Question about Webroot Spy Sweeper (spysweeper) for PC
Getting program to work
Ikeep getting program compatibility assistant coming up on my computer and saying my computer is not compatable.
When i click on acer cystal eye webcam then i show the instruction the webcam was not found
Posted on Jan 21, 2008
Hi, I just bought the Sabrina Spellbound CD-ROM which is compatible for Windows 95/98, but I have a Toshiba laptop with Windows Vista. It won't launch, please help!!!
Have you tried running the game in compatibilty mode? If not follow these steps.
1. Navigate your way to "My Computer" > "Local Disk (usually C:) > "Program Files (x86)" > and then the folder the program is stored in.
2. Right-click on the program launch icon and left-click on properties.
3. Click on the "Compatibility" tab.
4. Check the box that says "Run this program in compatibility mode for:"
5. Click on the arrow pointing down and select a previous version of Windows which you know the game is compatible with.
6. Click on "OK", and try to run the game again.
Hope this helps. If not, let me know the outcome and I'll try to assist you further.
Jul 08, 2011 | Disney Interactive Sabrina The Teenage...
Drivers not compatible with window 7
Hello Witonada, what type of driver issues are you having, Windows 7 comes loaded with a compatibility assistant that will install native xp or vista drivers for windows 7. to do so put the driver on your desktop, right click and choose the capability assistant then select try recommended settings, This option allows us to test run the program to see if the new compatibility settings fix the issue. Click on Start the program to begin testing it out. After testing the program and determining if the settings work or not click on Next. This will finish your new installation. In some instances the assistant may ask if the program worked in another platform say yes and choose windows xp sp3. walla your all set .
May 25, 2011 | Computers & Internet
I can't get Calendar Creator 12.1 to run on my windows 7 64-bit system
Windows 7 Compatibility for Broderbund Calendar Creator version 12 :
32-bit(compatible) and 64-bit(We are working with the software publisher to confirm this product's compatibility) -->click HERE! to navigate .
Run the program in compatibility mode:
1.Right click on the program's shortcut, .exe file, or installation program;
2.Click on Properties.
3. Click on the Compatibility tab. (see screenshot below)
NOTE: If the Compatiblity options are grayed out, then it is a 64 bit program and cannot be changed.
You can use windows xp mode to run calendar creator .
Please navigate to this page click HERE! and follow microsoft instructions ..
Please let me know if you need any further assistance.
Dec 29, 2010 | Broderbund Calendar Creator 12 for PC
I'm trying to run my Hypertech ECON programmer for my 2010 Silverado, when I install the disk it gives me a error code 2869 and exits me out of the install. Am running WIndows 7
It seems that Windows 7 is not compatible with this program and thus the error 2869. the program in the Program Compatibility Assistant utility in Windows 7.
then select the caption that says it ran on a previous Operating system ( that is Windows XP/ Vista etc. and select the radio dial to the left and click apply.
Instruction from Windows help:
Run the Program Compatibility troubleshooter
Click to open the Program Compatibility troubleshooter.
Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
Sep 25, 2010 | Computers & Internet
I can't upload john deere drive green on my computer witch runs vista but it worked on the inlaws computer which is XP and the game says it should work on vista
Hello, If you have a program running programs since you've started using Vista, you may be able to fix that easily by running the program in XP mode.
Step 1
Locate the program you want to run, right click on the program's icon on the desktop, or in the start menu.
Step 2 Once you right click on the icon, click on properties at the bottom of the window that comes up.
Step 3 In properties, click on the Compatibility tab. Check "run this program in compatibility mode" and select Windows XP in the drop down menu. Also at the bottom of the compatibility tab, check "run this program as administrator".
Running as administrator will cause windows to ask if it's okay to open the program everytime you click to open the program. Nothing wrong with it, but just be aware.
Aug 02, 2010 | ValuSoft John Deere Drive Green for...
I bought keyboardworks v1.1 it worked fine for my old xp computer. Now I switched to windows 7 and it does not work. Any fixes?
Since this software was designed to work with Windows XP or earlier. It may not run in windows 7 normally, but you can run this application in Compatibility mode.
