Question about Whirlpool Duet GHW9150P Front Load Washer
F2 will not drain - Whirlpool Duet GHW9150P Front Load Washer
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 107 Answers
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and
"F/02" is flashed.
Most common cause is a clogged drain filter. Remove the front lower panel and remove the drain filter (often white) near the pump assembly. remove any foreign debris (socks, nails, coins, ect..)
If this does not fix it here is directly from the manual
Press PAUSE/CANCEL twice to clear the display.
* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the
pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Posted on Dec 13, 2009
F2 fault
F2 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair.
Jan 21, 2013 | Siemens Washing Machines
F2 error code won't drain
The problem is with rotor assembly of the drawer that is causing the F2 error. Turn power off. Empty water using a small container and towel to dry base.
Remove the washer arm and drain filter sump cover. Twist the rotor at the base out from the socket gently but firmly.
Clean the cavity and check the rotor for damage. Put everthing back in and turn power on.If F2 does not go away then replace rotor.
Aug 21, 2012 | Fisher and Paykel 24 in. DD603H W Built-in...
Before it starts spinning F2 comes up what does that mean?
Hello & Welcome to FixYa
F2 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display suds and then F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F2 error code flashes and machine wont finish the drain cycle
F2 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
May 30, 2011 | Siemens WXLP1460 Front Load
Hi I have a DD603 F & P dish drawer. I had an F2 fault, found the rotor motor seized. I've replaced that but F2 still comes up & the water doesn't drain away. Any ideas?
Before we talk about water not draining away, can you confirm if the wash arms rotate during the wash cycle. The rotor works as a wash pump and drain pump depending on which cycle it is in.
If F2 keeps coming then it is also likely there is some debris in the rotor cavity which is grinding on the rotor. But one needs to be sure if F2 is coming up only in drain cycle or is it already on during wash cycle.
May 16, 2011 | Fisher and Paykel 23 in. DD603H SS...
We just received an F2 error on the washer? how
Well it depends is it an F2 or an F02.. Two different codes.. an F2 code or and (F ) code could be electrical variables "F" Variables [F4 to F16] (Electrical Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START.
"FO2" (Drain Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Is the drain hose kinked?
Is the drain hose frozen?
Is the drain hose clogged?
Is the drain hose more than 96" (2.4 m) above the floor?
Hope that helps I just went to www.sears.com/parts typed your model you were missing a diget on the end picked one located the owners manual on manage my home and went to trouble shooting all else fails it says calls for service.
May 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Jan 19, 2010 | Asko D1976 Built-in Dishwasher
Wsher stops in the rinse cycle wiht a n F4 message
f2 error means long drain or no drain
replace drain pump if nessesary
Mar 17, 2009 | Kenmore Washing Machines
F2 error
f2 means the unit is draining to slow...you need to clean your pump filter...if you need help with that post to onthejob
Jan 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader
F2=Long Drain If the drain time exceeds 8 mins the water valves are turned off and F02 is displayed
Check drain hose
check pump filter for foreign objects
check pump motor for proper operation
Jul 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
150 people viewed this question
Dan Webster
Dan Webster
Sal De
