Question about MSI K9VGM-V Motherboard
I installed the motherboard with the cpu 3500+
I installed the motherboard(msi k9vgm-v) with the cpu 3500+ (witch i've got from a friend), into my case.also i got his power supply.
after i put the parts in my case and connected all the wires the computer will not start. just the fans on my graphic, cpu and power suplly spin a little bit and nothing more happens.after that i removed the ram i tried to start the comp. and same result, then i removed my graphic and start again and same thing happend. i also removed hdd and nothing has changed. i tried also to check the cpu if it is in the right place and it is. the front LEDs turn on for a sec and then just turns off.
can anyone help me with this issue
i hope i do not need to buy a new motherboard and cpu....
  • 2 more comments
  • bimmer_ali Dec 13, 2009
    no beep, nothing
    the fans (cpu, psu, and graphic) spin for a sec a nothing more happens.i checked the wires many times and everything is in the right place....just one thing was not right, i had one screw on the back of the board wrong placed, maybe that caused a power problem?!
  • bimmer_ali Dec 16, 2009
    no beep
  • Mark Taylor
    Mark Taylor May 11, 2010
    Are you getting any beep codes?
  • 728 Answers
There could be many things that could stop the board from turning on, Determining what is wrong is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Also, if your going to load a ide drive, make sure you set your pin setting correctly on it. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four with another to see if you get any change. Also, on the drive, try a different cable to make sure it's not that, If no change, then I usually get another board that I can test the first four, and make sure that they work. If after that and you have tested all of the components and they all work, then it's save to say you have a Dead Board
Good Luck and don't forget to leave a rating.
Thanks
Mark
Posted on Dec 19, 2009
Testimonial: "Thank you! the board is dead, i tried everything but nothing helped.now i'll take the board to a local service, maybe they can fix the mobo..."
Installed WD3200AAKS 320gb Sata 1hard drive to replace 80gb seagate. MSI K9VGM-V mb with Athlon 64 X2 cpu, 2Gb ram, Hard drive is detected as WD 3200 but only shows as 127 Gb in disc properties. There...
right clik on my computer, then manage, then disc managmant, in it you can see your free space, right click on your free space, then greate new partion.
Jun 08, 2011 | MSI K9VGM-V Motherboard
I have windows 7-64 biti end i need this drivers.thank you----my motherboard is---K9VGM-V
You need to go to MSI's website and get the drivers from their support link for that particular motherboard.
http://www.msi.com/product/mb/K9VGM-V.html#/?div=Download
May 08, 2011 | MSI K9VGM-V Motherboard
My computer is unable install sound card my mother board is msi k9vgm-v ?
you may download the high definition audio driver here:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=260
Dec 24, 2010 | MSI K9VGM-V Motherboard
Msi k9vgm ms 7253 driver
Download here at msi:
http://www.msi.com/product/mb/K9VGM-V.html#/?div=Driver&os=XP%2032
Select your windows system.
Find the audio driver and download it.
Unzip the file before you install.
Good luck
Oct 01, 2010 | MSI K9VGM-V Motherboard
I need the mothert board diagram
Download the manual for your MSI K9VGM-V MB. Click on the link provided;
http://www.msi.com/index.php?func=searchresult&keywords=k9vgm-v&table=download
You will need Adobe Reader to view the manual. If you do not have Adobe you can download it at Adobe's web site;
http://www.adobe.com/products/reader/
Mother board layout is on page 1.
Cheers!
Mike
Sep 10, 2009 | MSI K9VGM-V Motherboard
Win 98 on K9VGM-V
hi im josh in cebu phils.may i help you? friend if mainboard doesnt support the video. You just buy a new video card and install it sothat it can be used at the same time it will gve you better performance cause the video nw works its own.good luck
Feb 20, 2009 | MSI K9VGM-V Motherboard
No dispaly
I AM THINKING IF THE POWER SUPPLY DID YOU CONNECTED
TO MAIN BOARD IS OK . NEWER BOARD NEEDS A CABLE WITH FOUR PIN TO GIVE ANOTHE 12V TO STAR ALL THE BOARD. IF YOU CAN EXPLAIN I DID YOU CONNECTED MAY BE
WE CAN KNOW THE PROBLEM- DELFO
Mar 20, 2008 | MSI K9VGM-V Motherboard
MSI K9VGM-V Motherboard Logo
134 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
David
David
Robert Monigold
Robert Monigold
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
