Kenmore 110-4563291 washer. need coupler part number and no one at sears in washington can find the model number supplied on the lid.....the washer was purchased in canada. help.....i want to fix my washer. thanks
  • Washing Mach... Master
  • 22,326 Answers
Try looking on the company web site as they may be able to post you one ,if you take the old part in they can match it thats for sure because although that model might not be listed you can bet your last dollar that the machines are the same inside with the same components
Posted on Dec 12, 2009
12 year old kenmore elite topload washer - replaced the coupler - works fine except makes horrible noise in any spining cycle- seems to be a rubber belt or gasket around the tub drive area but can't see...
ok lets see if i can help you out,, first the model number ( on most models) is on the inside of the lid, or raise the lid and look on the rim of the washer under the lid,, if its not there it may be on the back of the unit,, or in some cases its gone, fell off , wore out, ect.. second,, if the motor coupler went out then it may be a issue with your trans,, ive seen alot of these where the trans starts to lock up, or the bearings on your shaft start to seize, break the coupler
Jan 19, 2011 | Kenmore Washing Machines
With my old washer I was able to open the lid and it continued agitating. My new one does not allow me to open the lid while it is agitating. Is there a locking mechanism?
Whirlpool / Kenmore washers use a "Lid Switch" as a safety device.
On older models the switch would stop the spin cycle when the lid is raised.
Newer models stop both the Agitate and Spin cycles.
If this is a Sears washer see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Oct 21, 2010 | Kenmore Washing Machines
I have a kenmore top loading washing machine #22811. It filled with water, then stopped working & made a buzzing sound. Now it is not making the sound, but is also not performing any other tasks:...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
NOTE: THE "STOCK NUMBER THAT YOU QUOTE IS FOR SEARS TABLE SAWS OR ROUTERS. BE SURE TO CHECK THE EXACT MODEL NUMBER.
Two possibilities: None of the suggestions are very expensive.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the washer still doesn't work, check the motor coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the
transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or
spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Aug 05, 2010 | Kenmore 24032\24036 Top Load Washer
I need an owners manual for troubleshooting for a kenmore 70 series model 110 20722, serial CK4011186, type 111 When it spins out the wash water and rinse water not all of it goes out? Does it have a...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
Based on the 20722 Stock Number, the following might be the Sears diagram site for your washer. Check under the Lid for the exact model number:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20722990&pathTaken=partSearch
Two possibilities:
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the motor coupler is OK, the problem could be the clutch:
Sears has a replacement clutch band kit.
See the following for how to pull the pump, motor and transmission.
You DON'T HAVE TO PULL THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=65fc1c013d6130868b14c8bb4baf7bfd
Also see the Whirlpool / kenmore service manual for these washers.
Both the Motor coupler (available from most appliance parts stores) and the clutch band kit are relatively inexpensive.
See the Following Whirlpool parts list for alternatives to the Sears part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
These models don't really have a filter but I'd check the hoses to and from the pump and inside the pump to look for any obstructions in addition to the Motor Coupler (about a $20 part) and the clutch.
Jul 01, 2010 | Kenmore Washing Machines
Replaced Kenmore 90 coupler - now NOTHING works!
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
The first and easiest question is: Did you remember to re-connect the Lid Switch???
If it still won't agitate or spin, I'd check that the Motor coupler was installed correctly and hasn't destroyed itself.
I'd also test the switch.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
May 31, 2010 | Kenmore Washing Machines
My husband replaced the coupling on our kenmore
I'd verify that the Motor Coupler is installed correctly first.
I'd also verify that the Lid Switch was re-connected after replacing the coupler. (A common oops that I've done myself)
If it was, I'd test the Lid Switch by jumping the two outermost contacts with a short piece of insulated wire.
See the Whirlpool Service manual for their top load, direct drive washers for how to bypass the switch.
Apr 27, 2010 | Kenmore Washing Machines
Kenmore Washer 90 Series Super Capacity will not agitate or spin.
http://appliancejunk.com/forums/index.php?topic=3437.0
Yes, you have a direct drive coupling problem. Use this video to replace your part.
EZPZ.
Aug 13, 2009 | Kenmore Washing Machines
Kenmore washer, 110.22722100, won't spin
It may be the coupler. see my link to sears parts for exploded view. coupler is number 13. The coupler is behind the motor and will need the main cover (case) removed to replace it. Inspection is also easier with the case removed. It's an $18.00 part and a bout $90.00 in labor to hire it done. I can help. http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22722100&pop=flush at this link choose BRAKE/CLUTCH/GEARCASE/MOTOR/PUMP
Jul 03, 2009 | Washing Machines
Need a diagram for a lid switch
Hello jafarrell
What is the exact model # ?
This was the part number!!
You said, you need a diagram of the Kenmore top loading washer, model 20432 lid switch.
This is a Kenmore part # you supplied, so here is where you can get it from Kenmore.
Part # 20432 lid switch as you supplied in our communications!.
http://www.searspartsdirect.com/partsdirect/retrievePartActionHome!search.action?productGroup=N%2FA&partNumber=20432&pop=flush
Thank you for using Fixya.
Huuum
Please remember to leave a rating
Sep 18, 2008 | Kenmore 22422 Top Load Washer
I need help also.
The model number should be located around the tub opening somewhere. The part you are describing sounds like the lid strike and/or lid switch. If you can doublecheck and provide me with a model number, I can locate the parts for you. If you wish to repair this yourself I have step-by-step instructions at the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
The lid switch usually costs about $25, while the lid strike costs about $10. A repair of about $35 may change your mind about buying a new one. I hope this helps you. Post back if you have further questions, or need more assistance.
Apr 28, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
104 people viewed this question
Top Washing Machines Experts
