Question about Motorola Mobility V551
When I recive a call the ringer is not working and I press the ringer off button and it doesnt work
Turn ringer on
To set the Vtech T2326 ringer:
there are only four ringer tone/volume choices plus "off" available
1. Press the PROG end of the "SELECT/PROG" rocker switch.
The display will light and show "DIRECTORY"
2. Press the right side top button "VOL +/DIR"
The display will change to "SPEED DIAL"
3. Press the right side top button "VOL +/DIR" again The display will change to "RINGER: [number] ( 1 - 4 or OFF )"
4. Press the SELECT end of the "SELECT/PROG" rocker switch.
The "RINGER: [number] ( 1 - 4 or OFF )" will blink and the ringer will sound.
5. Press the right side top button "VOL +/DIR" The display will change from "RINGER: 1" to "RINGER: 2" and the sound will change accordingly.
6. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 2" to "RINGER: 3" and the sound will change accordingly.
7. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 3" to "RINGER: 4" and the sound will change accordingly.
8. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 4" to "RINGER: OFF" and the sound will cease accordingly.
9. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: OFF" to "RINGER: 1" and the sound will change accordingly.
10. ...and so on, cycling through the four choices & OFF: when you decide to select one, press the "SELECT" end of the central "SELECT/PROG" rocker switch.
11. The display light will go out, the phone will chirp in acceptance, and it will be ready to use the chosen ringer. --
Sep 07, 2013 | Vtech T2326 Cordless Phone
Low ringer and receiver volumes
sir you can increase the receiver volume by when you are answering the call press the volume button to increase the reciver sound...............
Dec 26, 2010 | Nokia 3100
I have a targus wireless mouse MODEL:AMW1603EU the reciver light does not come on and the mouse light doesnt go of nor does it work.
Did you ensure the ON/OFF Switch is set to ON? Did you also try replacing the batteries, then pressing the connect button on the receiver followed by the connect button on the bottom of the mouse?
Jan 14, 2010 | Targus Wireless Optical Notebook Mouse...
I have an akai aa-a25 reciver and right side speakers only work
I had this problem when I first got this receiver back out of years in a box, but it was fixed by pressing the reset button on the back. Hope that works for you!
Jul 10, 2009 | Audio Players & Recorders
My vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
Does your handset have a PROG button? Press that, then press the VOL+ button until you come to RINGER VOL: OFF. Press SELECT button, then use the ^ (VOL+) key until you get the desired volume level. Press SELECT again, then OFF. You're good to go.
May 30, 2009 | Vtech 5867 Cordless Phone
BELL VISTA 200 TELEPHONE
i need a manual for a vista 200 to programme it and to clear stored info i bought it second hand
Dec 05, 2008 | Bell BE-412CID Corded Phone
Turn ringer back on
I sent an email to Doro at asking this exact question Their reply was to hold down the ringer button (bottom left one) till it beeps.
My mistake was pushing it and letting it go straight away.
For Customer Service, go to:
http://www.doro.com/global/businessunit/dorohome/support/customerservice
I got a reply 20 mins after emailing them.
Jun 25, 2008 | Lands Phones
MICROSOFT WIRELESS MOUSE FOR LAPTOP DOESN'T WORK
There's also a connect button on the USB connector. Plug the connector in and press the connect button underneath until the light flashes. Release the button and click the connect button on the mouse until the USB light is steady.
May 16, 2008 | Targus PAKP003U Keyboard
Turn the ringer off
To turn off the ringer on my Vtech cordless phones, I have had to turn off the base ringer & all handsets.
Base Ringer:
Press Menu and listen carefully, continue to press menu until you hear "Base Ringer, to change base ringer press change", hit change and it will say "Off", then you must hit the PLAY/STOP button to save your change.
Handset:
Press the program button and use your "up/down" key to cycle until you see the Ringer selection. Press SELECT and then use your "up/down" key(s) to cycle until the OFF selection is see on the handset screen. Press select.
Jan 17, 2008 | Lands Phones
Motorola Mobility V551 Logo
54 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
