Question about HP Photosmart D7360 All-In-One InkJet Printer
Ink system failure Error: 0xc18a0301
I have been printing quite a bit today. Towards the end of my job the printer screen popped up a message that said "Ink System Failure" - Refer to printer documentation. Error: 0xc18a0301. It prompted me to turn the printer off and then on again. I did several times but to no avail. That screen continues to pop up and nothing will print. I took out the cartridges, put them back in, unplugged the printer from the wall and the USB port and then shut my computer down. Nothing works. I attempt to print and the screen comes up as usual but when I click to print, the icon in the taskbar disappears. Any ideas??? Thank you. nonnie110951@mchsi.com
    New Friend:
I am posting this in the hopes that it may help other lost lambs like myself as I was unable to find this answer on my own searching the web.
For the past couple of days, my happy little HP 6180 Printer has been asking for new yellow juice. I finally got the chance to go pick up a new cartridge and much to my dismay, when I installed it, I got a message saying Ink System Failure... something something... refer to documentation.
Well, the documentation had no references to this kind of error. I tried everything the website suggested, unplugging it, taking out the ink cartridges, starting the whole thing up and reinstalling and the error just appeared again and again.
I looked online and was dismayed to find that people said that they had gotten refurbished models sent to them because they couldn't get tech support at HP to help them... OR that they were charged big bucks for tech support.
My husband took over at that point (I am normally the geek but it was a long day) he got online with a tech support person and she talked him through fixing it. It works great once again!!!
Here is the content of the chat, hopefully it helps you too! Christina is the tech support person.
Christina: Let us perform some steps to isolate the issue and find a fix for it.
Christina: Please perform the following steps and let me know the message that will be displayed on the printer.
Christina: A. - Press and hold the "*" key.
B. - Press the "#" key and release both keys.
Display should say "Enter Special Key Combo"
C. - Press and release in sequence the "1", "2" and "3" buttons.
CustomerName: ok
CustomerName: screen says "support" R0631M
Christina: Fine.
Christina: 2. Press and release the right arrow button until the display says "System Configuration Menu".
Christina: 3. Press and release the "OK" button.
Christina: 4. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
Christina: 5. Press and release the "OK" button.
Christina: 6. Display should say "Hardware failure status: Clear. Press OK to clear".
CustomerName: yup
Christina: 7. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
CustomerName: ok
Christina: 8. Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
CustomerName: ok
Christina: 9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
CustomerName: done
Christina: Fine.
Christina: 10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
CustomerName: done
Christina: 11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
CustomerName: made a buncha noise, and it didn't print a diagnostic page
Christina: Good.
Christina: Is the error message still being displayed on the printer?
CustomerName: nope
Christina: Good.
CustomerName: should I try to print something?
Christina: Let us print a self test page to check the functionality of the printer.
Christina: Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
Posted on Feb 12, 2013
  • 532 Answers
This comes from fixyourprinter.com: Error number 0xc18a0301 on HP printers Follow the below steps on the front panel of the All-in-One printer:
A. - Press and Hold the “Print Photos” & “Red Eye Removal” buttons. Release both buttons. Display should say “Enter Special Key Combo”
B. - Press and release in sequence “Red Eye Removal”, “Print Photos”, “Red Eye Removal”
Display says "enter special key combo"
Press and release in sequence “Red Eye Removal”, “Print Photos”, “Red Eye Removal” .
If "support COxxFN0723BR" appears with "uiaux" message, perform the below steps:
2. Press and release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
3. Press and release the “OK” button.
4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status.
5. Press and release the “OK” button
6. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
13. To verify printer functionality print a SELF TEST PAGE.
Posted on Dec 12, 2009
What does error Oxc05d0281 mean
This error message means" ink system failure " and to resolve this issue please follow these troubleshooting steps:
Unplug the printer and wait 30 seconds for power to discharge.
2. Plug in the printer.
3. Hold the CANCEL and OK buttons simultaneously, and keep them depressed while you hit the ON button. This resets the printer.
4. When the printer turns on, if you still get the error message, it's OK. Then perform the steps listed
1?Press and hold the “*” key
2?Press the “#” key and release both keys,Display should say “Enter Special Key Combo”
3?Press and release in sequence the “1”, “2” and “3” buttons
4?Press and release the right arrow button until the display says “System Configuration Menu”.
5?Press and release the “OK” button.
6?Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure
7?Press and release the “OK” button.
8?Display should say “Hardware failure status: Clear. Press OK to clear”.
9?Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
10?Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
11?Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
12?Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
13?Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
After you perform the steps listed above, when you are at the step at the end where you are pressing the cancel button until you get to the WELCOME screen, if at some point you see a message, “Inproper shutdown, hit OK”, go ahead and hit OK and the Welcome screen should appear.
One thing that is nice about this method is that it doesn't use up all your ink doing a recalibration.
The error message should not pop up so try to print a self test Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
all the best
Jun 04, 2010 | HP Photosmart 3210 Printer
Ink system failure code 0xc18a0301
I had the same error and found a posting that recommended that you press * and # and then release at same time. The screen states that you need to enter a Special Key Combo. Enter 1 2 3. From here press the right arrow until you get to System Configuration Menu. Press OK three times. Then press Cancel until you are back at the main screen. This clears the hardware failure status.
Jan 13, 2010 | HP Photosmart C7280 Printer
Error 0xc18a0301 - "Ink system has failed" on a Photosmart 6180
Aug 28, 2009 | HP Photosmart D7160 InkJet Printer
Can print...ink system failure - followed process but it wont wor
2. Press and release the “OK” button.
3. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
4. Press and release the “OK” button.
5. Display should say “Hardware failure status: Clear. Press OK to clear”.
6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
7. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
13. If the error is still there, or reoccurs replace the unit
Aug 21, 2009 | HP Photosmart C6180 All-In-One InkJet...
Error 0xc18a0301
Hello Alina,
Please Click here and follow the instructions to resolve this issue.
Regards
laxman
May 26, 2009 | HP Photosmart C7280 Printer
Error 0xc18a0301
Error: 0xc18a0301 fix from HP tech support:
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
C. - Press and release in sequence the “1”, “2” and “3” buttons.
Screen says "support" R0631M
turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
Print a self test page to check the functionality of the printer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
Ink system has failed 0xc18a0206
This is easily fixed with the following key sequences. You do NOT have to open the printer and unplug a circuit board.
1) press * and # at the same time
2) press 1, 2, 3 and “support R0632M” should display
3) press > and “information menu” should display
4) press > and “configuration menu” should display
5) press OK and “hardware failure status” should display
6) press OK “failure status: clear”. Press OK to clear
7) press CANCEL
8) press CANCEL
9) press CANCEL
10) turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.
NOTE: I did this and the fist time the error came back. Do the sequence again (as I did) and the error will be replaced with the usual print cartridge initialization screens. Print a test page to make sure.
Dec 08, 2008 | HP Office Equipment & Supplies
Ink system has failed. Unable to print. Error:0xc18a0301. Turn power off then on again. Problem continues. Hp Photosmart C5180 All-In-One
Nov 13, 2008 | HP Office Equipment & Supplies
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
HP Photosmart D7360 All-In-One InkJet Printer Logo
986 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
