually, Batteries Plus can re-pack the battery.
Nov 18, 2016 | Vacuums
Red light flashing very fast and not charging fully
How long is it charging until the light goes from flashing red (no charge) to yellow to finally green (full charge) ? If it's not at least 2 hours, sorry I don't have my Roomba papers available, so I'm guesstimating here, it's not getting a full charge. If you can put a voltmeter on the " fully charged" battery pack, that might tell you if the charger is the problem. Clean off the metal contacts where Roomba meets the two metal contacts on the charger. Also just because a battery pack or set is new doesn't mean it's functional. I had a new Apple battery for my laptop that didn't work when I replaced an older one.
Sep 26, 2014 | iRobot Roomba 530 Robotic Vacuum
I have a Dyson DC16 handheld and the battery does not hold a charge.
I have the same vaccumm with the same problem, went back to exchange it and the same thing happened, I usually get about 10-15 minutes non stop out of the battery, I read that the battery memorizes the first charged time and then will only charge for that long. Did you happen to charge it 24 hrs?
Jan 03, 2014 | Dyson DC16 Root 6 Bagless Handheld...
Should the red light on my 15.6v dustbuster turn green when it's fully charged? It doesn't.
I had the same issue, then i just found the manual, in charging part, it says:"The charging indicator will be lit as long as the
appliance is connected to the plugged-in
charger."
Also it says:"While charging, the charger may get warm, this is
perfectly normal and safe. It can remain on
charge indefinitely without damage or danger. It
is not possible to "overcharge" the battery cells
with the charger provided"
Jul 29, 2012 | Black & Decker 15.6 Volt DustBuster Vacuum
My irobot (Roomba)is only working for 10 mins then
It should take about 6 hrs to charge. I had the same problem and reset the charging circuit. 1) Charge it until the green light comes on. 2) Unplug and pull battery out. 3) hold down the power on button 15-30 seconds. 4.) Put the battery back in, plug in the charger (direct - not through the dock) and charge for 72 hrs. Then, run at Max clean until the "I'm dead" tune plays.
May 12, 2010 | iRobot 4150 Roomba Vacuum
Battery lasts only 3 - 4 minutes. Dyson admits this is too short, but won't send me a new battery because I live in Canada..
yer its a con and they know it too, rember it takes about 16 hours to fully charge the batterys after they have been knocked flat, and thats only with a good set in it,,, problem is in your battery pack there are whats called "matched batterys" that is the batterys all hold the same amount of charge if one go's down on you the hole pack is a bust bin job as you wont ever get the same kind of battery to replace it with
sorry im no help there
Oct 23, 2009 | Dyson DC16 Root 6 Bagless Handheld...
Roomba 4210 replaced aps battery still does not work
Try cleaning the silver contacts on the battery as well as the charging station with a small amount of rubbing alcohol such as an alcohol pad.
Also check to make sure the dirt reserve is completely empty. Also check that the briushes are clear and can move freely.
This 'not charging' is a very common problem with the Roomba and the manufacturers continue to sell rechargable batteries that are no good even though they are aware of the problem.
Mar 29, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Westinghouse Unplugged Vacuum Turns off after 5 Seconds.
If both batteries are behaving the same way then this is probably a charger problem. When you insert the battery pack into the charger does the 'charging' light blink for 30 minutes (fast charge) then go steady? I noticed that one of my batteries was causing the light to come on steady immediately I inserted it into the charger. When I tried to use the battery pack I got the same problem everyone else is seeing, i.e. vacuum cleaner shuts off in less than a minute, so I conclude that when the charging light is on steady then the battery is not being charged.
If the charging light does not blink when you insert the battery (i.e. comes on steady or not at all), try removing the battery and re-inserting it into the charger.
Try a conditioning cycle on your battery packs. To do this:
* Insert the battery pack into the charger
* Before the charging light lights press the 'condition' button located just above the charging light.
* The 'conditioning' light should blink. This is a light which does not normally illuminate, and it is located below the condition button and above the charging light. The charger fan will run quieter in this mode.
* Leave the battery pack in the charger for 24 hours while this cycle is taking place.
I'm not a service technician so perhaps someone else might like to post other solutions or corrections to this one.
Mar 07, 2008 | Vacuums
WST1600 upright
Hi , check battery teminals might corroded need clean the post ,unscrew clean and try to charge , if does not full the battery have problem , need to replace.
Jan 21, 2008 | Westinghouse WST1600 Upright Vacuum
Swivel sweeper battery is not charging
The battery is done for sure. take a look here Finally charging for our multi device world and choose the best one for you (by price and seller). cheers
Jan 18, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum Logo
163 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
