I have a Nautilus N576-B fan that we replaced the motor in, now it has developed a loud rattle sound with the squirel cage rattling against the shroud. We have tried realignment, rubber damper, etc. to no avail. Any suggestions. What fan would take the same size rough in...
  • Washing Mach... Master
  • 8,404 Answers
Nautilus is a good brand, my favorite.
Take it all back down and clean it. Check ALL MOUNTING SURFACES, including the mounting of the mounting surfaces. Holding the fan in your hand securely, plug it in. Do you feel any undue vibration?
Do you still have the old motor? You replaced it because it was dirty or not running? You can clean it using electronics spray cleaner available from auto parts supply or electronics supply place or FixYa.com advertiser. Lubricate with light oil if you want. Test it in the samy way as I suggested above.
Reassemble the device using all the rubber the manufacturer provided and/or suggested and try again. Securely tighten all the fasteners.
Let me know what happens please
thanks
and thanks for your interest in FixYa.com
Please vote
positive comments welcomed by volunteer question catchers.
thanks
a
Posted on Dec 12, 2009
NOISY SQUIRELL CAGE ON A CARRIER AC/HEAT PUMP OUTDOOR UNIT
Not unless its a belt driven wheel. If not no grease will help just make a big mess. Take the fan assembly out, take motor off the wheel, take wheel out of the assembly wash wheel with hose, dry reassemble. Or just go buy a new wheel but check your shaft on the motor if loose get a new motor also.
Mar 15, 2013 | Carrier Heating & Cooling
My dyer is makes a loud, rattling sound.
did you find what caused the blower fan to break in the first place?I suspect the casing around the fan may not be clearing and something is in the fan again. or the keepers to keep it on the motor shaft are loose. The rollers for the drum and belt may be faulty. these are all of the parts that move so it has to be one or more of them.
Mar 01, 2012 | Amana NED4500VQ Dryer
Loud rattles in front fan and loud hummiing from unit itself along w minimal cooling and freezing up
Unfortunately sounds like the squirrel cage in the front may have broken off at the hub. This is a pretty extensive job on most window units, not all that costly (parts wise) but quite a lot of labor.
Apr 19, 2011 | LG Goldstar GWHD5000 wall/window Air...
My Rinnai 1001F has just developed a loud rattle when turned on. What's the most common problem and who fixes in Manchester NH?
There are two fans or blowers in your unit. The first to turn on prior to the flame starting. The second fan blows out hot air into the room. Depending upon when the rattle starts will dictate which fan is causing the rattle. Any good gas company should be able to help you out.
Jan 08, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have a blower fan rattling my house in the attic. I am looking for the set screw to see if maybe it rattled loose, does anyone know where that might be.
the set screw is on the squirel cage you need an adjustable wrench but as check all mounting brackets and possibly a belly band that goes around it held by a nut/bolt but that motor may not have that feature
Sep 14, 2010 | Heating & Cooling
Loud fan rattling in convection mode
On the repairs I have done, it has always been a bad fan motor bearing. The only way you are going to be able to tell is to tear it down to the fan assembly and feel if the fan blade or blower is loose. Good Luck, Appliance Specialists
Jan 17, 2010 | Ovens
Inducer Fan Seems To Be Rattling
what make of furnace check for birds and blockage
unfortunatley when they go there gone the squirrel cage wheel will not come of shaft u will need motor n wheel or a "plug n play housing all in one"
Oct 05, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Freezer fan noise rattle
If the fan bearing is not worn, which would cause the fan blades to wobble and create noise, the problem is with the sheet metal mounting plate being loose and rattling.
In mine, I just slightly bent the plate on the side that has the mounting screws. When installed, this will help apply pressure against the bottom of the mounting plate to secure it in position and not rattle when running.
Louis
Jun 13, 2009 | Sub-Zero 642
Amana Bottom Freezer
  I have found tubing rattling against plastic tray on right side in back.  Also found this tray rattling against frame.  You can take back off unit and llisten for noise.   Watch out for spinning condensor fan blade.  Very sharp,  believe me!!  Try pressing on tubing.
Oct 14, 2007 | Refrigerators
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
