Question about RCA 36V430T 36" TV
Popping sound then no video. Power TV off and then back on and get video for seconds to minutes only.
    Sergeant:
  • 210 Answers
A capactor is going down( look like little batteries) and if any have raised tops replace
Posted on Dec 12, 2009
TV picture goes out after 10 minutes of viewing with popping sound
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced.
If you need any information or other assistance let me know.
Thanks,
Lee
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Lines disappear mostly if the tv is switched off for about 15 seconds and start popping slowly and spread all over in few minutes. Is it a motherboard or t-con board problem? The problem was caused by a...
remove the back cover of your tv shut off your light then observe if there is sprkling in the inverter section, that's the cause of popping sound,,
Sep 09, 2013 | Televison & Video
What causes the TV to go on and off when first turned on, until it warms up for 5 to 10 minutes
Try turning the volume all the way down then power the TV an see how
long it takes to bring a screen up if you still hear a popping sound then you have a bad part with a bad connection most likey a lamp and wiring.
Call to have it serviced a must if so.
Jun 08, 2012 | Mitsubishi LT-3280 32 in. LCD HDTV
LG Plasma 42pc3d turns on, pops, then turns off
The first thing you should look into is the Z-SUS board, the one situated on the right side viewed from the rear. This board develops a high voltage during operation that might be the source of the popping sound. It is also responsible in refreshing the panel for proper picture display. The weird colors on your TV indicates a faulty Z-SUS board.
Note: Unplug the TV and wait for at least five minutes in order to allow the voltages to drain before you disconnect or reconnect any connector.
  • Disconnect the Z-SUS board from the Y-SUS board. The Z-SUS board is situated on the right side viewed from the rear of the TV while the Y-SUS is on the left.
  • Plug the TV back and turn it on.
  • You will still be able to see the weird colors the moment the TV shut off but do not flash. If it does not pop and stays on and there's a sound, you are pretty sure the Z-SUS board is faulty. Replace it.
  • If it still pops and shuts off, disconnect the Y-SUS board from the power supply. The Y-SUS board also develops a high voltage during operation. The power supply is the one right between the Z and Y-SUS boards.
  • Re-apply AC power then turn the TV on.
  • You'll not be able to see any color or video. If it does not pop and stays on with sound, you have a faulty Y-SUS board, replace it.
  • If it still pops and shuts off, please let me know.
Feel free to update me of the result and your own findings.
Dec 03, 2009 | LG 42PC3D 42 in. Plasma Television
Dell 17" LCD TV takes a long time to come on 15 minutes or more
popping noise is an indicatior of a bd board. if the unit power light still lights amber, it probably the main board else the power board a circuit or two may have been fried. both boards need to be examined. questions, email me
Feb 05, 2009 | Dell W1700 17 in. HD-Ready LCD Television
Video warps on edges then cuts out to black, then fades back in
Please dont rate me if could not fix your problem. Check the tv lamp. If doest work well, replace it. Thank you..
Nov 29, 2008 | Samsung TXM3096WHF 30" TV
Popping sounds
Do a complete overhaul of the regulated power supply===solder any/all bad connects,replace any weak capacitors.HB Electronics kit #103-088 will help you locate which parts go bad===get on it before it crashes hard!
Sep 26, 2007 | Daewoo DTQ-27S3FC 27" TV
RCA 36V430T 36" TV Logo
57 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
