Question about Tricity Bendix AW1000W Front Load Washer
Bendix wdb1074t can not get door open and manual inside with hoses
3 Suggested Answers
  • 213 Answers
SOURCE: Bendix washer-dryer door won't open
if you remove the panel in the front lower right hand coner of the washer you should be able to feel around in there for a plastic cord. pull the cord to manually unlock the door
Posted on Nov 25, 2007
This solution worked for me. By removing the 2 screws holding the filter in place I could turn the filter and push it back into the machine. I could feel a thick cord which felt more like electrical cable but, by feeling around the area where I judged the lock to be located on the inside, was able to locate the actual catch and release it. Thanks Chris72! This saved me a lot of money on a service call and much frustration at not being able to get to my clothes for several days - the earliest the repairer could come.
Posted on Dec 10, 2007
Replace door seal on tricity bendix 1000rpm it just come off
bit of a fiddly one it has 2 clips around the door seal one on inside one on out side
Jan 21, 2015 | Tricity Bendix Washing Machines
Tricity bendix user manual
I have never failed to find a manual online. Go to bendix web site and search model.
Aug 22, 2014 | Washing Machines
Where is the filter on a AW1560W washing machine
There is a small 4 inch square door on the bottom right of the front of the machine. Press the right hand side of the door and it will pop open. Pull out the small drain hose, drain off any excess water, unscrew the corcular filter cover to extract it. Instructions and pictures can be found on page 17 of your user manual. If you do not have a manual, you can download one here:
http://www.usersmanualguide.com/tricity_bendix/washing_machine/aw850w
Please rate this solution
Jul 21, 2011 | Tricity Bendix AW850W Front Load Washer
My bendix washing machine door does not open after wash cycle ha finished
  1. Is there still water in the machine when the wash cycle has finished? If so, the door doesn't open because there is still water in the machine. Try clearing the filter at the bottom of the machine, in the front. If this doesn't work, check that the drain hoses are cleared. If it still doesn't work, try replacing the drain pump.
  2. Is the "door" light still on? You may have a faulty door lock assembly, or your control board may be faulty.
Feb 27, 2011 | Tricity Bendix AW1400W Front Load Washer
I have mislaid my manual. i am trying to clean the filter of my tricity bendix 1000rmp washing machine. I opened the small door at the bottom right of the machine and unscrewed the cap inside . now the...
Make sure the filter and the housing are clean and that there is no grit or similar on the seal, if it still leaks, then you may have to fit a new filter and or seal.
Nov 05, 2010 | Tricity Bendix AW1000W Front Load Washer
I want a complete door for aw850 tricity bendix washing machine
Hi
Can you please give me a product number for this model as there are two or three versions of door.
The product number will start ENr No: 9.................. Possibly found on the inside of the door, a label on the front of the machine next to the door seal or inside the filter flap.
Regards
Aardvark Repairs
aardvark.repairs@btinternet.com
Nov 18, 2009 | Tricity Bendix AW850W Front Load Washer
Tricity Bendix AW1400W front load. Water leaks onto floor (a lot). Hoses dry. Pump and drain hose OK. Running the program causes leak. Pouring water into soap dispenser drawer causes leak. Just pouring...
Ether the washer is over filling or has warn out the seals. If it has been abused (overloaded) it needs serious work. other wise the sensor may be stuck. Try 1/2 cup of vinegar with a load and see if that cleans the sensor travel area past the drum but inside the tub. This is a common problem for an old machine. Best leak is on the door and you may be able to tighten the screws but be careful it could mis aligne it so tighten a small amount and test by closeing the door. Do this at least twice before turning the screws hard.
Aug 17, 2009 | Tricity Bendix AW1400W Front Load Washer
Nov 24, 2007 | Tricity Bendix WDR1040W Front Load Washer...
How does this machine work??
Check your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
chassg,
It is normal for the door to release after 2 or 3 minutes, its a precaution set by the machine; do not force the door. And surely the cycle must end for you to have a nicely washed clothes. Don't try to stop front loaders inbetween, less probs for you.
Nov 19, 2007 | Tricity Bendix AW1054 Front Load Washer
Washing machine makes beeping noise
It sound like a lid switch problem .A defective lid switch will notice of an open door when actually door is physically closed, and will prevent washer's spining and function at all. The switch located inside the machine near the door frame. You should open the top panel (open 2 screws and then slide it out) and you will have an access to it . You can test it by multi-meter (it is an on/off switch). In case of a deffective switch, it should be replaced. Be aware that you should remove machine's power cable before starting your test !!!! Good luck !!!
May 30, 2006 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix AW1000W Front Load Washer Logo
90 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
