Question about NEC ND-2510A DVD±RW Dual Layer Burner
Audio cd and DVD
On inserting CDs or DVDs nothing happens, the drive doesn't even show up under 'My Computer'. Any possible causes and suggestions for fixing.
Many thanks in advance.
  • Serah Jan 20, 2008
    I have managed to get the drive icon back into ' my computer' by doing a total system scan, on inserting a dvd error message now reads "please insert a disk into drive D:'
    Can someone please help? Thanks again Sarah
  • swestside May 11, 2010
    Does the drive make any noise upon inserting a disk? Also you might want to open your computer and make sure all the connections are in place.
  • 70 Answers
It is mainly due to two reasons
  1. your operating system don't detect your drive
  2. its data or power cable is not properly connected
In the first case, if you are using xp, open my computer, select control panel, click add new hardware icon
  1. read and do as follows
  2. the computer automatically detect your drive
  3. if it don't detect, using manual method and add the drive
In the second case, only do if you are little technical minded
  1. open cpu cover
  2. check the data and power cables attached to the drive
  3. refix the cable some time it may in loose contact
  4. replace cable if it may contact problem
Posted on Jan 21, 2008
CD player not recognized
Read this carefully as it requires you to go in to the registry in windows.
It's the standard fix for missing CD Drives.
Click Here.
Hope this helps.
Jan 26, 2012 | Averatec 3200 Notebook
My dvd player worked fine until I mistakenly inserted a bluray dvd. Now dvds will only have video - no sound. And, there's no sound at all for cds. How do I get audio for dvds and cds again?
Assuming that this is an entertainment center (TV, stereo) DVD player:
It seems likely to me that at some point, the sound cables were accidentally loosened. Double check that the sound cables are plugged in on both sides. They will probably be 2 plugs, one white and one red.
Check to make sure the volume is turned up.
Failing all of these, it may be possible that the added weight of the Blu-Ray (Blu-rays are heavier than DVDs) may have caused some damage internally and the unit either needs repair or replacement.
Assuming that this is a computer DVD drive:
Check the Windows volume control by left-clicking on the speaker symbol next to the clock in your task bar. Push the slider all the way up. You should hear a sound. If not, there is a problem with your speakers or sound card; either way, the appropriate component needs repair or replace.
If you do hear a sound, but still no CD or DVD audio, I would suspect that your computer expects an analog sound link for DVD and CD audio. Inside the computer, look for a small black connector that is loose on one end, but plugged in on the other. If you find one, one side needs to be in the back of the DVD drive, and the other needs to be attached to the appropriate socket on the motherboard or sound card.
Mar 14, 2011 | Computers & Internet
My LG DVD writer GSA-H55N not detecting CDs and some DVDs
Some DVD/CD drivers have two lasers: one for DVD and the other for CD. Not sure if this is your case but looks like the laser for CD discs is gone. The only way to repair it to replace the pickup mechanism. Anyway, it's hard to diagnose your issue as it may be caused by drivers, dust, software that interferes with the CD/DVD drivers, etc.
Aug 30, 2009 | LG (GDR8163BB) (gdr8163bb 10pk) Internal...
HP 530 Laptop CD/DVD Drive Not Working
Please buy new CD/DVD drive since it wont open you cant event check using media. Its a possible mechanical failure.
Aug 17, 2009 | HP 530i (Q6750A) DVD±RW Dual Layer...
Computer will no longer read. play or even acknowledge dvds or cd
Try this:
How to fix the CD player
1. Go to System/Library/Caches and trash the folder
2. Go back to System/Library and trash the file Extensions.kextcache
3. Restart.
If that doesn't work, try trashing this file:
~Home/Library/Preferences/CD Info.cidb
That is the way its done
Dec 17, 2008 | Computers & Internet
My lg GSA-H55N dvd writer is not playing Cds but plays Dvds fine
Try and find the latest drivers for your drive.
Hope this helps! :)
Nov 23, 2008 | LG GSA-H55N DVD-RAM Burner
My drive is neither reading nor writing CDs (or DVDs)
Drive is ng - time to go shopping or check if drive is covered under warranty. Happens.
Jun 16, 2017 | Lite On LH-20A1P (0844149002088) Burner
Combo drive CD not reading, but DVD ok
it may have dual laser and one that reads cd's is faulty, but try uninstalling the dvd drive first then re installing it to see if it cures it, if not the drive will need replacing. Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete. Restart the pc and windows will find the drive again automatically and install the drivers
Mar 30, 2007 | Samsung TS-H492A/RSWN CD-RW/DVD-ROM...
Please Insert disk?
Hi Tool4theman, I have a CD/DVD r/w drive and it only says NEC DVD +RW. That is just the text the manufacturer has embedded in the device, not the results of any diagnostics. You've mentioned what program you are playing DVDs with but what are you playing your audio CDs with and are they commercial audio CDs? Have you tried running a diagnostic on your drive? Here is a link to the Sony CD/DVD diagnostic tool. Its meant for Sony drives but I have used this successfully on other drives in the past. When prompted for a blank disk us a CD. Let us know how it goes and don't forget to rate the posting.
Jan 03, 2007 | LG DRN-8080B DVD Drive
NEC ND-2510A DVD±RW Dual Layer Burner Logo
102 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
