Question about Brother HL 1240 Printer
Brothers HL 1240 Laser Printer. Drum led flashes, then Ready, ALarm and Data led flash together. Replaced the toner cartridge. No Change.
Red alarm light is on and printer is not printing
Posted on Dec 13, 2009
All lights flashing on front - drum, ready, alarm, data. All four flash once then just Drum flashes once and it keeps repeating. What does this mean? If it's replace the drum, how to I do that?
R U getting a message that tells U to change the drum on the printers LCD screen? Also what type of printer R we talking about - if its an HL 1240 - that is an older machine so unless U have a bunch of toner cartridges for it it is not worth spending a lot of money on. Call the dealer and see what they have to say and then decide how to proceed - I do recommend the brother mono laser printers - I think they are the best all around value and no I do not sell brother printers or have any affiliation
Jul 19, 2016 | Office Equipment & Supplies
ALL THE LIGHTS ARE FLASHING . I HAVE CHANGED TONER AND DRUM AND STILL FLASHING
When you change drum, do you reset it?
If not, try this:
Install the toner cartridge into the new
drum unit until it locks into place,
indicated by a click. When the toner
cartridge is installed correctly, the lock
lever is lifted automatically.
Press the control panel button until all the LEDs are on. (The LED turns on in sequence
from top to bottom.) The drum page counter is reset.
Close the front cover, and check that the Drum LED is now off.
Jun 30, 2011 | Brother HL 1440 Laser Printer
I have a couple Brother Printers HL-1435 that are in alarm status and will not print. The Drum light will flash, and then the Drum, Ready, Alarm and Data lights all flash at the same time. How can...
This could mean one two things.
* The toner cartridge is nearly empty.
* You have a paper jam.
To replace toner cartridge:
Click this link to go to the Brother site where it will show proceddure with illustrations how to change the toner cartridge.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000065/faq000065_011.html?reg=us&c=us&lang=en&prod=hl1435_us&Cat=7
To clear a paper jam:
Go to this link for procedure. It also has illustrations to assist you.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000026/faq000026_005.html?reg=us&c=us&lang=en&prod=hl1435_us&Cat=113
I hope this helps.
Aug 04, 2010 | Brother HL 1435 Laser Printer
All 3 Error lights are flashing (4 if you count the GO button)!!
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Jun 26, 2009 | Brother HL-2170W Laser Printer
All lights are flashing not printing
Might have a paper jam in area of toner and drum cartridge that may need to be removed. Typically this will solve the issue.
Feb 11, 2009 | Brother HL 1430 Laser Printer
Brothers HL 1240 Alarm light on
Pull the drum out the front door, remove the toner cartridge and check for any paper and remove it.
Make sure there is toner in the toner cartridge. Look at the lights on the printer. Look at the labels beside them. The label "Toner" will have two lines going to two lights. If those two lights are on when you try to print, you are out of toner. But a now toner and install it in the drum. Install the drum back into the printer.
If not, look at the drum. At the rear top is an opening across the whole drum. Look inside it, you will see a metal grid. That grid must be clean or it will cause small sparks. These sparks will cause a false toner empty error. Buy a can of compressed air from Best Buy (or wherever). Use this compressed air to blow clean the grid. Move the small blue tab at one side of the opening ti the other side and back again. Reinstall the drum and try printing again.
If neither of those help, write back and let me know what lights stay on when the printer stops.
Sep 06, 2008 | Brother HL 1240 Printer
Brother Laser Printer HL 1440
tray this
The procedure for the factory inspection mode is as follows.
(1) Turn off the printer power switch, open the front cover, and remove the drum unit.
(2) Turn on the printer power switch while holding down the control panel button. The Drum
LED comes ON.
(3) Lightly press the panel button again.
(4) Check that all the LEDs except the Ready LED are OFF.
✒ If the toner sensor is ON, the Drum LED stays ON (error).
✒ If the front registration sensor is ON, the Alarm LED stays ON (error).
✒ If the upper paper cassette sensor is ON, the Data LED stays ON. (error) (HL-1250
only)
NOTE:
The lower paper cassette solenoid is turned ON/OFF even if the panel button is not pressed.
(5) Check the rear registration sensor.
✒ If the rear registration sensor is stuck backwards, the Ready LED stays OFF. (error)
✒ If the rear registration sensor is moved back and forth, the Ready LED comes ON at
any time. (error)
(6) Check that only the Data LED comes ON while pressing the panel button.
✒ If the paper eject sensor is ON, the Drum LED stays ON. (error)
✒ If the lower paper cassette registration sensor is ON, the Ready LED stays ON. (error)
If the registration sensor is ON, the lower paper cassette solenoid is turned ON, and
the Ready LED also stays ON. (HL-1250 only)
NOTE:
(7) Install the drum unit.
✒ Check that the Drum LED goes ON and the Ready LED goes OFF.
(8) Close the front cover.
(9) Continue to press the control panel button.
✒ Check that the Data LED stays OFF.
(10) Release the panel button.
(11) If all the sensors except the toner sensor are correct, the printer goes back to the Ready
status.
If any error is detected, the printer stays in the inspection mode.
Apr 01, 2008 | Brother HL 1440 Laser Printer
Laser Printer HL-1440
Hi , The error message your getting refers to the following for the Ready & Alarm Buttons Flashing.
1. Paper Jam
2. Misfeed
3. No Paper
I hope this helps!!
Dec 05, 2007 | Brother HL 1440 Laser Printer
Brother HL-1440
(blinking every 5 seconds) Toner Low Indicates that the toner cartridge is nearly empty. Purchase a new toner and have it ready for when Toner Empty is indicated. (solid) Toner Empty Replace the toner cartridge with a new one. User's Manual is available at the following location: http://www.brother-usa.com/Data/Documentation/Printer/User/UM_HL1440_1450_1470N.pdf Hope this helps.
Aug 22, 2007 | Brother HL 1440 Laser Printer
Brother HL-1440/ flashing alarm light and flashing yellow data light
Brother HL 1240 Printer Logo
584 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
