Question about Nextel i860
How to take out of airplane mode...It power cycles then turns back on and off again
I would like to urn the Airplane mode off on my Straight talk phone?
Press and hold the power button on side of phone until a menu pops up for Airplane and Shut down and Restart. Select the airplane mode to turn it back on or off.
Jul 20, 2017 | Cell Phones
When I go to settings and hit Wi-Fi, my networks do not appear. Have no scanning abilities
Samsung Galaxy S4: WiFi not scanning for networks:
Hello:
Try these troubleshooting tips:
1. If this is happening at home, it could be your network setup is having issues, turn off your router/modem, wait 2 minutes, and then turn the router back on.. wait for the router to connect and then try again..
OR
2. Go to:
Settings > WiFi > (remove your network & then re-add it, don't forget you need your WiFi password in order to log back in)
OR
3. Go to:
Settings > Connections (Network Connections) > More Networks > turn on Airplane Mode > wait a few seconds and then turn off Airplane Mode
OR
4. Go to:
Settings > My Device > Turn Power Saving Mode Off
Feb 13, 2016 | Samsung GALAXY S4
S4 wifi will not scan for networks
Hello:
OR
2. Go to:
OR
3. Go to:
OR
4. Go to:
Feb 13, 2016 | Samsung SGH Cell Phones
After installing Windows 10, why won't airplane mode turn off and wifi is limited?
How to turn on or off Airplane Mode in Windows 10
Option 1:
1. Open Action Center (Windows Key + A)
2. Click/tap on the Airplane mode quick action button to toggle on or off.
Option 2:
1. Click/tap on the network icon in the taskbar notification area.
2. Click/tap on the Airplane mode button to toggle on or off.
Option 3:
1. Open Settings, and click/tap on the Network & Internet icon.
2. Click/tap on Airplane mode on the left side, and turn on or off Airplane mode on the right side.
3. When finished, you can close Settings if you like.
Airplane mode issues can be of different ways. One might be unable to turn off the airplane mode as its toggle indicates the function is unavailable for the time being. Few users might not be able to activate the wireless connections as they are not willingly glued to the Airplane mode. And there are situations where Airplane Mode turns on automatically refusing other wireless devices to perform correctly. So, we provide you different solutions to try for the above mentioned Airplane Mode issues. So, let us head towards the main topic and see How to Fix Airplane Mode Issues in Windows 10.
How to Fix Airplane mode not turning off in Windows 10:
Solution 1: Change Network Adapter Properties
1. search for Device Manager in Start Menu or Cortana and open it.
2. Make your way to the Network Adapter section and expand it by double-clicking on it.
airplane-mode-turn-off-after-installing-qxiko4mbhn3xwpbyjhiay14v-2-0.png 3. Figure out your wireless modem from the available list and right click on it to navigate to its Properties.
airplane-mode-turn-off-after-installing-qxiko4mbhn3xwpbyjhiay14v-2-2.png 4. This launches the Properties dialog box of your adapter. Hit on the Power Management tab. Clear off the option that saysAllow the computer to turn off this device to save power.
airplane-mode-turn-off-after-installing-qxiko4mbhn3xwpbyjhiay14v-2-5.png 5. To apply the changes, press Ok button. This will Fix Airplane mode not turning off issue in Windows 10 and resume its slider to be turned off.
Check the other solutions here Airplane mode not turning off in windows 10 Fixed
Aug 15, 2015 | Lenovo Computers & Internet
Tracfone losing signal constantly
Try reestablishing your phone with your above providers tower. To do this, all you need to do is hold down the power button, turn on airplane ? mode and wait for 30 seconds, after that, hold the power button again and turn airplane mode ? off
Oct 09, 2017 | Cell Phones
Unable to acces network
Perform a hard reset on your device by pressing and holding your lock screen/power button until your device powers off. If this doesn't solve your problem please set your phone to airplane mode for ten seconds, and then turn it he airplane mode back off. Airplane mode can be accessed through your cell phones settings.
Thanks,
Dish Guy
Apr 07, 2014 | Nokia E Cell Phones
I have droid phone. Says on airplane mode. How do I turn airplane mode off?
1. Press and Hold the Power button for 2 Seconds. A menu pops up. On that list, you will see "Airplane Mode" (under which should state "Airplane mode is ON").
2. Now tap "Airplane Mode" to switch it Off. If you press the power button again after a few seconds, it should now say "Airplane Mode is OFF". This is how you want to leave it. Done.
Sep 14, 2011 | Apple iPod touch
When i turn on phone it shows off and gsm does not work
there are two options first problem happens if the sim card is not detected, eg terminal is broken or action is less, second phone is in airplane mode, you can select airplane mode once again from menu and you should have a network.
press power button slowly to toggle between profile, general, airplane, silent etc
dont forget to comment
Dec 22, 2010 | Samsung Ace SPH-i325
What is airplane mode and how do i get out of it??
Airplane Mode (Motorola CLIQ™ with MOTOBLUR™)
NOTE: Airplane mode turns off the wireless radio. This allows you to use programs while travelling on an airplane, but not make or receive calls. An Airplane icon appears on top of the signal bar when airplane mode is active.
To turn Airplane mode on or off, refer to the following:
Using the Lock key
To use the Lock key to turn off Airplane mode, perform the following steps:
1. At the Home screen, press and hold the Power/Lock key on the right side of your phone.
2. At Airplane mode, tap On or Off.
Using the Settings menu
To turn the Airplane mode on or off using the Settings menu, perform the following steps:
1. At the Home screen, press the Menu key.
2. Tap Settings.
3. Tap Wireless controls.
4. Tap Airplane mode to turn on or off.
Dec 04, 2010 | Motorola Mobility CLIQ Cell Phone
I just need to know how to get my lg ally phone off of airplane mode
Hold the power button down until the phone options menu appears. There are only 3 options to choose from. The middle option is airplane mode. It will let you know if it is "on" or "off". If it is "on" then just tap this option and It will turn airplane mode off, thus turning all your communications back on.
Sep 16, 2010 | Cell Phones
Cell Phones Logo
93 people viewed this question
Top Nextel Cell Phones Experts
Rommel Balcita
Computer Repairing
Computer Repairing
ray gallant
Are you a Nextel Cell Phone Expert? Answer questions, earn points and help others
