Question about Amana ARS2464B Side by Side Refrigerator
Water source is good..valve where goes in ,take line off other end nothin comes out ...it reminds me of a p-trap but has 2 fuses on top...is this clogged
  • 288 Answers
Sounds clogged. with the water line off, look into the top of the valve at the screen and see if it is dirty. It may be a bad valve also. The do go bad from time to time
Posted on Dec 12, 2009
After hot water demand, burner stays lit, blew up Pex supply line
Thermocouple has 2 ends. One end attaches to gas control valve, other end sits inside the pilot flame.
Flame heats thermocouple, causing tiny electrical current that is detected inside the gas control valve and keeps the gas valve open so water heater can turn on when thermostat calls for heating.
If pilot goes out, then no electric current reaches gas control, and all gas to burner and pilot is shut off.
If pex line burst, that implies very high pressure, caused by closed system with check valve that stops expansion, or possible clog in the water line, or high local water pressure, or clogged factory-installed heat traps.
Put pressure gauge like BTG100 on the drain valve to check pressure, should not exceed 80psi, install pressure reducing valve on cold water line, install expansion tank on cold water line. Remove heat traps and install ordinary pex-lined di-electric nipples from hardware store.
If the water was super hot, then overheating could have caused the pipe explosion.
However the gas control thermostat is ECO protected, and if ECO (energy cut off) trips because of high heat detected inside the tank or combustion chamber, the gas control will trip off and no longer work, gas control needs to be replaced. Some newer electronic gas controls can be reset, but that type heater uses a thermopile instead of thermocouple.
Thermopile is basically a group of thermocouples, that product more electric current that is used to power electronics inside the gas control valve, which issues an error code on the gas control, and some day will send a text message each time out-of-range event occurs.
Copy following links for troubleshoot resources, including troubleshoot by type of gas control valve:
http://weaterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/Low-hot-water-pressure.html
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Jul 12, 2012 | Bosch Aquastar 125B Gas Valve NG - Part...
Water & Ice Maker installation schematics. Need diagram of back of refrigerator
You need to get the model number... look up the DUAL water valves (which seem to be missing) and hook up the water & ice RESPECTIVELY
Watch those supplier videos...
Those new press connectors are a snap to
use (and release)...
appliancepartspros
Search Over 2 1 Million Appliance Parts
partselect
PartSelect Appliance Parts and Repair Help
repairclinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
kit LIKE THIS... (can't tell w/o model number)
Amazon com 2181730 Quality Replacement Dual Water Valve Kit for...
Carnac the Magnificent
May 21, 2017 | Amana Refrigerators
I have an Atwood water heater G6A-7E, heater heats up but no hot water flow after 15 seconds...Flushed system with water and air, put water to it and the hot water flow stops after a few seconds....
First check that any by-pass valves are in proper position. Remember, cold water has to enter in bottom fitting at back of tank, and hot water comes out at top fitting. Thus any valves that may be there, need to be in open position, and any valve between those 2 lines will need to be closed. If all valves are in proper position and working as they should, I would suspect you have a faulty check valve between top (hot) line fitting and tank. One easy way to check that before replacing it, would be to shut incoming water source off, whether running off pump or hose attached outside. Then relieve all pressure in system by opening taps until all pressure is gone. Now, go outside and open pressure relief valve carefully ( in case it's hot ) and make sure pressure is relieved there as well. Now, carefully hold pressure relief valve open while you have someone turn water back on, and see if you get good flow from pressure relief valve. If you get good pressure coming out of there, that tells you your tank is getting full, and you have water coming in as needed, so problem has to be on hot side ( top fitting ) and/or onward from there, which would be check valve fitting at top next to check. Remove the check valve and If you don't have a new check valve to try it, just put a short galvanized 1/2" pipe nipple in there for now if needed and that should do it, just attach your fitting directly to nipple. Before you do this, make sure you have removed all aerators etc on taps that may be plugged and tested pressure that way as well just in case. I have seen all of them plug up at same time before. If you remove them and get good pressure, then problem solved.
Nov 06, 2011 | RTO Atwood Water Heater - 6 Gal LP
My Atwood RV Water heater does not allow water to pass through. It goes in the bottom but does not come out of the top. No clogs are apparent and the plumbing all passes water. I removed the bypass valve...
The fitting at the top of tank where line connects is usually a check valve, Good chance the check valve has blown apart inside and plunger is blocking flow through it. Either get yourself another or even use a short 1/2" NPT plastic or galvanized pipe nipple to replace it and you should be good.
