Question about Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
The picture on my tv freezes approx every minute but the sound carries on normally. This is a fairly new and modern tv. Any suggestions?
  • Sony Master
  • 8,457 Answers
This tv using free air?Tries better antena like roof antena or buy a digital antena.
Posted on Dec 12, 2009
SOURCE:
The sound on my TV keeps cutting out. It cuts out for 1-2 seconds. It does this approx. every 30 seconds. I have changed cables and cable box....no change. Any suggestions?
Sounds like the final audio amp MOSFETs are overheating.
After set has been off and unplugged check for dirt and dust clogging cooling fins and parts. Air must circulate for cooling. Remove dust with a gentle blast of air or an upholstery brush attachment on your vacuum cleaner.
If this doesn't work the parts usually cost more than a modern set is worth and I suggest purchase a new set.
Nov 26, 2015 | Televison & Video
Picture fades to black
Find the vertical IC and check for very small cracks on the solder joints of its pins and resolder (approx. 10 Pins). Also check in the same area for a 1 micro farad at 50 vdc capacitor that goes bad and replace it.
Dec 18, 2013 | Toshiba CX32F60 32" TV
Horizontal lines and no picture or sound after approx. 5 minutes
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jul 10, 2012 | RCA Scenium HDLP61W151 61 in. HD-Ready...
When I first turn on my Technika tv I get sound but no picture. After hitting the top of the tv it comes on. After a further few minutes the picture freezes and eventually fades away. Further hitting of...
The dreaded loose connection syndrome, this could be easy or hard to trace, only solusion is checking circuit boards for bad connections , it may be also capacitors in power supply neading replaced, not a novice repair
pete
Nov 11, 2010 | Televison & Video
I recently purchased a new Samsung Blue Ray player. My previous Sony DVD player used the blue,green, red cords plugged into DVD imput, and I used Coaxial for sound. The Blue Ray only uses HDMI, which the...
Optical carries only 5.1 sound, no video. HDMI carries both video and sound. If your receiver doesn't have HDMI, check your TV for optical output. You can go BluRay to TV via HDMI, then TV to receiver via optical.
If you don't have optical out on your tv, you're going to need either a receiver with HDMI or a BluRay player with component output (blue, green, red).
Dec 06, 2009 | Sony STR-DG500 Receiver
Apologies to Andy Hi Fi and tvtek who both answered this query yesterday, but I gave out the wrong model of tv. My set takes about 5 minutes to produce a picture, which is then as good as ever. Sound comes...
This fault sounds very much like the CRT (Cathode Ray Tube) is approaching the end of its life. If you can find a TV engineer in your area - preferably one from "the old school" - he may well have a "Tube booster". This sometimes works to "rejuvenate" old CRT's but can also unfortunately, bring an abrupt end to the tube, because it involves passing a higher than normal current through the tube heaters.
Environmentally, it all depends on the age of your current TV and the size of the screen. If it's a fairly large screen, (32") it will probably consume around 250 to 300 Watts of electricity. Modern LCD TV's are more efficient, however gas plasma TV's tend to use slightly more power than LCD models.
As you will know, TV's don't use that much power in comparison to say, a cooker, electric kettle, fan heater or washing machine heater so you can expect to use around 200Watts for your new TV if it has a 32" screen. Power consumption goes up of course, the larger the screen size you have, so if you bought a 40" or 50" screen you would not save anything in power compared with your old CRT type TV.
If your current TV has lasted for 20 years or more then you have done reasonably well. That's not to say that many TV's with conventional CRT's often last MUCH longer than this.
Tandberg CRT TV's have been known to still be working perfectly well after more than 30 years! Much the same with Panasonic.
Nov 18, 2009 | Televison & Video
No picture when on for approx 15 minutes
It sounds like you are saying the "video looks scrambled but the audio keeps playing OK"
Normally this is a Video Processor Problem that requires a Board to be replaced.
When the problem happens, can you see the TV menu or the TV's On Screen Display clearly.
I suggest checking to see if the problem happens with the video inputs like, Composite(yellow/red/black), component(RGB/yellow and black), HDMI and S-video. If it happens to all inputs then you need to replace a board.
May 21, 2009 | Vizio VW37L 37 in. LCD HDTV
Screen goes black
not worth fixing,techs charge at least 65.00 $ an hour not including trip charge.no easy fix. you can get new lcd flat panels for under 500$ now. especially at best buy,ther giving them away
May 19, 2009 | Sony KV-32XBR450 32" TV
Samsung HLR6167 - picture freezes
This is very common in Samsung DLPs. The DMD board is going bad. You will need to replace it.
Jan 07, 2008 | Samsung HL-R6167W 61" HDTV
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
148 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
