Question about Refrigerators
Icemaker freezes up
The icemaker inlet tube on our GE refrig./freezer Model #GTS18XCSARWW continuously freezes up. Is this a common problem with this model and how is it fixed?
    President:
  • 1,218 Answers
Good day,
Common problem on all refrigerators.
It is usually caused by a bad water valve located on the rear bottom of the machine.
What happens, is it fills the ice maker, and is supposed to shut off completely.
If it dribbles instead of shutting off completely the water will start to freeze in the tube, and eventually freeze the tube shut.
Posted on Dec 12, 2009
I have a GE profile model # TFX30PR the plastic tube for the icemaker keeps freezing
The water inlet valve is bad allowing the water to drip into the tube and allowing it to freeze there clogging the tube. This is the most common cause for the tube to freeze. You will need to replace the "water inlet valve" on the back of your unit. Here is the part you need to order.
Oct 28, 2012 | GE Profile Performance 29.8 cu. ft....
The ice maker is not working anymore and the light inside the freezer is flashing red.
Do you have water at the dispenser?
The water tube to the icemaker inside the refrig is frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 06, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Ice maker stopped working. the water and ice dispense from the door, but it does not make any NEW ice...
Jun 06, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ice maker does not make ice.
The water tube to the icemaker inside the refrig may be frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Jun 06, 2010 | LG LMX25981ST Stainless Steel Bottom...
Kenmore model 79578502800 refrigerator error code 1F. icemaker does not work
The water tube to the icemaker inside the refrig maybe frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Jun 05, 2010 | Refrigerators
GE PDS20MCP - the Ice maker is not making ice. Took out full tray of ice and has not made any since? Is there some reset button or something?
Before you the Water Valver - Shut your water off - disconnect the water line to the from the back of the refrigerator at the top where it goes into the icemaker. I used zip tie or something flexable to see if it would go all the way through to the
tube inside the refrig. If you have obstruction - use your hair dryer
to thaw the ice from inside the refrigerator tube. When the flexable item goes all the way through. Hook back the water line to the icemaker. You will have ice soon. If still not working, replace the inlet water valve at bottom back of refrig.
Read more: http://forum.appliancepartspros.com/refrigerator-freezer-repair/93259-ice-maker-repair.html#post227249#ixzz0pzmjhvPC
Jun 05, 2010 | GE Profile PDS20SFS Bottom Freezer...
GE adora side by side refrigerator DTL181C5RRBS
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No water in the ice maker
Pour about 2/3 cup of water into icemaker . If it freezes and dumps , and water doesn't go into icemaker , replace the water inlet valve ( the piece on the refrig that the wall waterline connects to . If it doesn't dump the water poured into it after freezing , then replace the icemaker .
Sep 06, 2009 | Maytag MFD2561HE Bottom Freezer French...
GE Profile Refrigerator Ice Maker not working
Pour about 2/3 cup of water into icemaker . If it freezes and dumps the cubes , replace the water inlet valve ( piece on back of refrig that the wall water line connects to ) . If it doesn't dump the cubes , replace the icemaker . Also make sure the coils are clean under the front at the bottom of refrig , or the squirl cage behind refrig ( model number would have helped ) , of dust , lint , pet hair etc .
Sep 05, 2009 | GE Refrigerators
Model #ed5lvaxvqoo; ice maker quite working, no water WHIRLPOOL
Due to your refrig having the ice bin on the door , it could be a little bit more difficult to diagnose . Pour about 1/2 cup of water into the icemaker . If it doesn't dump , then the problem is the icemaker . When you open the freezer door , does the laser lite flash 2 times then pause then 2 times etc.? If the lite does not flash , it means the icemaker is in the harvest mode (dumping) . If stuck in the harvest mode , replace the icemaker . If the icemaker dumps the frozen cubes , then the black fill tube above the fill cup , could be frozen , or the water inlet valve is bad . If you feel ice in the black tube ,(water valve bad due to slow drop leak ) you'll need to pull the fridge from the wall , and see if there is a plastic coupling on the tube going up to the icemaker . If not , you should get one in case of future problems . Cut the tube (or disconnect the fitting ) (if you can blow thru it , black tube is not stopped up with ice ) and turn the icemaker off . Turn the freezer setting down a number or two . Go by ocassionally to see if you can blow thru the line . This water line goes between the top of refrig and the inner liner . Bad design because if it freezes , no way to get to it . Can try hair dryer2.gif on top of refrig . I have known it to take several days for this line to thaw .
Aug 28, 2009 | Whirlpool Refrigerators
Refrigerators Logo
135 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
