Question about Canon Powershot SX110 IS Digital Camera 9.0MP
Help - taking pictures with Canon Powershot sx110 is and it froze - no power - lens is stuck out and can't turn on / off. changed batteries and still nothing
kram26
  • 544 Answers
SOURCE: how to repair lcd screen canon powershot sx110-is
hi,
For that camera that died, here are some non-intrusive simple fixes that you should try before throwing in the towel. Copied this first post from somewhere. It was a fix for a Canon A520, but am not sure if it would work for other cameras with the same problem? For those of you with a camera that will not power up or turn on, especially if this occurred after a power interruption with your lens extended, please give it a try. If you do, please leave a comment on specifics like your camera make/model, and whether it worked for you or not.
"DEAD CAMERA, LENS OPEN-If the batteries run down completely while the camera is still open, it may not start up again when new batteries are installed. But if you remove the memory card, then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time."
OK, so the above didn't work. Next thing to look at are the batteries themselves. Are you using alkaline batteries, or worse yet those "Super Heavy Duty" batteries? If so, betcha we've just discovered your problem. Alkaline and regular "super heavy duty" batteries just don't have the power for more than a few pics in a digital camera. Some may even have problems just powering startup of the camera. It doesn't matter if they're new, and right out of the package. Digital cameras for the most part should only be used with rechargeable NiMH batteries (if you still have your instruction manual, open it to the "batteries" section. Pretty sure you'll see a statement similar to what I've just said). Most retailers sell NiMH batteries for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
OK, so maybe those newfangled batteries didn't fix your camera, don't give up just yet. The next thing to check is that your batteries are actually making contact with the battery posts, and that these posts are clean. If not, bend the posts up/down a little, and maybe clean them with a little rubbing alcohol on a Q-tip.
The next thing to try is examine both the battery and flash card door. There's usually a little switch on both doors (note some SD card doors do not have this switch) that activates when the doors are closed. If they don't, the camera won't start to prevent damage to the flash card or camera startup sequence. For most cameras its usually a little piece of plastic on the door that pushes in on a pin switch when the door is closed. Closely examine both doors to try to identify these switches. A lot of times that little plastic nib wears down or breaks off, but can easily be jury rigged with a small glued-on replacement.
If you've tried all of the above and still no luck, the problem is then likely to be internal to the camera. Am planning on posting sometime in the future some likely things to check, hopefully with a pictoral guide. One example would be that if your camera uses Compact Flash, check to make sure all pins are present and aligned in the card slot (if bent, simply unbend/straighten them with a skinny "jewelers" screwdriver, then insert the flash card for final realignment).
As before, if one of these simple fixes worked in your particular case, please leave a comment on your camera's make, and which fix worked.
Good Luck!
Camera Repair please don't forget to rate our answers..
Posted on Feb 19, 2009
xscrewdriver
  • 246 Answers
SOURCE: How to set self timer and take picture
Press the self-timer button and use arrow buttons to select the delay time, press MENU to confirm. More detail please read the user’s manual on page 68.
Here is the link of the manual http://gdlp01.c-wss.com/gds/0300001224/PSSX110IS_CUG_EN.pdf
Posted on Jul 09, 2009
SOURCE: Lens won't close.
I just found the culprit causing my camera to do the same. Under the battery door there is a post that hits a switch. That switch needs to be activated when the door is closed in order for it to work. Safety feature to allow someone not to put in a SD card while camera is on.
Posted on Aug 14, 2009
SOURCE: Canon Powershot SX110is: problem with the batteries
Make sure you are using Lithium batteries. Alkaline batteries will go dead immediately in this camera. I've tried it.
Posted on Nov 10, 2009
mandygirleag
  • 3 Answers
SOURCE: My Canon Powershot G9 suddenly
This is a really common problem on the G7 and the G9. They get no power all of a sudden when two screws from inside the camera get loose and cause a short. It's not a cleaning as was suggested, your camera actually needs to be repaired. There's a great shop that only specializes in service for the the Canon Powershot cameras and they have this exact fix on their site. They charge $89 for everything. That takes care of parts, labor, the services for the G9, return shipping and they give you a pretty good warranty on the whole camera once it's been serviced. The cool thing with them is they do the correction to the two screws inside the G7's and the G9's that causes this no power problem. Here is the site where you can have it serviced: www.camerasandparts.com Everything comes out to $89 and they are awesome for service on the Canon Powershots. I hope this helps, all the best with it.
Posted on Nov 25, 2010
My canon powershot sx110 is is only taking black pictures. any suggestions on how to fix this?
Have you downloaded pictures to your computer to see if the pictures are ok, and it's just the display? If not, worth testing. If pix are ok, then it's just the display that's bad. If the pix are bad, get new camera.
Jun 24, 2014 | Canon PowerShot SX110 IS Digital Camera
I was trying to take pics yesterday, and my daughter pushed the camera out of my hands while the lens was extended(digital Canon Power Shot SX110)... Now, the camera is messed up saying, Lens Error......
