Question about Samsung SPH-i500 Handheld
Flashing Display on Samsung i500
My cell phone is flashing.  Tried to reset sevearl times.  Tried removing the battery, and replacing.  Tried turning off an restarting.  When I hold down the reset pin (from the stylus,) it stops flashing.
Is there a secret code to reset, or is the phone just dying??
Thanks
David
  • Anonymous Apr 22, 2008
    removed the battery to read the back serial number then when i replaced it the phone started flashing and would not function--still havent figured out what to do in order to save my phone numbers--VM
  • Anonymous Jun 17, 2008
    My Samsung is flashing even after the battery has been removed.
I have had the same problem... twice.  First time I held down some keys just trying desperately to get it to come back to life.  Well I hit the right combination for a hard reset.  So I lost all my data.
Second time I took my phone into the Sprint Store across from Sprint HQ in KC.  The only thing they knew to do was a hard reset. I'm suspicious since I was having trouble removing my battery the second time, that my battery's position may have caused some type of short.  Still searching. KC Ron
Posted on Apr 09, 2008
Battery ran out, I have charged it but only windows icon flashes and won't turn on?
is the battery showing fully charged ?. If it is remove the battery for a few minutes then replace it this will reset it without any data loss .
Oct 13, 2014 | Cell Phones
My samsung galaxy S showcase i500 keeps powering on and off it won't do ANYTHING else!! help!
@nicole you have to make sure that your battery is charged before turn on if its doin the samething the just take your phone for flashing.
Jan 06, 2012 | Cell Phones
Where do I find my serial number from a sumsumg galaxy s i500 ?
Turn the phone off. Turn the phone over. Remove the back cover. Carefully remove the battery. The serial number and mac address ar printed on the tag under the battery. Write it down. Double check all alpha/numbers. Replace the battery. Replace the back cover. turn the phone back on.
Hope this helps.
Bob
Sep 10, 2011 | Accessory Export Samsung Fascinate /...
Samsung c140 dead
PHONE IS DEAD WON'T COME ON
If the mobile phone does not switch on, it is called a dead mobile.
It can be due to many reasons
1. Water damage
2. Fall down
3. Not used for a long time ( Mostly battery is down)
(1) Check the Battery. It should show 3.7 volts or as written on the battery.
(2) Check the Battery Connector
Check two things (a) Voltage coming or not (b) shorting
Note : If there is shorting then clean the circuit in ultrasonic cleaner (Remove display, camera, etc before putting it in ultrasonic cleaner )
Clean the circuit with a soft brush and make it dry with a hair dryer or ****er.
If the shorting doesn't go it may be due to shorting in an ic,capacitor or circuit. if shorting is in ic u can check it by attaching a battery then press the on-off switch keep the battery for 10-15 seconds. after that remove the battery and check which ic becomes hot. Reball or replace that ic. If shorting is in circuit it must be removed by ultrasonic cleaner
Note - The circuit is made of three layers. if there is shorting in the middle layer it cannot be removed
(3) Check the On/Off switch & voltage at on-off switch
Note - Connect a charger. If charging is shown on display then the problem is with the on/off switch or software problem
(4) Try flashing the mobile.
(5) If flashing cannot be done then there is hardware fault we first dry solder the Flash IC & RAM IC and check in the Software. if flashing cannot be done then we dry solder/reball/replace flash ic & RAM ic.After that dry solder/reball/replace Power IC, Network IC, Crystal, CPU :D:D
Jul 18, 2011 | Samsung C140 Cell Phone
My samsung jet will not turn on
1. Water damage
2. Fall down
Jun 15, 2011 | Samsung Jet S8000 Cell Phone
My samsung gt-c330k phone has started saying "connecting with pc" for no reason as have not tried and have no cable cannot get it to stop saying this message and it is unusable, have tried...
my phone is flashing memory card removed, (there is no card in this phone that I know of) turned it off and on, taken battery out but still flashing. Unable to select any menu and unable to unlock phone from holding button on screen
Apr 27, 2011 | Cell Phones
Display screen going whitish in colour
Change the mother boardof the cell phone
Jul 11, 2007 | Samsung SGH-X700 Cellular Phone
Samsung SPH-i500 Handheld Logo
152 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
