Question about Philips 50P8341 50" Rear Projection Television
55 inch phillps projection tv model #55p8341
I was just wondering how to apply the feature of picture in picture on the tv....I saw that on here there is no 55 inch phillips projection tv so I just decided to ask on here the 50 in....well again my question was regarding this feature that I didnt even know it had the picture in picture and I am not sure if I need special cable or is it already built in aned what do i have to press to make it appear in my menu....please any info you can give me I would really appreciate it....I have the Phillips Magnavox control that came with it the remote has the number CL015 ....and on the other side 47/03 dont know if these mean anything to you , but i thought id write it in anyway...thanks again Sincerely Diana
I have a 55 inch phllips projection tv. the color looks white and washed out like the brightness is not adjusted corectly, I have adjusted it as much as i can with the remote but i still get a washed out picture. What is wrong and what can i do?
Posted on Apr 04, 2009
I have the same tv add a two way splitter at the back of your tv one leg of the splitter to antenna a and the other leg of the splitter to antenna b. then you will have pip.
Posted on Feb 22, 2009
    President:
  • 4,402 Answers
You have to have your ant/cable connected to but tunners on the back you should see a ant1 and a ant2 then select pip from your remote
Posted on Jan 22, 2008
I have a philips big screen projection tv modul#55p8341 that turns off after being on for a while. great picture and sound
Your horizontal output chip is going bad after it heats up to a certain point it fails and shuts your set down. After a while if not replaced your set will fail to power up at all.
Aug 13, 2010 | Philips 55P8341 55" Rear Projection...
I have the 55" phillps rear projection tv
Common problem with this model. Goto www.TvRepairKits.com to get their chirping TV repair kit.
Feb 24, 2009 | Philips 55PW9363 55" Rear Projection...
Tv menu
I am having the same issue! Ugh!
Sep 22, 2008 | Philips 55P8341 55" Rear Projection...
Philips 50P8341 50 in. Rear... Problem:
You CRT coolant needs to be replaced, its a very common problem with the phillips and magnavox projection TVs. If you need more info on the Coolant Change let me know.
Jul 14, 2008 | Philips 55P8341 55" Rear Projection...
Pillips projection tv
I HAVE A PHILIPS M#55P8341A THERE IS DOUBLE PICTURE ON THE SCREEN IF YOU HAVE ONE PERSON THERE YOU SEE TWO OF THEM ONE IS RED THE OTHER IS GREEN?
Jul 09, 2008 | Philips 55P8341 55" Rear Projection...
Help
Change the CRT coolant in the green and blue tubes thats a comon problem with that model. You will be amazed at the results that changing the coolant will have on color, it will make it look like new again.
Jun 13, 2008 | Philips 55P8341 55" Rear Projection...
Philips 55P8341 red pic
yes change the coolant, if that doesnt correct the problem you will need a blue CRT
Jun 04, 2008 | Philips 55P8341 55" Rear Projection...
Blinking lights on philips 55P8341
5 volt protection is causing the set to go into protective shutdown. Check for shorted diode 6306. Part#934038020127
or shorted capacitor 2318. or faulty voltage regulator
May 18, 2008 | Philips 55P8341 55" Rear Projection...
Cannot adjust colors
sounds like your red tube is getting a short I can post you a web sight and they have used red picture tubes
http://servicemanuals.vstore.ca/
Apr 22, 2008 | Philips 55P8341 55" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
106 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
