Question about LG 42PX5D 42 in. Plasma HDTV
Usb harddisk problem on LG 50PT81+ not compatibel XP
I have a LG plasma 50 inch with a 80 Gb build in Harddisk. It's possible to connect a external USB harddisk . I bought one on Westrn Digital ( 500 Gb , Fat32 ) . My problem : When I connect th USB hardisk original to my PC ( XP Pro ) , no problem , everyhing works. When I connect original to my LG Plasma, it reconized the USB connection , but I need to format the USB harddisk with the USB-format option ( menu of TV ). Than , I can copy films and everything to that harddisk . But when I want to reconnect it to my pc , he shows the harddiks in My Computer , but when I get access , get an errot and ask me to format the drive. the only option is NFTS. What can i do , I installed ext2FSD ( linux based file manager , ext2,ext3 ) but no solution
LG have created a solution that only allows you to backup to a hard disk in the format that they have created.
The hard disk can not then be read by a computer as they only recognize formats such as NTFS, FAT or FAT32: not LG´s format!!!
If you reformat the disk in FAT32 format then you can copy files to the hard disk and see your photos, or certain types of DIVX files and listen to music via your TV,......BUT...you can not save TV programs from the TV to the same hard disk UNLESS you allow the TV to reformat the hard disk to LG´s format ) in which case you will lose all the files you previously had on the hard disk.
In practice LG have created a backup solution that is of little use to most users particularly bearing in mind that the backup takes almost as long as the original programs and as long again to restore.
Most of LG´s products are very clever and have a tendency to be in advance of the market.
However on this occasion LG almost had a good idea but many users are going to feel tricked like I did,
Posted on Mar 09, 2008
The best way is you can format the hard disk in NFTS and then you can format your computer to the same format. then there will be no problem. The problem is because of two defferent formats. Its always a good idea to stick in one format. Hope that might help
Posted on Jan 26, 2008
  • maxpppp Feb 08, 2015
    Yoy can not format the LG TV hard disk to NFTS format
Windows 7 cant pig up my external hard drive
Try to install the required drivers for the external USB-enclosure. If you did, you should verify if the connections inside the encloser is well connected, as you should also check if the included powersupply (adapter) will be sufficient to power the internal harddisk.
Another test is to connect the drive to a different USB-port at your computer, or,... even better, connect it to a different PC.
Another option is that the harddisk is not formatted. Some OS'es (like Windows) don't handle this well. You can look for Acronis Disk Dokter at Internet, to overcome this.
If all failed, well, then you got an hardware issue. Either the external enclosure is malfunctioning or the harddisk is defective.
Oct 13, 2013 | Verbatim 500GB USB Desktop 500 GB Hard...
Harddisk > 500 GB
yes you can simply make ur ram more from 1 gb..or etc
Jun 16, 2013 | Asrock 775i65G Motherboard
Dear Sirs, I need the Windows 98 Driver for Western Digital USB External HardDisk 320 GB ? I use COMPAQ Presario with Windows XP to hook up the External Harddisk right know. The External...
Sory to report - from Western Digital support site
Uses SES Drivers
7, Vista, XP
Not Supported
Server 2008, Server 2003, 2000 Server, 2000, ME, 98SE, 98, 95
Win 98 is not a supported OS, for that drive.
Jan 27, 2011 | Western Digital My Passport Essential...
How to transfer data from seagate barracuda 7200.7 ST380011A 80 GB hard drive to another hard drive after crash?
You need a usb cable to harddisk. than a computer running linux. connect hd by usb to linux and copy.
Jan 13, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Hi my Transcend 320 GB harddisk is not getting detected. Storejet 320Gb
hello
connect the USB external hard disk to usb port by the way disconnect other working harddisks
available on the system, boot the system with bootable cd/floppy go to command prompt and run
chkdsk on this drive
Also download "mbrfix" connect all working harddisks along with the nondetecting harddisk and run mbrfix for the USB defective harddisk
Try using different USB data transfer cable, if power source adapter is used check for rated power output in multimeter for this adapter, if found defective replace it with new/good adapter with same
specifications
Bad luck if harddisk controller has failed you have to go in for new harddisk
GOOD LUCK ooo
Nov 10, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
Can i make my portable hard drive an external hard drive?
It is already. Just connect it to a USB port and it should pop up as a new drive.
Jun 02, 2010 | Buffalo Technology 250GB MINISTATION TURBO...
I've dropped my Western Digital 250gb hard drive & now its not working. The light on the device does light up & the computer recognises that something has been connected but you cannot see the...
I've similar problem with Samantha_500, i inadvertently dropped internal Harddisk (Seagate 80GB) with external case (M-Tech), the external case was broken into pieces (only the parts with plastic), the Harddisk is not working anymore, it detects by windows XP as a device connected in USB, but no drives detected in windows explorer. is there any way to recover this harddisk? thanks for the help in advance.
Dec 26, 2009 | Western Digital Passport WDXML800UE...
My dvd rw is not detected
When installing SP2 version, you possibly corrupted the drivers for the DVD. It is possible there are different drivers for the DVD between XP and XP (sp2). Go to the laptop mfg website and download the newest drivers for the DVD.
Aug 20, 2007 | Microsoft Windows XP Professional With...
LG 42PX5D 42 in. Plasma HDTV Logo
688 people viewed this question