Windows 7 comes with Program Compatibility troubleshooter, using which you can run older programs in compatibility mode.
To run the Program Compatibility troubleshooter
1. Open the Program Compatibility troubleshooter by clicking the Start button and then clicking Control Panel.
2. In the search box, type troubleshooter, and then click Troubleshooting.
3. Under Programs, click Run programs made for previous versions of Windows.
4. This would scan the computer for incompatible applications and list them, keyboardworks .
5. Click next. this will try running in Windows XP mode.
6. If sucessful save the setting and u should be good to go, else try installing this application in Compatibility mode.
7. right-click choose properties on setup.exe
8. click on compatibility tab. put a check on run this program compatibility mode for and choose windows XP
9. put a check on run this program has administrator. cluick apply and ok and install this application.
10. run the application, if it does not work repeat the steps 1-6.
May 18, 2010 | Computers & Internet
Medieval lords not running
Hello wilsonpaul74
As far as I know, there isn't a patch for Windows 7. Have you tried running it in compatibility mode? There are two ways to do this:
1. Right click on the programs shortcut, .EXE file, or installation program, and click on Troubleshoot compatibility. N.B. You will not have the Troubleshoot compatibility option available for pinned items in the Start Menu or on the Task Bar.
2. The wizard will now give you a list of options to choose from. Try each individual option, following the on-screen instructions.
If this doesn't work, you can try the following option.
1. Right click on the programs shortcut, .EXE file, or installation program.
2. Click on Properties.
4. Check the Run this program in compatibility mode for box.
5. Click on the drop-down menu arrow, and select which version of Windows the game was made for. N.B. Always pick the latest Windows version the game was made for a better chance of it running properly.
I hope this helps. If you require further assistance, please don't hesitate to ask.
Apr 28, 2010 | Monte Cristo Medieval Lords for Windows
Vista compatibility problems when trying to install set up program for yumi pro mp4 player v 4.05 get message blocked due to known compatibility problems
Copy the installation to your hard drive.
now take the properties and setup it for windows xp under the tab compatibility.
now run your application with administrative privilage. right click then "Run as Administrator'
Vista's Compatibility assistant is known to have a lot of bug.
if it didn.t work then
Press the keyboard combination "Windows Key +R"
you will have run dialogue box
type in "services.msc"
in the window that appears look for "Program compatibility assistant" and then disable it.
now restart your computer and try installation
it will be fine
its recommended that you switch your os to windows 7 from vista as windows 7 is more bug free and crash is unlikely to happen
Jan 08, 2010 | Sumvision Yumi Pro Digital Media Player
Im trying to intall webcam but it says it not compatible when i put the webcam disk in it does not come up with anything. how do i get this to work?
Your only solution at this point is to go the manufacturers web site and see if there is a down load for a version that is compatible with your version of Windows. You could try to install it using compatability mode but I wouldn't. It is better to get the correct version. If that is not available then put the cd in and when the autostart window appears click cancel then open explorer. Find the setup file on the cd and right click it. Go to properties and select run in compatability mode and select the version of windows the program is compatible with.
Sep 09, 2009 | Computers & Internet
After I installed Easy Media Creator 10 a "HP Cue Status has stopped working" popup window comes up on my screean and says it well close the program and will close and I will be notify when a...
This means this program not compatible with Vista.
You need to uninstall the program, and reboot the system.
Now there is a way to install with XP compatibility, 80% of the time this will work. (if this does not work, you will just have to find the version of the program that works with Vista)
To install with XP compatibility:
Running the Vista Program Compatibility Wizard 1) Click on Start
2) Click on Control Panel
3) Click on Programs
4) Click on Use an older program with this version of Windows.
5) Then just follow the instructions in the Wizard.
Insert the installation disc for the program. Open the Compatibility Wizard. In the Wizard, browse to the program's setup file (Setup.exe, Install.exe, etc.)
Aug 05, 2008 | Computers & Internet
Webroot Spy Sweeper (spysweeper) for PC Logo
29 people viewed this question
Top Webroot Computers & Internet Experts
Are you a Webroot Computer and Internet Expert? Answer questions, earn points and help others
