Question about Maytag MMV5000 Microwave Oven
Everything is working on my microwacve but it is not heating the food. Is there a fuse or Magtron tube I can replace?
  • 612 Answers
The answer to your question is, Yes. Click on this http://www.partselect.com/MultiModels.aspx?ModelNum=mmv5000&SearchTerm=fuse&RefineSearch=0 and the part you see labled as #5 is the fuse you will need to replace. Take all the screws out around the back that are holding the outter case on. Once you have the case off, look back behind the touch panel. There you will find the fuse, mag tube and a lot of other parts. You can use a meter to check the fuse before you replace it and if it's good your mag tube will most likely be the problem. Good luck
Posted on Dec 12, 2009
Evry thing works except the food is not heated. It makes the noise, timer counts down..
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side of the blower housing, or magnetron tube assembly)))
Dec 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave will not heat food but everything else works.
(((The fuse is located inside the unit along side the magnetron)))
Nov 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave wont heat food. Everything else works.
Micorwave doesn't work when the megatron tube is out. That's probably why it won't heat up. Either replace microwave or the tube. You can get the number from Sears for the megatron tube by calling customer support.
Nov 09, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Does everything but heat food.
Sounds like the magnatron tube or it's fuse.
Aug 11, 2009 | Kenmore 80809 Microwave Oven
Still operable
Jul 30, 2009 | Goldstar MA-1011 Microwave Oven
Everything seems to work but it does not heat the food.
Jul 30, 2009 | GE JVM1650 1000 Watts Microwave Oven
Is not cooking
sounds like the magtron is gone out.
Call GE answer center 1-800-626-2000 ask for tech help. Have you model # off the data plate ready.
May 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave will not heat food.
Sometimes inside the machine there is a fuse for this, if you can remove the outer case you should be able to see it, HOWEVER let me tell you that i have been in this position and have replaced the fuse and the machine then works only to die again, once this happens it is usally a sign that either the tube or a transformer is gone and it normally isnt worth getting fixed.
Mar 26, 2009 | Microwave Ovens
Maytag MMV5000 Microwave Oven Logo
109 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
