Question about Hotpoint NBXR463EBWW Electric Dryer
My hotpoint dryer warms up but does not completely dry clothing by end of regular cycle. It seems to only have 1/2 the heat it had previously, and take twice as long to dry the clothes.
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
This sounds like the thermostat this video will show you the faults or you can visit our video help
You-Tube video "Vx9JMZRRKrg" placeholder (do not delete)
Posted on Jan 07, 2010
SOURCE:
Dryer won't dry clothes
Heating element faulty not giving as much heat as it should
Nov 14, 2015 | Dryers
Hotpoint A1400WD Washer Dryer
Check your dryer vent (probably outside) to be sure something or a kid hasn't flattened it, making it not vent moisture properly. Replace the vent or pull it back out so the damper door will open.
Feb 26, 2014 | Dryers
My hotpoint dryer will not produce heat any longer. it seemed to be weak at first on heat production taking 2 sometimes 3 cycles to completly dry clothes now its stopped all heat production what would be...
There are two solutions to this problem. The first one is to check your vent hose. It could be plugged up and it won't vent out. Second problem is it your elements. Depending on what model of the dryer the tops of getting it fixed would be $150 with labor.
Apr 21, 2011 | Hotpoint Dryers
My dryer is not heating the air clothes are rolling and air seems to be blowing but the clothes are damp when cycle ends and they are not warm. what do i need to fix this?
if the clothes are damp then I would disconnect the vent tube, and dry a load of clothes. If they are dry then the vent needs to cleaned. Hope this helps Tim
Feb 06, 2011 | Fisher and Paykel DEGX1 Electric Dryer
Hotpoint nvl333gyoww gas dryer's timer stopped working and ran for an extended length of time (about a day). After looking over the dryer, i noticed that during the no heat cycle the timer would work. So...
the timer : if you use time dry the timer should always move and complete the cycle. if you use auto dry the timer uses a sensor to tell the timer to move. If your not getting any heat your sensor might not tell the timer to move.
So lets start with the no heat problem. First make sure your Vent is clear or just disconnect the vent and put a pair of womans stocking over the end to keep the dust down, This will ensure you do not have a blocked vent. ((( If you have a blocked vent on a gas dryer the safty sensor will shut off the gas valve and you will only get a little bit of heat))) Now try the dryer for small load, ((( if this solved your problem then you have a cloged vent )))
If this did not solve your problem then the coils on your gas valve in the dryer are probably bad.
Sep 02, 2010 | Hotpoint NVL333GY Gas Dryer
I have a hotpoint dryer ctd40, it seems to eb
either your heating element,hi-limit switch,cycling switch, thermal fuse, or missing one leg of input power i.e.120volts instead of 240 volts
Oct 29, 2009 | Dryers
Dryer is spinning and warming up but it's not drying
Exhaust full of lint. Vacuum into dryer exhaust as far as you can, Then clean out complete vent from dryer to outside. Any lint will catch moisture and clothes will not dry.
Jul 21, 2009 | Dryers
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Oct 05, 2008 | Washing Machines
My gas dryer only heats up the first time...
replace both coils on the gas burner (the round black dohickeys)after first ignition they tend not to pull valve open next time heat is called for
Jun 06, 2008 | Hotpoint NBXR463GBWW Gas Dryer
Hotpoint NBXR463EBWW Electric Dryer Logo
185 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Archie Ferrarini
Archie Ferrarini
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
