Question about Western Digital Caviar 500GB Internal SATA Hard Drive
I am trying to install Windows 7 on WD Caviar Green 500GB hard drive, but the installer won't recognize the drive. The drive shows up in the BIOS, and all connections have been checked.
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 72 Answers
If you've got the xp installation disk, create a partition on that drive and then use the windows 7 disk.
Posted on Dec 26, 2009
Windows 7 installation disc doesn't see SATA hard drive
If your motherboard's BIOS is properly configured for SATA controllers and you burned the Windows 7 RC1 ISO image correctly, Windows 7 should recognise and install on a SATA drive without any third-party drivers. Consult your motherboard's User's Guide for assistance in setting up the BIOS properly.
In case Still Having Problem Then Follow Us For Computer Support For On : Computer Support
Feb 06, 2014 | HP Pavilion dv6130us Notebook
My WD caviar green keeps blinking and won't show up in any way on my windows pc or macbook pro
Your WD has probably gone belly up. If you can't get it to register on either computer and you've tried different computers then it has croaked.
Were you able to use it in the past on the windows computer and the mac? If so, that's strange because they are two different formats and most times when you plug the drive into one or the other it will want to reformat it to be able to access it.
Jun 05, 2012 | Western Digital WD Caviar Green WD5000AADS...
How to install windows 7 on a Western Digital Caviar Blue 640 Hard drive
if your computers motherboard is older than 5-6 yrs you might not be able to load windows 7
and you will need a minimum of 2GB of RAM
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you should go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps you
Sep 18, 2011 | Western Digital Caviar 500GB Internal SATA...
Hi, I want to know how to install the WD10EARS-00Y5B1 drivers? Okay, the problem is, that my computer doesn't recognise my SATA Hard Disk. I have Windows 7 Home Premium, and another SATA Hard Drive. I...
there are no drivers required for a hard drive.
Windows 7 should automatically detect the new hard drive and it should show up in disk management to format or prompt you to format.
Check your cable connections again.
Otherwise your new hard drive may be DOA. Return it to the store that you purchased from.
Mar 26, 2011 | Western Digital WD Caviar Green WD10EARS -...
SOYO KT600 Dragon Plus mobo not recognize WD Caviar SATA 1TB HDD
Yuck! Soyo filed for bankruptcy in May and their website is gone!
You need to enable the SATA in the rom bios AND install the drivers for it; but, I hope you have the manual and the CD.
Jul 05, 2009 | Soyo Computers & Internet
Can we/should we update our bios?
I would not update the BIOS if you aren't haveing problems. If you use WinXP you should have no problems updating the Hard Drive to the 500GB, If you format the disk using the NTFS File system when you install windows, and it only recognizes 137GB of the 500GB, then update, but you shouldn't have any problems. thanks for any ratings
Mar 30, 2009 | EliteGroup ECS L4VXA2 (CDL4VXA2)...
Hard disk Recognition problem
U are actually facing the same problem as "jackwilkinso". As my previous post: Windows XP does not come out to support SATA hard drive, because inside do not inclued the SATA driver, that why u cannot see the harddisk during the setup. What u can do is try to install the SATA supported OS like Windows Vista or Windows 7, or maybe can "forcely" put in the SATA driver in ur Windows XP setup CD.
YBC (/\)
Mar 29, 2009 | Western Digital Caviar 500GB Internal SATA...
WD Caviar SE 16
Have you installed it as the main drive, ie the one with the ops system on, or have you installed it as a secondary drive? Either way, check you have the drive set up correctly as per instructions on pack. You are not alone with this problem either, it is common with WD. Come back to me with more info re your install.
Personally, I would set it up in an external enclosure and access via USB. Much more realable that way, and it is portable for you.
Apr 14, 2008 | Western Digital Caviar SE16 (WD5000KS)...
Wd800jd sata hard drive not recognized in bios on boot up
Hi, A couple of ideas: 1. There are 3 versions of this motherboard: Dragon Plus, V1.0 & V2.0, perhaps your BIOS needs an update to be able to recognize the new HD. This of course would require flashing; 2. There are two variations of a WD SATA hard drive: Serial ATA amd Serial ATA II; 3. Re Jumper settings: the eight-pin jumper block is only used to enable power management on the drive. There are no master/slave settings since there is only one drive per cable; 4. If you are fresh installing Windows on it, you need to press F6 when asked by the Windows Installer and follow on-screen instructions. Hope this be of some help/idea. Post back how things turn up or should you need further information.
Sep 17, 2007 | Western Digital Caviar SE WD800JD SATA...
New Hd HELP
I guess there is nothing with BIOS since it identify your Western Digital Caviar Hard Drive. Try changing the jumper setting of this Hard Drive by reading the Instruction that comes along when you purchase. Otherwise you can visit the Western Digital website and click on Support-Knowledge BASE...http://www.wdc.com
Apr 08, 2007 | Western Digital Caviar SE WD2500JS...
Western Digital Caviar 500GB Internal SATA Hard Drive Logo
412 people viewed this question
Top Western Digital Computers & Internet Experts
Alun Cox
Marvin
Marvin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