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Sep 11, 2011 | Canon PowerShot SX110 IS Digital Camera
Hi my canon powershot sx110is,has a problem when i try to zoom in or out the camera shuts down and it says lens error,restart camera i tried new batteries taking out all the batteries etc help please
Hiyour unit might has in zoom control gear unit or zoom in and out detecting sensor area. this type of problem might has two solution to technician. first is change defective gears. second is a whole lens unit replactment. either or any other problem of this type of camera they just charge you around $65 to 115 depend on what your local repair shop want to charge.
Jun 03, 2011 | Canon PowerShot SX110 IS Digital Camera
All of the pictures are grainy and very dark- not usable camera at all- less than 2 years old I have re formatted the SD card, changed the batteries, and reset the camera to default settings
To fix your issue with the Canon Powershot SX110 IS Digital Camera, try cleaning the lens. A huge issue with malfunctioning pictures can be as objective as a dirty lens. If that doesn't solve the issue, try to make sure that your flash is working to its full power. If you are taking a picture in a low-light area and the flash isn't giving off a strong enough light, this will cause grainy/noisy dark photos. Lastly, try playing around the with settings on the configuration screen. Sometimes digital cameras can malfunction, even after reformatting, and will apply alternate settings from what you originally had set.
Hope this helps!
-Anonymity
Feb 24, 2011 | Canon PowerShot SX110 IS Digital Camera
Took a shot with flash, the camera just died, no sign of life, lens stuck open. Changed batteries, with and without card, nothing makes a difference, not a sign of life.
I searched for 'no power' under the faq's for the Canon Powershot sx110 Digital Camera on the canonusa.com site and got the following result:
Issue: Lens will not extend when camera is powered on. (No error Message)
Solution: The PowerShot SX110 IS requires service.
Unfortunately, the issue you describe seems to indicate that your product requires repair service. Canon has excellent service options and we are eager to provide any assistance you may need. Links to the service options that are available for your product are listed below:
Request a Repair Online You can conveniently pre-arrange repair service with a Canon Factory Service Center through Canon's website. Find a Service Location Search to locate a repair service center and obtain further instructions. If you still have questions about the issue you are experiencing, a Technical Support Representative will be happy to answer any question you may have. You can contact us through the email link or phone numbers listed below.
  • Obtain Support by Email
  • For toll-free technical support, please call 1 (800) 828-4040 begin_of_the_skype_highlighting 1 (800) 828-4040 end_of_the_skype_highlighting during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 pm. EST, excluding holidays).
  • Toll-free TDD Support Line for the Hearing Impaired is available Monday - Friday (excluding holidays) at 1-866-251-3752 begin_of_the_skype_highlighting 1-866-251-3752 end_of_the_skype_highlighting
  • Technical Support is available for Customers in Canada at 1-800-OK-CANON begin_of_the_skype_highlighting 1-800-OK-CANON end_of_the_skype_highlighting
We look forward to helping you rectify the issue you are experiencing and are always available to provide any assistance you may need.
Dec 02, 2010 | Canon Powershot SX110 IS Digital Camera...
I have a powershot sx110 is and while using it today it was fine until ai tried it again and it displayed the error, "lens error, restart camera". It won't restart though. Help!
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 31, 2010 | Canon PowerShot SX110 IS Digital Camera
Everything appears to be working on my camera however i cant see anything on the viewfinder its always black. I can look at pictures ,take pictures with flash, but they are black, please can you advise
If your camera is an SX110 IS, A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
However, if you made a typo, and your camera is really an SD110, the problem would then likely be a defective CCD imager. If so, Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
Feb 16, 2010 | Canon PowerShot SX110 IS Digital Camera
"lens error, restart camera" for canon powershot SD1200IS
problem in canon digital camera ixus 95 is
Do not open Power has never changed the battery and another also does not start
Oct 11, 2009 | Canon PowerShot SD1200 IS / Digital IXUS...
Canon PowerShot SX100 IS Lens Stuck
If the lens does not extend/retract when the camera is powered on, then lens assembly is damaged.
Unfortunately, such Canon SX100 (and the SX110 too) has a very fragile lens assembly, and it's damaged very easily. Most of the times the internal gears, the plastic post guides and the motor are damaged at the same time, so the only solution is to replace the whole lens assembly.
The lens replacement requires a qualified camera repair technician, unless you want to try in repair it yourself, which requires tools (scredrivers, soldering iron, desoldering tool, magnifier glass with light, etc).
Best regards,
Oct 14, 2008 | Canon PowerShot SX100 IS Digital Camera
Camera froze whilst taking pictures, lens stuck.
It happend to me also. I think it is caused by the lens mechanism. It is stuck and it disabled all other functions.
Jan 02, 2007 | Canon PowerShot A75 Digital Camera
Canon Powershot SX110 IS  Digital Camera 9.0MP Logo
22 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
