Question about Kenmore 74602 Gas Dryer
Kenmore dryer making rumbling noises
Kenmore dryer when running, it is making rumbling noises, shuddering. it's 3 years old.
  • Kenmore Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication. Check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Posted on Dec 13, 2009
My kenmore gas dryer model 110-76662501 is making a thumping noise while the dryer is running. The dryer is about 5 years old used about 3 times a week. The clothes dry fine. Maybe a pulley or...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 11, 2011 | Kenmore Dryers
Kenmore 600 Series Gas Dryer, about 2 years old. Makes a loud scraping or rumbling sound as drum turns, not constant but in a cycle, as if off balance. I checked to be sure it is level. What are the likely...
It is normal for the dryer to make sound due to the high velocity of air moving through the dryer drum and exhaust system.
A clicking noise may be the timer advancing.
Check the load for objects such as coins, nails, etc. Remove promptly from dryer.
It is normal to hear the dryer gas valve or heating element cycle on and off during the drying cycle.
The dryer should be level and installed on a solid floor.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 16, 2010 | Kenmore 63942 Dryer
High pitched squeal when running. Capacity Plus Gas Dryer ten years old.
tumble dryer / twin tub is making a loud rumbling noise when running, unplug it, take the rear cover off and remove the drive belt. Then turn the inner drum by hand. If there is a grating noise, the bearings will almost certainly need replacing
Mar 09, 2010 | Dryers
Maytag dryer makes rumbling noise when drum starts and again when
Sounds like a broken spring or a spring mount.
Jan 17, 2010 | Maytag Dryers
Loud rumble sound, Vent hose vibration
That model of neptune dryer had a problem with the blower housings cracking. When the housing cracks, it binds forward into the blower wheel making a loud "rumble" noise and vibration. If you open the door and manually turn the drum and you hear a rubbing noise and feel alot of resistance, then you have a cracked blower housing and need to replace it. It is not an easy job to replace, so if your not familiar with dryers, you should have a technician replace it. Let me know if you have any further questions. shane
Oct 01, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Bosch dryer making rumbling /grinding noises low frequency
you might want check the rollers that tub rides on they are in the front lower part of the dryer, or the belt that turns the tub.
Jun 23, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
Dryer makes rumbling sound when starting
If you remove the front cover and access the blower fan and see if it is still tight on the shaft. if it isn't it makes a rumble sound when started due to vibrating and after a while it makes more noise as it goes. Now I removed the fan and placed a shim in the flat area and matched the flat area of the shaft and replace it back on the shaft and it should solve it.
Mar 21, 2009 | Maytag MDE2600 Electric Dryer
Kenmore elite3 dryer rumbling noise
there are two rollers that hold up the drum...they go bad...and are ez to replace! they are sold in sets of two for about $30.00
Mar 15, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore 400 dryer squealing noise
A little lubricant on the pulleys near the belts will go along way. Its vereasy to access these parts front the back of the machine with a 1/4 hex head screwdriver.
Jan 19, 2009 | Kenmore 63942 Dryer
Kenmore 74602 Gas Dryer Logo
322 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