Jul 14, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
I just bought a used fridge of this model type. The problem I have is that no water is getting to the water dispenser, ice maker or even the water filter and reservoir tank. When I look the the...
this system is using the filter for both ice and foutain . if you have a ohm meter you can ck the two valves . or you can use a test cord to see if the buzz. .. the buzz does not mean they open but does mean they should . the problem may be the filter valve / as the ice and foutain side of the main valve never fail at the same time so look at the filter valve .. also you can use air to ck the lines to make sure there clean . some friges if sitting for a long time could have algi in the lines and this plugs them good . hope this helps mm feed back pls .. ps don't look at the foutain it self i don't think your problem is there . and rember the foutain gets it water movement from the main valve . ther is no pumps or valves after the flter valve . . try removing the lines and blow air through them mm ..
Jan 19, 2011 | Jenn-Air JSD2789GES Side by Side...
Our ice maker stopped working after our town had a water shortage and shut off supply for a period of time.
Hi and welcome to FixYa. I am Kelly.
When there is a long term water outtage all kinds of things can be introduced into your water system. Most likely there is debris in your water supply line or water valve assy on your refrigerator.
1. Turn off the water supply to your refigerator.
2. Remove the water supply line
3. Turn on the water and purge the water line. ( If there is not water coming through the line at this point the water shut off valve at the supply connection is probably clogged. ) Then reconnect the line and turn on the water.
4. After purging the supply line unplug the refrigerator
a. Make a test cord for the water valve solenoid by using an old extension cord and cutting off the end and installing female termials available at any applaince parts source or some hardware supply sources.
b. Remove the fiberboard rear cover of the unit and gain access to the water valve
c. Disconnect the 2 terminals of the ice maker water valve solenoid and connect your test cord.
d. Remove the plastic line that goes to the icemaker at the top connection by pulling down and place in a bucket.
e. Plug the test cord into the wall outlet. Water should flow into the bucket.
f. Unplug the water valve solenoid test cord. Water MUST stop.
If you do not get water flow at this point your water valve is clogged. You can either try to reverse flow with water and power to unclog it or... use LP air at a distance pointing into the top plastic line with the test cord connected to the wall outlet. If it does not clear then your only option is to replace the water valve.
g. Remove the test cord and reconnect unit wires to the water valve solenoid.
Here is a link on how to cycle the ice maker:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
Just note that there is only 7.5 seconds that water is supplied when the sweep fingers are near vertical.
Thanks for choosing FixYa.
Kelly
Oct 14, 2010 | KitchenAid Refrigerators
My 2007 Fleetwod ##0 FKDS TT has no hot water delivery, (cold is Fine) No water comes from any faucet (3), or shower(2). When hot water is tried a short squirt of water (Les than 1/2 sec ond) comes out and...
Check for faulty (broken/apart inside) and replace check valve on hot side of tank (top line) between line connection and tank. Stem, spring etc, of new one goes in facing into tank.
Jul 18, 2010 | RTO Atwood Water Heater - 6 Gal LP
Vacuum line schematic 1987 toyota corolla le front wheel drive
It is similar to my rear wheel drive two door.
The main vacuum line from a vacuum source on the intake goes to the multi-hose valve on the top and the distributor vacuum advance.This multi-valve switching valve is the main connection to the other vacuum hoses on mine. Two lines come in from a vacuum source and thre go out to three components according to tempature. On mine the middle one off to side 1)goes to choke opener and switching vacumm valves mounted on the fenders the other middle one 2)second from top goes to another choke opener and EGR Valve and EGRModulator. The bottom hose connection is on when cold 3)and goes to a part on the carburator to help it run better when warming up a AAP valve.
There is a check valve diaprham thing inline to the EGR vlave on the second line from top.
I have another vacuum line on the drivers side of the carburator that has a check vlave inline but larger it goes to the throttle linkage to help slow the closing of the trottle on rapid deceleration.126c338.jpg14b3a33.jpgf95de67.jpg9f023f4.jpga890bd7.jpg5531e92.jpg
Mar 15, 2009 | 1987 Toyota Corolla 2 Door
Burner wont stay lit
ONE THING COMES TO MIND AS YOU SAY YOU HAVE ALREADY CHANGED T/C IF YOU ARE SURE YOU POSITIONED THE THERMOCOUPLE IN EXACT SAME SPOT ,THE SEDIMENT TRAP GOOD CK AS MOISTURE COULD HAVE GOTTEN INTO LINE THIS WOULD CAUSE LIKE SYMPTOM ALSO A ELEVATED GAS PRESSURE COULD CAUSE THIS ON START UP ALSO THE THERMOCOUPLE WORKS OFF MILLI-AMP TO TELL THE VALVE TO STAY OPEN SO MAKE SURE THE THREADS ARE CLEAN FREE OF MOISTURE AND GOOD AND TIGHT OR IF ALL THIS IS GOOD COULD HAVE BAD VALVE BUT CK THESE FIRST
Jan 14, 2009 | Water Heaters
Amana ARS2464B Side by Side Refrigerator Logo
108 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
