Question about Nokia N95 Cellular Phone
N95 flash light staying on all the time
I was taking some pictures in low light, when I finished using the camera, the light stays on. I tried removing the battery and the light goes off. As soon I put the battery back in the light comes on again. This cant be doing any good to an already bad battery life.
Can anyone help?
  • 4 more comments
  • Anonymous Jan 28, 2008
    I have the same problem, any idea how fix it??
  • Anonymous Mar 08, 2008
    N95 was slightly damp from rain on my pocket and when taking the phone out, noticed that the light was on. Removing the battery is the only way to stop it but it comes back on as soon as the battery is replaced.
  • mist213 Apr 28, 2008
    My phone got damp and the same thing happened to me.
  • Anonymous May 27, 2008
    Exactly the same problem.
    Firmware version:
    v 12.0.013
    19-06-07
    RM-159
    Nokia N95 (01.01)
  • Anonymous Aug 11, 2008
    My mate (who is a Brentwood *****) got her boyfriends spunk on hers and its now pregenant!!!!!!!!!!!!!!!!!!!!
  • harroldv Sep 08, 2008
    Have the same problem, one morning I woke up and the Flash light wouldn't turn off unless i removed the battery...
    Does someone know a solution, because i bought the N95 to use as a phone, not as a flash light!
Some water got into the phone which acts as an electricity conductor that is probably connecting the flash light switch together.
let it dry out for a few days and the problem will be gone, its hard to dry out the water from inside.
try to dry it using a blow dryer..always while the phone is off or you might move the water some place else.
use to happen with my keyboard when i spill water in side it. every keystroke writes 2 or 3 letters at a time.
Posted on Jul 29, 2008
  • 107 Answers
Does it have a waranty. contact your seller and try to negotiate. sorry for bad english..^.^
Posted on Jan 23, 2008
Is there a way to see n95 service light?
Posted on Feb 16, 2008
6ya staff
SOURCE:
How do i get the flash off
Most cameras, when set to automatic, will pop up the flash, when the lights are to low. As soon as you switch to a manual setting, with Aperture or shutter priority, the flash should stay where you put it. Down and if should not give any light. So check your settings and don't use Automatic or P(program)
Jan 24, 2015 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Nikon D80 takes picture but wont set off flash
has the camera been in any cold weather or hot conditionds in a car?
the camera deffintly has a fault it has nothing to do with the settings any more
could be due to wearther conditions.
do u have warrenty this item? it will have to be professinally looked at i searched the web and its saying there is a seprate chip inside the camera that produces the flash unit ,and if you had to pay to get it fixed roughly 65 dollars
Jul 05, 2008 | Nikon D80 Digital Camera with 18-135mm...
The camera light is always ON even after switching the phone OFF.
better check out your firmware or take it to a neraby specilist
Sep 15, 2009 | Nokia N95 Cellular Phone
Canon XSI showing "busy" when taking multiple shots
It can be that your batteries are low and takes longer to charge the flash... It can also be that your memory card is a slow on. If the red processing light on the back of the camera is staying on a long time, it means the camera is having trouble feeding the picture to the card... You might try decreasing the picture quality a little...
Jun 12, 2009 | Canon EOS Rebel XSi Digital Camera
Camera turns off when shutter button is pressed.
[source]Question about Samsung Digimax S500 Digital Camera[/source]
Try replacing batteries (high Ah photographic type).
The lens motor & electronics may be draining power if Ah capacity has dropped too low. At night, it could be that your flash is trying to fire (another drain), or shutter timer / mirror staying open longer.
Sep 20, 2017 | Samsung Digimax S500 Digital Camera
Flash pops up, but flash closed warning stays
My E5700 did this a couple of times. The fix for my flash was that the unit wasn't actually popping all the way open. I closed it, then manually poppped open the flash and gave it a gentle upward tug. The flash seemed to lock into position -- and has worked fine since. I hope your fix is as simple as with my E5700.
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
Nov 01, 2008 | Nikon Coolpix 5700 Digital Camera
This could be a faulty unit.  Take it back to where you bought it and hopefully you are still under you warranty.
Mar 09, 2008 | Nikon D80 Digital Camera with 18-135mm...
Canon eos 300d - image to dark
Try lithium batteries or rechargables in the 2500mah range,to me they seem to work best in a flash.
If you use alkalines,use a well known brand.But with alkalines,as they loose power it takes longer for the flash to recycle.
Also the monitor might need to be calibrated or adjusting brightness and contrast.
Mine sometimes does the same thing,I just use Photoshop to adjust it.
Jan 16, 2008 | Canon Digital Rebel / EOS-300D Digital...
Petax ist DL Focus
It could be that your lighting situation inside is darker than in the store. Since the Pentax *st DL does not have an anti-shake sensor like other new cameras, it could be telling you that the low level light will not support the aperture setting you have to acuratley stay focused.
Try using a tripod and a lower aperture setting.
Sep 08, 2005 | Pentax *ist DL Digital Camera
Nokia N95 Cellular Phone Logo
4,358 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
Zaid Anarwala
Zaid Anarwala
